Home » Language IDEs » ServerTools (WTP) » 1.0M8 and tomcat republish
1.0M8 and tomcat republish [message #140861] Tue, 27 September 2005 09:43 Go to next message
Originally posted by: patrick.roumanoff.gmail.com
I have tried 1.0M8, and it solved a number of issues I have had with
0.7, which are very nice like correct xml catalog lookup or Team
syncronisation (no more CVS folders in .deployables).
But there is a new issue than I can't work with.
While with 0.7 I was able to edit a JSP on the fly and be able to see
the resulting in the browser by a single reload (in the browser), WTP
1.0M8 seems to believe that editing a JSP requires what looks like a
major project compile + automatic republish. More over it now takes
a much longer time to save a JSP or a java class.
my webapps are fairly complex and I describe my setup in
http://roumanoff.blogspot.com/. I manually edited my .wtpmodules to
include the jar coming from a maven repository, and I also have inter
project dependencies.
WTP0.7 was able to handle this complexity, but this seems to have been
lost in 1.0M8. Or am I missing something ?
I had to edit my .project file since the builder
org.eclipse.wst.common.modulecore.DependencyGraphBuilder and the nature
org.eclipse.jst.j2ee.web.WebNature have disappeared in 1.0M8.
I tried the demo app
http://www-128.ibm.com/developerworks/db2/library/techarticl e/dm-0509cline/
which works very well and doesn't republish on jsp or class editing.
but there is no external jar dependency or dependency on other eclipse
projects.
I would really like to understand why my webapp gets republished when I
edit a JSP.
any idea/comments welcome.
Patrick Roumanoff
Out of memory error [message #141308 is a reply to message #140861] Thu, 29 September 2005 09:56 Go to previous messageGo to next message
Hello Team,
I am facing some issue when extending WTP framework to work with myServer
(custom server) and creation of web service.
I am getting out of memory error with the stack trace as bellow.
In Pre service develop command.
org.eclipse.core.runtime.CoreException[1]: java.lang.OutOfMemoryError:
PermGen space
at org.apache.tools.ant.Project.executeTarget(Project.java:1223 )
at org.apache.tools.ant.Project.executeTargets(Project.java:106 2)
at
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:704)
at
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:455)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:356)
at
com.bea.wlw.webservices.core.model.GenerationScript.run(Gene rationScript.java:160)
at
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
Caused by: java.lang.OutOfMemoryError: PermGen space
--- Nested Exception ---
In Pre service assemble command.
In Pre service deploy command.
In Pre service install command.
In Pre service run command.
I have tried setting the PermGen size into eclipse.ini as
-vmargs
-Xms256m
-Xmx1024m
-XX:PermSize=256m
-XX:MaxPermSize=1024m
Still the problem is not getting solved. Not sure if this problem is seen by
anybody in this team.
Does anyone know why this problem comes?
Your suggestions are highly appreciated.
~ <SandeepDarvekar/>
Re: Out of memory error [message #141688 is a reply to message #141308] Fri, 30 September 2005 21:23 Go to previous messageGo to next message
On Thu, 29 Sep 2005 09:56:45 -0400, Punery <sandeep_darvekar@persistent.=
co.in> wrote:
> -vmargs
> -Xms256m
> -Xmx1024m
> -XX:PermSize=3D256m
> -XX:MaxPermSize=3D1024m
>Still the problem is not getting solved. Not sure if this problem is se=
en by
Some on this list have seen before: See "Mysterious OutofMemory Errors" =
earlier in posts.
One wrote,
<quote>
found that the default values for these settings (sun JVM)
are -XX:PermSize=3D4m, and -XX:MaxPermSize=3D64m.
I tried changing these to -XX:PermSize=3D64m (as 64m doesn't ssem to be
enough), and -XX:MaxPermSize=3D128m.
</quote>
And another commented
<quote>
Running out of
PermGen space is symptomatic of bug where the application has a lingerin=
g, usually cunningly concealed, reference to an old ClassLoader (or,
less commonly, the classloader itself is broken and not unloading classe=
s correctly
</quote>
So ... if there's any bug in our code, I'd guess someone is creating and=
hanging on to class loaders too much.
If you have the abiliity to profile, you might look for classes related =
to classloading ... and we have a bunch.
A quick scan found this short list
ContextFinder
WorkerJob
ArchiveImpl
ArchiveFileDynamicClassLoader
ObjectInputStreamCustomResolver
Or ... if anyone has step to reproduce (e.g. with Tomcat Server), please=
open a bugzillas.
Re: 1.0M8 and tomcat republish [message #144846 is a reply to message #140861] Fri, 21 October 2005 14:16 Go to previous message
Originally posted by: rsanheim.REMOVE.gmail.com
Patrick Roumanoff wrote:
[snip]
This republish behavior is very annoying - go vote for the bug.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=112363
- Rob
http://www.robsanheim.com
Previous Topic:IWAB0398E Error in WTP .07 G.S.
Next Topic:Rewuild of workspace on any file change
Current Time: Thu May 08 14:29:32 EDT 2025
Powered by FUDForum. Page generated in 0.05557 seconds
