Populate Table From Database [message #1447959] |
Sun, 19 October 2014 01:37  |
IDataProvider bodyDataProvider = new ListDataProvider<OrgDetails>(retrievedData, columnPropertyAccessor);
the retrievedData is poplated only user opens perspective and enters something in search box.
My issue is the nattable throws exception if I do so saying cannot find data.
Re: Populate Table From Database [message #1448213 is a reply to message #1447959] |
Sun, 19 October 2014 11:41   |
My bad I should have been clearer.
The above statement is responsible for population the tables right .
My issue is when that in my program
retrievedData is populated after intialization of the application and in doing so Nattable thorws error a Null Pointer Exception. Is there a way like avoid this I will post snippet as well as error log for clarity.
searchButton = new Button(parent, SWT.PUSH);
searchButton.setText("Search");
searchButton.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
System.out.println(searchText.getText());
StoreInDatabase sd = new StoreInDatabase();
retrievedData = (List<OrgDetails>)sd.retrieveFromDatabase(searchText.getText());
IColumnPropertyAccessor<OrgDetails> columnPropertyAccessor = new OrganizationDetailsPropertyAccessor();
final DataLayer bodyDataLayer = new DataLayer(bodyDataProvider);
final SelectionLayer selectionLayer = new SelectionLayer(bodyDataLayer);
ViewportLayer viewportLayer = new ViewportLayer(selectionLayer);
ILayer columnHeaderLayer = new ColumnHeaderLayer(
new DataLayer(createColumnHeaderDataProvider()),
viewportLayer,
selectionLayer);
CompositeLayer compositeLayer = new CompositeLayer(1, 2);
compositeLayer.setChildLayer(GridRegion.COLUMN_HEADER, columnHeaderLayer, 0, 0);
compositeLayer.setChildLayer(GridRegion.BODY, viewportLayer, 0, 1);
NatTable natTable = new NatTable(parent, compositeLayer);
natTable.setLayoutData(
new GridData(SWT.FILL, SWT.FILL, false, true, 3, 1));
at org.eclipse.nebula.widgets.nattable.data.ListDataProvider.getRowCount(ListDataProvider.java:41)
at org.eclipse.nebula.widgets.nattable.layer.DataLayer.getRowCount(DataLayer.java:267)
at org.eclipse.nebula.widgets.nattable.layer.DataLayer.getHeight(DataLayer.java:318)
at org.eclipse.nebula.widgets.nattable.layer.DataLayer.getPreferredHeight(DataLayer.java:323)
at org.eclipse.nebula.widgets.nattable.layer.AbstractIndexLayerTransform.getPreferredHeight(AbstractIndexLayerTransform.java:258)
at org.eclipse.nebula.widgets.nattable.layer.AbstractLayerTransform.getPreferredHeight(AbstractLayerTransform.java:251)
at org.eclipse.nebula.widgets.nattable.layer.CompositeLayer.getChildClientArea(CompositeLayer.java:651)
at org.eclipse.nebula.widgets.nattable.layer.CompositeLayer.access$3(CompositeLayer.java:642)
at org.eclipse.nebula.widgets.nattable.layer.CompositeLayer$1.getClientArea(CompositeLayer.java:610)
at org.eclipse.nebula.widgets.nattable.viewport.ViewportLayer.getClientAreaWidth(ViewportLayer.java:1341)
at org.eclipse.nebula.widgets.nattable.viewport.ViewportLayer.recalculateAvailableWidthAndColumnCount(ViewportLayer.java:740)
at org.eclipse.nebula.widgets.nattable.viewport.ViewportLayer.getWidth(ViewportLayer.java:572)
at org.eclipse.nebula.widgets.nattable.grid.layer.DimensionallyDependentLayer.getWidth(DimensionallyDependentLayer.java:211)
at org.eclipse.nebula.widgets.nattable.layer.CompositeLayer$CompositeLayerPainter.paintLayer(CompositeLayer.java:906)
at org.eclipse.nebula.widgets.nattable.painter.layer.NatLayerPainter.paintLayer(NatLayerPainter.java:43)
at org.eclipse.nebula.widgets.nattable.NatTable.paintNatTable(NatTable.java:408)
at org.eclipse.nebula.widgets.nattable.NatTable.paintControl(NatTable.java:403)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:230)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4353)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1061)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1085)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1070)
at org.eclipse.swt.widgets.Composite.WM_PAINT(Composite.java:1491)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4667)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:339)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5036)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2549)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1151)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:164)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:236)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
Error while painting table: null
[Updated on: Sun, 19 October 2014 11:43] by Moderator
Re: Populate Table From Database [message #1448214 is a reply to message #1447959] |
Sun, 19 October 2014 11:43   |
viewportLayer,
selectionLayer);
Re: Populate Table From Database [message #1448289 is a reply to message #1448214] |
Sun, 19 October 2014 14:34  |
Well, the issue is that you are not populating data in the retrievedData list, you are replacing the collection. At the point you are setting the list, the reference points to null. How should NatTable notice that you are setting a reference to a collection afterwards?
Typically you should create an empty list and perform a clear() + addAll() when performing a load operation.
FUDForum. Page generated in 0.07828 seconds
