Eclipse wont start (yet another thread) [message #1444961] |
Tue, 14 October 2014 16:39  |
Hey everyone,
at first i'll excuse in advance for any bad english because it's not my native language.
But now to my problem:
I need to start in java programming, so I recently installed eclipse succesfully on 2 machines (at work and in a virtual machine).
The last few hours i tryed to install it on my personal computer at home and it's going to drive me nuts :(
After I did, what I did 2 times before (download and unpack eclipse, install java jdk, setup eclipse.ini, start eclipse, be happy) it seems that nothing I'm going to try leads to a starting eclipse.exe
There is no error message, no splash screen, nothing.
If I start the eclipse.exe by double click in explorer, I get an explorer.exe which consumes 25% of my cpu (one core) and nothing changes this until I restart my system. Same thing happens when I try to start eclipse.exe via console (cmd), only difference is a cmd.exe in taskmanager consuming 25% CPU.
My system specs are:
Windows 8.1 x64 (not running any UAC or sth, as user with admin rights)
16GB Ram
Intel i5-3570K
(if u need more details, just tell me)
A few things i tryed:
- complety cleaned my system of all java installations and eclipse to da a "fresh" restart (again) -> nothing
- reset PATH value to default -> nothing (even after another reinstall of java with clean PATH)
- set path to javaw.exe in eclipse.ini (-vm -> next line the path)
- start ecplisec.exe over cmd -> not a single output line displayed in the prompt
- start eclipse.exe with parameters -clean or -cleanPersistedState or even both -> again not a single output line ... just a cmd.exe consuming my CPU until I restart the system
I attached some screenshots of my problem to this post.
I hope anyone here can help me on this.
Greetz Michael
Re: Eclipse wont start (yet another thread) [message #1446964 is a reply to message #1446947] |
Fri, 17 October 2014 11:21  |
I just tryed something ...
I started Windows in Safemode and did another "clean start" (remove eclipse/java -> fresh download)
After I just unpacked eclipse i tryed to start it and i got the error messages that no java is installed (ofc, i just removed it so it's fine)
Without installing Java i restartet into "normal mode".
I tryed to start either 32-Bit version and 64-Bit version and none of them is doing anything (like before).
So i guess that there is a process or service running that kinda blocks eclipse from starting (i already tryed to disable antivir / antimalware / firewall etc. without success).
Depending on my mood i get the next hours i will either go for a windows reinstall or start removing software by software (or services) from autostart to see which programm causes the issue.
Thanks anyways for all the help i got from you so far.
I'll post again if i can manage to run eclipse succesfully.
Cheers
FUDForum. Page generated in 0.10025 seconds
