Home » Newcomers » Newcomers » launch the text editor
launch the text editor [message #144260] Tue, 21 March 2006 13:44 Go to next message
Originally posted by: jr_gz.hotmail.com
Hello everybody(sorry for my english), I would know how can I launch the
text editor of eclipse to work into a file.
I wonna launch the text editor of eclipse when I click into a file showed
in a jtree.
Does anyone know how can I do it, or a similar idea?
Thanks a lot
King Regards
Re: launch the text editor [message #144498 is a reply to message #144260] Wed, 22 March 2006 13:08 Go to previous messageGo to next message
DosenŽt nobody know how launch the eclipseŽs editor?
Re: launch the text editor [message #144524 is a reply to message #144498] Wed, 22 March 2006 15:14 Go to previous messageGo to next message
Originally posted by: myersj.gmail.com
Add a file association for the file type you want to edit -
Window->Preferences->General->Editors->File Associations.
Add a file type that matches the file you want to open. Then associate
that type with the Text Editor.
- Jeff
Re: launch the text editor [message #144589 is a reply to message #144524] Thu, 23 March 2006 04:36 Go to previous messageGo to next message
Sorry, but you donŽt understand me very well.
IŽm developing a plug-in that shows everyfiles of a directory in a
jtree(swing), and I wonna launch eclipseŽs text editor when I clicked in
one of theese files.
Re: launch the text editor [message #144623 is a reply to message #144589] Thu, 23 March 2006 09:39 Go to previous messageGo to next message
Is this an Eclipse plug-in? If so, why are you writing it in Swing?
Anyways, you can call:
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().openEditor(new
FileEditorInput(file), "org.eclipse.ui.DefaultTextEditor");
where file is the IFile for the file you selected in your tree.
Hope this helps,
- Jeff
Re: launch the text editor [message #145317 is a reply to message #144623] Tue, 28 March 2006 03:31 Go to previous messageGo to next message
Hello and thanks by your answer.
I was using swing because I couldnŽt show the tree in a view, but IŽve
resolved this problem.
I think your solution is good, but I donŽt know how to use the IFile.
IFile are used for files in the worksapce, but if I wonna open a file out
of the workspace(i.e c:\prueba.txt), How could I use it?
IŽm beginner developing plug-ins and "IŽm very green" and I have lot of
problems.
Thanks a lot.
Re: launch the text editor [message #145319 is a reply to message #145317] Tue, 28 March 2006 05:11 Go to previous message
Hello Jeff.
IŽve probed your solution but I found a problem. I tell you:
When I execute my plugin and I try to launch the text editor in this way
IWorkspace ws = ResourcesPlugin.getWorkspace(); //****
IProject project = ws.getRoot().getProject("External Files");
IPath location = new Path("C:\\jr.txt");
IFile file = project.getFile(location.lastSegment());
IEditorInput input=null;
input = new FileEditorInput(file);
try {
openEditor(input, "org.eclipse.ui.DefaultTextEditor");
} catch (PartInitException e) {
e.printStackTrace();
I recieve the next error,
Unhandled event loop exception
Reason:
Workspace is closed.
when the plugin execute the first instruction(****).
CouldnŽt I indicate to IFIle (file) the file that must open without use
project.getfile() since this is what produce the error?
Thanks a lot.
Previous Topic:Win 95 Install
Next Topic:GEF or GMF
Current Time: Wed Oct 15 05:55:58 EDT 2025
Powered by FUDForum. Page generated in 0.10372 seconds
