Home » Language IDEs » ServerTools (WTP) » "Processing Dirty Regions" error on WTP 0.7.1
"Processing Dirty Regions" error on WTP 0.7.1 [message #144895] Fri, 21 October 2005 17:19 Go to next message
Originally posted by: glen.db.verizon.net
Hello, running either 0.7.0 or 0.7.1 (using the all-in-one downloads for
both these versions of WTP) both give me a popup error "An internal
error occurred during: 'Processing Dirty Regions'" whenever I edit an
XML file. What version of WTP do I need to fix this (0.6 does not have
this error, but I would like something more recent.)
Also, is there a convenient way to search this newsgroup--the newsgroup
archives do not appear to have a search function.
Glen
Re: "Processing Dirty Regions" error on WTP 0.7.1 [message #147417 is a reply to message #144895] Thu, 17 November 2005 04:55 Go to previous messageGo to next message
I have also this problem with wtp 0.7.0.
Could the de team help us ?
Thank you,
Eric
"Glen Mazza" <glen.db@verizon.net> a
Re: "Processing Dirty Regions" error on WTP 0.7.1 [message #147575 is a reply to message #144895] Thu, 17 November 2005 14:52 Go to previous messageGo to next message
You might want to check your workspace's .metadata/.log file for the
full stack trace. It might help to explain why the error is
occurring or at least give you a starting point for opening a bug.
I suggest you check 1.0M8 or the upcoming 1.0M9 to see if the
problem is still happening.
- Nitin
Re: "Processing Dirty Regions" error on WTP 0.7.1 [message #148254 is a reply to message #147575] Tue, 22 November 2005 11:27 Go to previous messageGo to next message
I have tried the 1.0M9 and it's the same problem.
Here is my workspace's .metadata/.log file (in the attached file.).
Eric
"Nitin Dahyabhai" <nitind@us.ibm.com> a
  • Attachment: error.log
    (Size: 128.15KB, Downloaded 185 times)
Re: "Processing Dirty Regions" error on WTP 0.7.1 [message #148341 is a reply to message #147417] Tue, 22 November 2005 11:30 Go to previous messageGo to next message
I have only the problem on linux red Hat ES 3.0, on windows xp it's works
well.
Eric
"Eric Celerse" <eric.celerse@fr.thalesgroup.com> a
Re: "Processing Dirty Regions" error on WTP 0.7.1 [message #148343 is a reply to message #148341] Tue, 22 November 2005 11:45 Go to previous messageGo to next message
On Tue, 22 Nov 2005 11:30:25 -0500, Eric Celerse <eric.celerse@fr.thales=
group.com> wrote:
> I have only the problem on linux red Hat ES 3.0, on windows xp it's wo=
rks
> well.
Since the log contains a "class not found" error, be sure you restart WT=
P (once) with the
-clean option, incase its an "installed cache" probroblem. If you see af=
ter that, please
open a bug report with complete log. You might try the very very latest =
M9 candidate too ...
I know some "schema resolutions/lookup/caching" problems have been fixed=
in last day or two,
so *might* be releated to those.
Re: "Processing Dirty Regions" error on WTP 0.7.1 [message #148364 is a reply to message #148254] Tue, 22 November 2005 15:38 Go to previous messageGo to next message
Eric Celerse wrote:
> Hello,
Do you have a version of Xerces in your jre/lib/ext folder or
another org.apache.xerces plugin installed?
- Nitin
Re: "Processing Dirty Regions" error on WTP 0.7.1 [message #148516 is a reply to message #148364] Wed, 23 November 2005 10:23 Go to previous message
I had a version of Xerces in my jre/lib/ext folder. I have erased it. and it
works well.
Thank you.
Eric
Previous Topic:MDB with jboss
Next Topic:WTP0.7: NoClassDefFound: StructuredTextEditor from org.eclipse.jface plugin
Current Time: Wed Oct 29 09:02:17 EDT 2025
Powered by FUDForum. Page generated in 0.04696 seconds
