Help on requirements for updating to WTP 0.7.1 [message #144912] |
Sat, 22 October 2005 10:14  |
Originally posted by: mcfall.Hope.edu
This may not be entirely on topic, but this seems to be the best place to
ask.
I would like to move to WTP 0.7.1 from 0.7. I'm currently using Eclipse
3.1. The dependencies listed at
http://download.eclipse.org/webtools/downloads/drops/M-0.7.1 -200509270720/
are:
- The EMF driver used in this build is emf-sdo-xsd-SDK-2.1.1.zip
- The GEF driver used in this build is GEF-SDK-3.1.1.zip
- Java EMF Model Runtime driver used in this build is JEM-SDK-1.1.0.1.zip
When I use Eclipse's update feature, it tells me that the following updates
for installed features are available:
- JEM: Java EMF Model 1.1.0.1
- EMF/SDO/XSD: EMF SDK 2.1.1
- GEF: GEF 3.1.1
I'm assuming that since these version numbers match those listed as the WTP
0.7.1 requirements that I'd be all set to do the update, and then download
the wtp-0.7.1.zip file and drop it into my plugins directory. However, the
lack of the SDK name in the JEM and GEF updates listed by eclipse makes me
wonder if there's a difference between them (especially since at the
download site of 0.7.1 there is one download listed as wtp-0.7.1.zip and one
as wtp-sdk-0.7.1.zip). What's the difference between those things with the
SDK in their names and those without?
If I download the wtp-0.7.1.zip file, do I need to delete those files
referenced by 0.7.0? If so, how do I identify them? Does:
ls -d *wst*
do the trick before the download?
Ryan
Re: Help on requirements for updating to WTP 0.7.1 [message #144949 is a reply to message #144912] |
Mon, 24 October 2005 03:17  |
wtp 0.7.1 have ugly bug wiht xml editor (throw NPE when open, activate, type
in editor etc) - 0.7 is better or last weekly build
> ask.
> are:
> updates for installed features are available:
> - GEF: GEF 3.1.1
> WTP 0.7.1 requirements that I'd be all set to do the update, and then
> download
> the lack of the SDK name in the JEM and GEF updates listed by eclipse
> makes me wonder if there's a difference between them (especially since at
> the download site of 0.7.1 there is one download listed as wtp-0.7.1.zip
> and one
> the SDK in their names and those without?
> ls -d *wst*
> Ryan
FUDForum. Page generated in 0.05231 seconds
