Home » Eclipse Projects » GEF » REPOST: Marquee + bendpoint selection/move
REPOST: Marquee + bendpoint selection/move [message #144450] Mon, 26 July 2004 15:25 Go to next message
I wondered if anyone had thoughts on this, I'd really like to try and get
this issue resolved.
> I'm trying to implement functionality whereby when multiple nodes are
> selected and moved (via the marquee tool for example) then any absolute
> bendpoints which live on the connections between two nodes being moved,
> are also moved. This question has been asked a number of times before,
> and I have been following the following suggestion made by Randy:
> - Simple! When the class get's a changeBoundsRequest, have it forward some
> - "move bendpoints request" to all of it's source connections (source
> - connections are the ones going out of the node). You can do this
> - conditionally only if the target node is also moving (see
> - ChangeBoundsRequest.getEditParts()). You could test for the condition
> - either on the connection, or at the time when you decide to forward to
> the
> - connection.
> I think I have done what is being suggested here. When a
> changeBoundsRequest is received by the node then it iterates through all
> the connections it is the source for and test to see if the target node is
> also being moved. If this is the case, then REQ_MOVE_BENDPOINT requests
> are constructed and the appropriate commands queued. This works, but the
> problem is that the new position is the new position of the node (set
> using request.setLocation(..)) not of the bendpoint.
> Any suggestion on how I can work out the bendpoints new position? Or
> alternatively a better way to implement this functionality?
> James
Re: REPOST: Marquee + bendpoint selection/move [message #144606 is a reply to message #144450] Tue, 27 July 2004 14:07 Go to previous messageGo to next message
some
> > the
> > - connection.
is
the
So use request.getMoveDelta(), and apply it to the current bendpoint
location.
An alternative way would be to have the drag tracker determine which
connection editparts should be asked, and have it ask the connection
directly. You may be able to simply override getOperationSet() and then
just add support for MOVE in the connection editparts. Or you could make up
a new request ID specifically which is probably cleaner.
> > James
Re: REPOST: Marquee + bendpoint selection/move [message #144700 is a reply to message #144606] Tue, 27 July 2004 17:26 Go to previous messageGo to next message
> is
> the
> location.
Thanks Randy - it so obvious when you point it out!
One further question. I have an XYLayoutEditPolicy set on the parent of
the nodes in question. When the nodes are moved - this policy handles the
request. I would have expected that request.getEditParts() returns a list
of all the nodes receiving the request (i.e. if I remove four nodes
simultaneously, then this list would of size four). However the value is
always one regardless of how many nodes are being dragged, why is this?
James
Re: REPOST: Marquee + bendpoint selection/move [message #144872 is a reply to message #144700] Wed, 28 July 2004 09:46 Go to previous messageGo to next message
This is because each child individually receives the move request, and
forward it on to its parent for itself only. The plan was to change this so
that the selection set was split up into individual sets of children with
the same parent, and then ask each parent for the necessary commands. But
no one has really required this so it hasn't happened. For compatibility we
would probably have to make this an option on DragEditPartsTracker and not
the default.
"James Willans" <jwillans@cs.york.ac.uk> wrote in message
news:ce6h98$63b$1@eclipse.org...
all
node
> > is
requests
but
> > the
(set
> > location.
> James
Re: REPOST: Marquee + bendpoint selection/move [message #145045 is a reply to message #144872] Wed, 28 July 2004 17:17 Go to previous messageGo to next message
Okay thanks. So how can I calculate which other nodes are being
simultaneously being moved?
James
> the default.
> all
> node
> > > is
> requests
> but
> > > the
> (set
> > > location.
> > James
Re: REPOST: Marquee + bendpoint selection/move [message #145537 is a reply to message #145045] Thu, 29 July 2004 13:03 Go to previous message
You only want to do this one time, not for every node being dragged. I
would suggest doing it in the drag tracker and extending getCommand to
include the move bendpoints contribution.
news:ce954j$gu2$1@eclipse.org...
> James
this so
with
But
compatibility we
not
> > the default.
Previous Topic:a toolEntry stays pushed
Next Topic:a toolEntry that call a method
Current Time: Fri Jul 18 21:55:44 EDT 2025
Powered by FUDForum. Page generated in 0.06601 seconds
