Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Edapt] install on Kepler
[Edapt] install on Kepler [message #1445379] |
Wed, 15 October 2014 06:54  |
Hi there,
how can I install Edapt on Kepler?
The 0.3.0 version on http://download.eclipse.org/edapt/update-site/
seems to require EMF Compare 1.0.1, but I don't get that from the Kepler
release. And the EMF Compare Site only holds releases from 2.1.
When installing the nightly from
http://download.eclipse.org/edapt/p2/nightly/
I don't get any error during dependency calculation, but at the
installing step. Find the error message below. How can I fix that?
Hauke
An error occurred while collecting items to be installed
session context was:(profile=epp.package.modeling,
phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=,
action=).
No repository found containing:
osgi.bundle,org.eclipse.emf,2.6.0.v20140519-0339
osgi.bundle,org.eclipse.emf.ant,2.8.0.v20140519-0339
osgi.bundle,org.eclipse.emf.ant.source,2.8.0.v20140519-0339
osgi.bundle,org.eclipse.emf.cheatsheets,2.5.0.v20140519-0339
osgi.bundle,org.eclipse.emf.cheatsheets.source,2.5.0.v20140519-0339
osgi.bundle,org.eclipse.emf.codegen,2.10.0.v20140519-0339
osgi.bundle,org.eclipse.emf.codegen.ecore,2.10.0.v20140519-0339
osgi.bundle,org.eclipse.emf.codegen.ecore.source,2.10.0.v20140519-0339
osgi.bundle,org.eclipse.emf.codegen.ecore.ui,2.10.0.v20140519-0339
osgi.bundle,org.eclipse.emf.codegen.ecore.ui.source,2.10.0.v20140519-0339
osgi.bundle,org.eclipse.emf.codegen.source,2.10.0.v20140519-0339
osgi.bundle,org.eclipse.emf.codegen.ui,2.6.0.v20140519-0339
osgi.bundle,org.eclipse.emf.codegen.ui.source,2.6.0.v20140519-0339
osgi.bundle,org.eclipse.emf.common,2.10.0.v20140514-1158
osgi.bundle,org.eclipse.emf.common.source,2.10.0.v20140514-1158
osgi.bundle,org.eclipse.emf.common.ui,2.9.0.v20140519-0339
osgi.bundle,org.eclipse.emf.common.ui.source,2.9.0.v20140519-0339
osgi.bundle,org.eclipse.emf.converter,2.7.0.v20140519-0339
osgi.bundle,org.eclipse.emf.converter.source,2.7.0.v20140519-0339
osgi.bundle,org.eclipse.emf.databinding,1.3.0.v20140519-0339
osgi.bundle,org.eclipse.emf.databinding.edit,1.3.0.v20140519-0339
osgi.bundle,org.eclipse.emf.databinding.edit.source,1.3.0.v20140519-0339
osgi.bundle,org.eclipse.emf.databinding.source,1.3.0.v20140519-0339
osgi.bundle,org.eclipse.emf.doc,2.7.0.v20140519-0339
osgi.bundle,org.eclipse.emf.ecore,2.10.0.v20140514-1158
osgi.bundle,org.eclipse.emf.ecore.change,2.10.0.v20140514-1158
osgi.bundle,org.eclipse.emf.ecore.change.edit,2.6.0.v20140519-0339
osgi.bundle,org.eclipse.emf.ecore.change.edit.source,2.6.0.v20140519-0339
osgi.bundle,org.eclipse.emf.ecore.change.source,2.10.0.v20140514-1158
osgi.bundle,org.eclipse.emf.ecore.edit,2.9.0.v20140519-0339
osgi.bundle,org.eclipse.emf.ecore.edit.source,2.9.0.v20140519-0339
osgi.bundle,org.eclipse.emf.ecore.editor,2.10.0.v20140519-0339
osgi.bundle,org.eclipse.emf.ecore.editor.source,2.10.0.v20140519-0339
osgi.bundle,org.eclipse.emf.ecore.source,2.10.0.v20140514-1158
osgi.bundle,org.eclipse.emf.ecore.xmi,2.10.0.v20140514-1158
osgi.bundle,org.eclipse.emf.ecore.xmi.source,2.10.0.v20140514-1158
osgi.bundle,org.eclipse.emf.edit,2.10.0.v20140519-0339
osgi.bundle,org.eclipse.emf.edit.source,2.10.0.v20140519-0339
osgi.bundle,org.eclipse.emf.edit.ui,2.10.0.v20140519-0339
osgi.bundle,org.eclipse.emf.edit.ui.source,2.10.0.v20140519-0339
osgi.bundle,org.eclipse.emf.example.installer,1.3.0.v20140519-0339
osgi.bundle,org.eclipse.emf.exporter,2.7.0.v20140519-0339
osgi.bundle,org.eclipse.emf.exporter.source,2.7.0.v20140519-0339
osgi.bundle,org.eclipse.emf.importer,2.9.0.v20140519-0339
osgi.bundle,org.eclipse.emf.importer.ecore,2.8.0.v20140519-0339
osgi.bundle,org.eclipse.emf.importer.ecore.source,2.8.0.v20140519-0339
osgi.bundle,org.eclipse.emf.importer.java,2.7.0.v20140519-0339
osgi.bundle,org.eclipse.emf.importer.java.source,2.7.0.v20140519-0339
osgi.bundle,org.eclipse.emf.importer.rose,2.7.0.v20140519-0339
osgi.bundle,org.eclipse.emf.importer.rose.source,2.7.0.v20140519-0339
osgi.bundle,org.eclipse.emf.importer.source,2.9.0.v20140519-0339
osgi.bundle,org.eclipse.emf.mapping,2.8.0.v20140519-0339
osgi.bundle,org.eclipse.emf.mapping.ecore,2.6.0.v20140519-0339
osgi.bundle,org.eclipse.emf.mapping.ecore.editor,2.6.0.v20140519-0339
osgi.bundle,org.eclipse.emf.mapping.ecore2ecore,2.8.0.v20140519-0339
osgi.bundle,org.eclipse.emf.mapping.ecore2ecore.editor,2.7.0.v20140519-0339
osgi.bundle,org.eclipse.emf.mapping.ecore2ecore.editor.source,2.7.0.v20140519-0339
