| xmls file with non-xml extension (*.jrxml) [message #144483] |
Wed, 19 October 2005 13:20  |
How i can make file association for file with non .xml suffix
(for example jasperreport *.jrxml)
I make file association in Preferences and file is opne with 'XML editor'
but I can't call validation, format (context menu) doesn't work (disabled),
folding doesn't work , syntax highligth etc
What is a problem ?
Peco
| Re: xmls file with non-xml extension (*.jrxml) [message #144511 is a reply to message #144492] |
Wed, 19 October 2005 13:58   |
Amy,
i do it and I have more problem now (eclipse 3.1.1, emf 2.1.1, gef 3.1.1,
vep 1.1.0.1 and wtp 0.7.1 linux-gtk)
1) validation doesn't work (I haven't validation menu in context menu on
*.jrxml)
2) when i open *.jrxml i get error in error log (it work, but this error
get again and again when i type in editor ) :
error 1 : model has no JFace adapter factory
error 2: java.lang.NullPointerException
at
org.eclipse.wst.xml.ui.internal.views.contentoutline.XMLCont entOutlineConfiguration.updateForShowAttributes(XMLContentOu tlineConfiguration.java:306)
at
org.eclipse.wst.xml.ui.internal.views.contentoutline.XMLCont entOutlineConfiguration$ToggleShowAttributeAction.update(XML ContentOutlineConfiguration.java:99)
at
org.eclipse.wst.xml.ui.internal.views.contentoutline.XMLCont entOutlineConfiguration$ToggleShowAttributeAction. <init>(XMLContentOutlineConfiguration.java:94)
at
org.eclipse.wst.xml.ui.internal.views.contentoutline.XMLCont entOutlineConfiguration.createMenuContributions(XMLContentOu tlineConfiguration.java:115)
at
org.eclipse.wst.sse.ui.internal.provisional.views.contentout line.StructuredContentOutlineConfiguration.getMenuContributi ons(StructuredContentOutlineConfiguration.java:194)
at
org.eclipse.wst.sse.ui.internal.contentoutline.StructuredTex tEditorContentOutlinePage.setConfiguration(StructuredTextEdi torContentOutlinePage.java:382)
at
org.eclipse.wst.sse.ui.internal.contentoutline.StructuredTex tEditorContentOutlinePage.createControl(StructuredTextEditor ContentOutlinePage.java:193)
at
org.eclipse.ui.views.contentoutline.ContentOutline.doCreateP age(ContentOutline.java:133)
at org.eclipse.ui.part.PageBookView.createPage(PageBookView.jav a:315)
at org.eclipse.ui.part.PageBookView.partActivated(PageBookView. java:613)
at
org.eclipse.ui.views.contentoutline.ContentOutline.partBroug htToTop(ContentOutline.java:206)
at org.eclipse.ui.internal.PartListenerList$2.run(PartListenerL ist.java:87)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
at
org.eclipse.ui.internal.PartListenerList.fireEvent(PartListe nerList.java:58)
at
org.eclipse.ui.internal.PartListenerList.firePartBroughtToTo p(PartListenerList.java:85)
at
org.eclipse.ui.internal.PartService.firePartBroughtToTop(Par tService.java:87)
at
org.eclipse.ui.internal.WorkbenchPagePartList.firePartBrough tToTop(WorkbenchPagePartList.java:75)
at
org.eclipse.ui.internal.WorkbenchPagePartList.fireActiveEdit orChanged(WorkbenchPagePartList.java:51)
at org.eclipse.ui.internal.PartList.setActiveEditor(PartList.ja va:143)
at
org.eclipse.ui.internal.WorkbenchPage.makeActiveEditor(Workb enchPage.java:1128)
at
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:2903)
at org.eclipse.ui.internal.WorkbenchPage.activate(WorkbenchPage .java:552)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2371)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2295)
at org.eclipse.ui.internal.WorkbenchPage.access$9(WorkbenchPage .java:2287)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2273)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2268)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2249)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:371)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:334)
at
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:251)
at
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:131)
at
org.eclipse.jdt.internal.ui.actions.OpenActionUtil.open(Open ActionUtil.java:49)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:16 9)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:15 3)
at
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:222)
at
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:198)
at
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:296)
at
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 4.open(PackageExplorerPart.java:869)
at
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:741)
at
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 8)
at
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:739)
at
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:968)
at
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1067)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:243)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:238)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:277)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1021)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2867)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2572)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Amy Wu wrote:
> You need to associate your file extension to the XML Content Type.
