Home » Eclipse Projects » Sirius » Export the Sirius project so others can use(Sirius project as standalone project or Eclipse plugins )
Export the Sirius project so others can use [message #1438575] Mon, 06 October 2014 04:14 Go to next message
Hi guys,
I manage to built a project for creating models in Sirius, after the model is created, I use Acceleo to transfor the diagram into formal text that I use to perform some analysis.
The question is how I can pack the whole project so others can use it.
I hope there's someone who can help Smile
Best regards
Re: Export the Sirius project so others can use [message #1440383 is a reply to message #1438575] Wed, 08 October 2014 05:36 Go to previous messageGo to next message
Did you use the Viewpoint Specification Project wizard to create your
VSM? This wizard add automatically the required extension point
"orge.eclipse.sirius.componentization" for deployement, so the VSM
created in the project will be available when it turns as a plugin.
Therefore, you can package your project as usual if the extension point
is set.
Steve
Le 06/10/2014 10:14, MG Gharib a écrit :
> Hi guys,
> I hope there's someone who can help :)
> Best regards
Steve Monnier - Obeo
Need professional services for Sirius?
Re: Export the Sirius project so others can use [message #1441335 is a reply to message #1440383] Thu, 09 October 2014 11:33 Go to previous messageGo to next message
Hi Steve,
No, I was asking about such technique.
I will try it, thank you very much.
Best regards
Re: Export the Sirius project so others can use [message #1448533 is a reply to message #1440383] Mon, 20 October 2014 00:19 Go to previous messageGo to next message
Hi Steve,
If possible can you give more information about how I can do this Smile
Because I did not know exactly where to start.
Best regards
Re: Export the Sirius project so others can use [message #1448783 is a reply to message #1448533] Mon, 20 October 2014 08:41 Go to previous messageGo to next message
In the Sirius perspective, you can create a Viewpoint Specification
Project with the action in File/New/Viewpoint Specification Projet or
using the contextual menu of the Model Explorer view. You can find some
documentation in the Help, look into Sirius Specifier
Manual/Viewpoint/Viewpoint Specification Projects.
Steve
Le 20/10/2014 06:19, MG Gharib a écrit :
> Hi Steve,
> If possible can you give more information about how I can do this :)
> Best regards
Re: Export the Sirius project so others can use [message #1448851 is a reply to message #1448783] Mon, 20 October 2014 10:35 Go to previous messageGo to next message
Hi Steve,
Yes I did that, the whole project works fine at my laptop. But I want to know how I can export it so others can use.
In particular, I managed to develop my modeling tool, and managed to use Acceleo to transform any diagram I make into some sort of formal language that I use to perform some analysis on the models I create.
However, I still need to do one final thing, I need to make this framework available to others, i.e., put it somewhere so others can download and use.
Any idea, how such thing can be done?
Best regards
Re: Export the Sirius project so others can use [message #1448891 is a reply to message #1448851] Mon, 20 October 2014 11:37 Go to previous message
A Viewpoint Specification Project is a java plugin and can be built by
several methods, feature project + update site project, p2,
tycho...Sirius is built using tycho so as an exemple you can look into
the pom.xml files of each plugins. As this is an Eclipse building
question more than a Sirius related question, I will let you find a
tutorial on internet, but there are many and I recommend you to look for
a tutorial on Tycho.
Steve
Le 20/10/2014 16:35, MG Gharib a écrit :
> Hi Steve,
> download and use.
> Best regards
Previous Topic: Split the model into several files with Sirius
Next Topic:Get selected element
Current Time: Wed Jul 23 18:28:19 EDT 2025
Powered by FUDForum. Page generated in 0.05011 seconds
