| Creating a VM instance programatically [message #143197] |
Wed, 18 February 2004 18:32  |
Originally posted by: handcock.redhat.com
Does anyone know how to create an installed VM definition programatically?
ie. I 'm trying to add a JVM at /foo/bar/java_home to the Eclipse
preferences using Eclipse API calls.
Jeremy
| Re: Creating a VM instance programatically [message #144643 is a reply to message #144065] |
Mon, 23 February 2004 09:29   |
You should not create an instance of "StandardVMType", you should retrieve
it from the launching plug-in
JavaRuntime.getVMInstallType(String id).
The id for a standard VM type is
"org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType".
Darin
"Jeremy Handcock" <handcock@redhat.com> wrote in message
news:c15eu6$c93$1@eclipse.org...
> Darin Wright wrote:
> > Create an instance of a VMStandin, set its properties/attributes, and
then
> > call "convertToRealVM". This will add it to the JRE definitions.
> Thanks, Darin.
> I'm somewhat of an eclipse newbie. This snippet doesn't seem to be
> working for me:
> StandardVMType stdvmtype = new StandardVMType();
> VMStandin standin = new VMStandin(stdvmtype, "someUniqueID");
> standin.setInstallLocation(new File("/opt/IBMJava2-141"));
> standin.setName("IBMJava2-141");
> IVMInstall realVM = standin.convertToRealVM();
> try {
> JavaRuntime.setDefaultVMInstall(realVM, null, true);
> } catch(Exception e) {
> e.printStackTrace();
> Whenever I try to setDefaultVMInstall, I get a NPE at
org.eclipse.jdt.internal.launching.CompositeId.toString(Comp ositeId.java:42)
> Are there additional things that I need to define in the VMStandin before
> calling convertToRealVM()?
> Thanks.
> Jeremy
> > news:c10smj$5km$1@eclipse.org...
programatically?
> > > Thanks,
> > > Jeremy
| Re: Creating a VM instance programatically [message #144688 is a reply to message #144643] |
Mon, 23 February 2004 10:42  |
Ah, I see. Excellent... got this to work now. Thanks for your help, Darin.
Jeremy
> Darin
> then
>>Thanks, Darin.
>>working for me:
>>try {
>>Thanks.
>>Jeremy
> programatically?
>>>>Thanks,
>>>>Jeremy
FUDForum. Page generated in 0.03650 seconds
