Home » Eclipse Projects » Oomph » TargetDefinitionGenerator usage(How to generate a correct target definition?)
TargetDefinitionGenerator usage [message #1444760] Tue, 14 October 2014 10:12 Go to next message
I have managed to get the TargetDefiitionGenerator to work, in that by adding the annotation to the Targlet task, it generates a .target file upon performing it.
<annotation
       source="http:/www.eclipse.org/oomph/targlets/TargetDefinitionGenerator">
        <detail key="location"><value>${git.clone.location/releng/mytarget.target}</value></detail>
        <detail key="includeAllPlatforms"><value>false</value></detail>
        <detail key="includeSource"><value>false</value></detail>
        <detail key="generateVersions"><value>true</value></detail>
      </annotation>
1. I found that the File _must_ exist, otherwise the generation fails (although gracefully, a status is added to the Error log). Bug or feature?
2. I added "generateVersions" since the target is stupid, and without this, Tycho fails to find the correct versions.
3. The generated target only contains requirements from the Targlet where the annotation is added. This is understandable, however, I wanted to have two Targlets, as I saw in other setups in the catalog. However, this means that the generated target will not contain the required features from the other Targlets.
4. Simply adding the same repositories to the Targlet (without adding additional dependencies) seems to work.
5. Note that there may be some requirements that are not needed in the Targlet directly, but are needed in the .target for correct building (e.g. xbase.lib), I circumvented this by adding xtext.sdk requirement directly.
In the end, I managed to solve all my issues, another victory for Oomph Smile
Re: TargetDefinitionGenerator usage [message #1444764 is a reply to message #1444760] Tue, 14 October 2014 10:19 Go to previous messageGo to next message
Abel,
Comments below.
> upon performing it.
> <annotation
> <detail
> </annotation>
> feature?
I think it's a bug that we of course don't notice once it exists...
Please open bugzilla.
Yes, we generate one for Oomph purely for our Tycho builds.
Targlets are composed into a single target definition. In fact we have
a bit of a problem that the generated TP contains things we don't want
from the extra projects materialized by the other targlets...
I'm not sure I completely understand the setup involved.
> directly.
Yes, we often want extra things so that they'll be available in the
launched IDE, even if not directly required by the projects in the
workspace...
> Oomph :)
Cool. :-)
Re: TargetDefinitionGenerator usage [message #1444772 is a reply to message #1444764] Tue, 14 October 2014 10:32 Go to previous messageGo to next message
Thanks, Ed!
I have opened an issue: https://bugs.eclipse.org/bugs/show_bug.cgi?id=447112
If I add repository R from Targlet A to the repository list of Targlet B, and requirements in B depend on features in R, then those requirements will be generated into the .target. However, if R is not added to B, the same requirement is not in the generated into the .target.
Re: TargetDefinitionGenerator usage [message #1444773 is a reply to message #1444772] Tue, 14 October 2014 10:34 Go to previous message
Additional note: the setup in question is:
http://git.eclipse.org/c/viatra2/org.eclipse.viatra2.emf.git/diff/setup/org.eclipse.viatra.setup/VIATRAEMF.setup?id=8a786c0ba8ab57061cfd23a98a07c472444582f6
(I'm including the commit in the link for future reference, since I expect the setup will change over time)
I would be happy to hear any useful comments for improving this setup.
Previous Topic:Cloning git , importing and connecting to egit
Next Topic:"Do you trust these certificates"-Dialog does not popup during install
Current Time: Sun Jul 27 02:09:36 EDT 2025
Powered by FUDForum. Page generated in 0.04504 seconds