> Preferences -> General -> Content Types
> "Haris Peco" <snpe@snpe.co.yu> wrote in message
> news:dj5o5n$ik3$3@news.eclipse.org...
>> Hi,
> (disabled),
>> What is a problem ?
>> Peco
| Re: xmls file with non-xml extension (*.jrxml) [message #144559 is a reply to message #144511] |
Wed, 19 October 2005 14:57   |
Originally posted by: amywu.us.DELETETHISPART.ibm.com
1) you should check out https://bugs.eclipse.org/bugs/show_bug.cgi?id=112037
as to why there is no validation action. I think the validation should
still be kicking in though, when you save. And it should be the same
validation you see as you are typing (source validation).
2) This code has been cleaned up a bit since wtp 0.7.1. So this bug may
have already been fixed. But you can report this bug and include step by
step scenario and sample file.
Was everything else working after you associated your file extension to the
xml content type? Content assist, syntax highlighting?
news:dj5qe0$n41$1@news.eclipse.org...
> Amy,
3.1.1,
> *.jrxml)
> at
uration.updateForShowAttributes(XMLContentOutlineConfigurati on.java:306)
> at
uration$ToggleShowAttributeAction.update(XMLContentOutlineCo nfiguration.java
:99)
> at
uration$ToggleShowAttributeAction.<init>(XMLContentOutlineConfiguration.java
:94)
> at
uration.createMenuContributions(XMLContentOutlineConfigurati on.java:115)
> at
ontentOutlineConfiguration.getMenuContributions(StructuredCo ntentOutlineConf
iguration.java:194)
> at
tlinePage.setConfiguration(StructuredTextEditorContentOutlin ePage.java:382)
> at
tlinePage.createControl(StructuredTextEditorContentOutlinePa ge.java:193)
> at
ne.java:133)
> at
utline.java:206)
> at
> at
:1044)
> at
> at
st.java:85)
> at
> at
> at
> at
28)
> at
> at
va:2371)
> at
> at
> at
> at
> at
ity.java:251)
> at
ity.java:131)
> at
49)
> at
> at
on.java:198)
> at
> at
> at
> at
:1044)
> at
9)
> at
968)
> at
a:1067)
> at
> at
> at
> at
> at
java:226)
> at
> at
> at
> at
..java:25)
> Thanks
> >> Hi,
editor'
> > (disabled),
> >> What is a problem ?
> >> Peco
| Re: xmls file with non-xml extension (*.jrxml) [message #144586 is a reply to message #144559] |
Thu, 20 October 2005 00:23   |
I would like try with last wtp, but I use spring-ide and hibernate plugins
and the doesn't work with last build (M8 or bigger)
syntax highlighting and content assist work fine
outline view doesn't exists - I rename same file to *.xml and outline work
fine
I will try last build - which one is more stable ?
> the
>> Amy,
> 3.1.1,
>> *.jrxml)
>> at
>> at
> :99)
>> at
> :94)
>> at
>> at
> iguration.java:194)
>> at
>> at
>> at
> ne.java:133)
>> at
> utline.java:206)
>> at
>> at
> :1044)
>> at
>> at
> st.java:85)
>> at
>> at
>> at
>> at
> 28)
>> at
>> at
>> at
> va:2371)
>> at
>> at
>> at
>> at
>> at
> ity.java:251)
>> at
> ity.java:131)
>> at
> 49)
>> at
>> at
> on.java:198)
>> at
>> at
>> at
>> at
> :1044)
>> at
> 9)
>> at
> 968)
>> at
> a:1067)
>> at
>> at
>> at
>> at
>> at
> java:226)
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
> .java:25)
>> Thanks
>> >> Hi,
> editor'
>> > (disabled),
>> >> What is a problem ?
>> >> Peco
| Re: xmls file with non-xml extension (*.jrxml) [message #144684 is a reply to message #144559] |
Thu, 20 October 2005 14:29  |
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=112037 as to why there is no
> validation action. I think the validation should still be kicking in
> though, when you save. And it should be the same validation you see as
> have already been fixed. But you can report this bug and include st ep by
> the xml content type? Content assist, syntax highlighting?
2 is resolved in last weekly build (10512005) and 1 isn't important for me
FUDForum. Page generated in 0.04610 seconds