osgi.bundle,org.eclipse.emf.mapping.ecore2ecore.source,2.8.0.v20140519-0339
osgi.bundle,org.eclipse.emf.mapping.ecore2xml,2.8.0.v20140519-0339
osgi.bundle,org.eclipse.emf.mapping.ecore2xml.source,2.8.0.v20140519-0339
osgi.bundle,org.eclipse.emf.mapping.ecore2xml.ui,2.7.0.v20140519-0339
osgi.bundle,org.eclipse.emf.mapping.ecore2xml.ui.source,2.7.0.v20140519-0339
osgi.bundle,org.eclipse.emf.mapping.source,2.8.0.v20140519-0339
osgi.bundle,org.eclipse.emf.mapping.ui,2.6.0.v20140519-0339
osgi.bundle,org.eclipse.emf.mapping.ui.source,2.6.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.codegen.ecore,2.10.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.codegen.ecore.source,2.10.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.codegen.ecore.ui,2.10.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.codegen.ecore.ui.source,2.10.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.codegen,2.10.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.codegen.source,2.10.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.codegen.ui,2.8.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.codegen.ui.source,2.8.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.common,2.10.0.v20140514-1158
org.eclipse.update.feature,org.eclipse.emf.common.ui,2.9.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.common.ui.source,2.9.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.converter,2.10.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.converter.source,2.10.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.databinding.edit,1.4.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.databinding.edit.source,1.4.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.databinding,1.4.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.databinding.source,1.4.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.doc,2.9.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.doc.source,2.9.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.ecore.edit,2.9.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.ecore.edit.source,2.9.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.ecore.editor,2.10.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.ecore.editor.source,2.10.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.ecore,2.10.0.v20140514-1158
org.eclipse.update.feature,org.eclipse.emf.edit,2.10.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.edit.source,2.10.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.edit.ui,2.10.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.edit.ui.source,2.10.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf,2.10.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.mapping.ecore.editor,2.9.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.mapping.ecore.editor.source,2.9.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.mapping.ecore,2.8.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.mapping.ecore.source,2.8.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.mapping,2.8.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.mapping.source,2.8.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.mapping.ui,2.8.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.mapping.ui.source,2.8.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.sdk,2.10.0.v20140519-0339
org.eclipse.update.feature,org.eclipse.emf.source,2.10.0.v20140519-0339
Re: [Edapt] install on Kepler [message #1445499 is a reply to message #1445379] |
Wed, 15 October 2014 10:22   |
On 15-10-14 12:54, Hauke Fuhrmann wrote:
> Hi there,
That's possible. The latest build was intended to do exactly that.
This is the old update site, with a build not compatible with Kepler.
I am having issues populating (automatically) the download area with the
builds. stay tuned, working on it right now.
> Cheers,
> Hauke
> action=).
Re: [Edapt] install on Kepler [message #1445516 is a reply to message #1445499] |
Wed, 15 October 2014 10:52   |
Can you try to install from this p2 URL:
http://download.eclipse.org/edapt/p2/repository
Does this work for you?
>> Hi there,
>> Cheers,
>> Hauke
>> action=).
Re: [Edapt] install on Kepler [message #1488020 is a reply to message #1445516] |
Wed, 26 November 2014 03:41  |
Hi Christoph,
installation worked like a charm even on Luna. Thanks a lot!
Hauke
Am 15.10.2014 16:52, schrieb Christophe Bouhier:
>>> Hi there,
>>> Cheers,
>>> Hauke
>>> action=).
Current Time: Wed Jul 30 21:05:35 EDT 2025
Powered by FUDForum. Page generated in 0.04170 seconds
