Home » Eclipse Projects » Remote Application Platform (RAP) » Custom Component: Server Side Component
Custom Component: Server Side Component [message #1234149] |
Tue, 21 January 2014 05:47  |
as mentioned in the other topic (http://www.eclipse.org/forums/index.php/t/637543/) i am trying to create a custom component based on Javascript Jit Visualization.
Right now, i am struggeling with the Java Server side implementation.
In the client i am doing the following:
// This method is called on DOM label creation.
// Use this method to add event handlers and styles to
// your node.
onCreateLabel : function(label, node) {
label.id = node.id;
label.innerHTML = node.name;
label.onclick = function() {
console.log("clicked " + node.name);
remoteObject.onSend(node);
//later
onSend : function(node) {
if (typeof (node) != "undefined") {
console.log(node);
rap.getRemoteObject(this).set("text", node.name); }
I want to achieve the following:
I am displaying a tree with different nodes, and when a node is clicked, the name should be send to the server, do a server side operation, and send the result back to client.
On the Server, i am doing the following which is based on the CKEditor template:
private final OperationHandler operationHandler = new AbstractOperationHandler() {
public void handleSet(JsonObject properties) {
JsonValue textValue = properties.get("text");
if (textValue != null) {
text = textValue.asString();
System.out.println(text);
Whenever i click a node on the client, nothing happens until i resize the client window. Then the System.out.println on the server is called.
I searched around the wiki and the forum and found the following:
call(method, properties)
Instructs the remote object to call the given method. Calling this method will write a "call" operation into the message, which will to be sent to the server within a few milliseconds. One message may contain several "call" operations, if they are added consecutively.
Parameters:
{string} method
The name of the method.
{Object|null} properties Optional
This object may contain any number of additional properties/fields associated with the call. It may also be null or omitted.
So when i change the client code to the following:
console.log(node);
rap.getRemoteObject(this).call("text", node.name);
I get the following error
WARN qtp1306210867-85 org.eclipse.jetty.servlet.ServletHandler /daios/app org.eclipse.rap.json.ParseException: Unexpected end of input at 1:-1
at org.eclipse.rap.json.JsonParser.error(JsonParser.java:371)
at org.eclipse.rap.json.JsonParser.expected(JsonParser.java:362)
at org.eclipse.rap.json.JsonParser.readValue(JsonParser.java:97)
at org.eclipse.rap.json.JsonParser.parse(JsonParser.java:62)
at org.eclipse.rap.json.JsonValue.readFrom(JsonValue.java:92)
at org.eclipse.rap.json.JsonObject.readFrom(JsonObject.java:123)
at org.eclipse.rap.rwt.internal.protocol.ProtocolUtil.getClientMessage(ProtocolUtil.java:69)
at org.eclipse.rap.rwt.internal.service.LifeCycleServiceHandler.isSessionShutdown(LifeCycleServiceHandler.java:241)
at org.eclipse.rap.rwt.internal.service.LifeCycleServiceHandler.synchronizedService(LifeCycleServiceHandler.java:78)
at org.eclipse.rap.rwt.internal.service.LifeCycleServiceHandler.service(LifeCycleServiceHandler.java:67)
at org.eclipse.rap.rwt.engine.RWTServlet.handleValidRequest(RWTServlet.java:121)
at org.eclipse.rap.rwt.engine.RWTServlet.handleRequest(RWTServlet.java:108)
at org.eclipse.rap.rwt.engine.RWTServlet.doPost(RWTServlet.java:99)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:755)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at org.eclipse.rap.rwt.osgi.internal.CutOffContextPathWrapper.service(CutOffContextPathWrapper.java:106)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:128)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:386)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:669)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:457)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:229)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1075)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:384)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:193)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1009)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:135)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:116)
at org.eclipse.jetty.server.Server.handle(Server.java:368)
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:489)
at org.eclipse.jetty.server.AbstractHttpConnection.content(AbstractHttpConnection.java:953)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.content(AbstractHttpConnection.java:1014)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:861)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:240)
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:82)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:628)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:52)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:608)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:543)
at java.lang.Thread.run(Thread.java:744)
I even red the Wiki Page with title
How exactly do I use the "listen" method?
But i dont understand how to add the mentioned method.
To make a long story short, how can i achieve that the server responds a event of the client?
If you need further information please feel free to ask.
Tobias
Re: Custom Component: Server Side Component [message #1234308 is a reply to message #1234149] |
Tue, 21 January 2014 11:54   |
Hello...
> // your node.
> label.id = node.id;
I don't know what "node" is or where you get the "remoteObject" from,
but if it is a normal RAP remoteObject this can't be right since there
is no "onSend" method on RemoteObject. If you created some object
yourself and called it "remoteObject" then I would rethink that name,
because anyone reading your code would be really confused about that.
> //later
> console.log(node);
Assuming the "this" is correctly set and the method is called, this
looks correct.
That is what the above code should do, yes. As the documentation states
"This method does not cause the message to be sent immediately. Instead
it will be sent the next time a "notify" or "call" operation is written
to the message."
(http://download.eclipse.org/rt/rap/doc/2.2/guide/reference/jsdoc/symbols/RemoteObject.html#set)
- In this case the window resize causes a notify operation somewhere
else entirely.
> console.log(node);
Yes, probably because "call" expects a property map as the second
parameter, not a string.
(http://download.eclipse.org/rt/rap/doc/2.2/guide/reference/jsdoc/symbols/RemoteObject.html#call)
In any case, "set" is the right method to use, not "call". But "set" is
only meant to synchronize client/server state, not to send events. So if
you want to notify your application that something happened, then in
ADDITION to "set" you need to send a "notify" operation. How this is
done is documented
here(http://download.eclipse.org/rt/rap/doc/2.2/guide/reference/jsdoc/symbols/RemoteObject.html#notify)
and
here("https://wiki.eclipse.org/RAP/Custom_Widgets_FAQ#How_exactly_do_I_use_the_.22listen.22_method.3F")
Example:
remoteObject.set( "text", "something" );
remoteObject.notify( "textChanged" );
As explained there, for your notify operation to work you need to have
the event type in the typeHandlers "events" array
(http://download.eclipse.org/rt/rap/doc/2.2/guide/reference/jsdoc/symbols/rap.html#.registerTypeHandler)
and render a "listen" operation form the server
(http://download.eclipse.org/rt/rap/doc/2.2/guide/reference/api/org/eclipse/rap/rwt/remote/RemoteObject.html#listen%28java.lang.String,%20boolean%29).
The idea is that a notify is only send if the server actually has to do
something for that event, usually notify listeners that execute
application code. If the application didn't register any listeners then
the client doesn't have to send notify operations, so it doesn't do that
and the "set" operation is send with the next request.
If you ALWAYS have to do something IMMEDIATELY on a client side event,
"call" would be the right operation to use. E.g.:
remoteOBject.call( "doSomething" );
However, that might be a sign of bad design. Why would the server side
widget have to immediately do something on a client side value change
unless there are listeners from the application?
If you don't understand something about this or have suggestions how to
make it more understandable in the wiki, let me know.
Greetings,
Tim
Tim Buschtöns
Twitter: @EclipseRAP
Current Time: Wed Jul 23 12:50:45 EDT 2025
Powered by FUDForum. Page generated in 0.27741 seconds
