Home » Archived » BIRT » selectively disabling "export to excel" option
selectively disabling "export to excel" option [message #702611] Tue, 26 July 2011 11:21 Go to next message
I'm using BIRT 2.6.2.
Is there a way to disable the option to export to excel, but only for SOME reports?
Alternatively, passing a URL parameter indicating if export to excel should be enabled is also a good option.
Re: selectively disabling "export to excel" option [message #702839 is a reply to message #702611] Tue, 26 July 2011 17:52 Go to previous messageGo to next message
Look at ExportReportDialogFragment.jsp in the
webcontent/birt/pages/dialog directory of the web viewer.
In this code you can get the report name like:
String rpt = ParameterAccessor.PARAM_REPORT;
You should be able to use this with the if statement:
if ( !ParameterAccessor.PARAM_FORMAT_HTML.equalsIgnoreCase(
supportedFormats[i] ) )
To drop the excel export option.
Jason
> SOME reports?
Re: selectively disabling "export to excel" option [message #1443809 is a reply to message #702611] Mon, 13 October 2014 04:34 Go to previous messageGo to next message
I am also searching for a way, to selectively enabling export options in BIRT reports.
Isn´t there a way, you can define this in the report itself?
Maybe using a script?
Re: selectively disabling "export to excel" option [message #1444667 is a reply to message #702839] Tue, 14 October 2014 07:28 Go to previous messageGo to next message
Jason Weathersby wrote on Tue, 26 July 2011 21:52
I tried to access the report name through ParameterAccessor.PARAM_REPORT but only got the default value "__report".
How can I access the report name or even the report id?
Re: selectively disabling 'export to excel' option [message #1779728 is a reply to message #1444667] Thu, 11 January 2018 16:20 Go to previous message
I am also looking for the same to control format options(pdf, xlsx ...) only for some reports.
how can we access the report name or report id in Exportreportdialogfragment.jsp? Please let me know is there any other way.
Srinivas Narra
[Updated on: Thu, 11 January 2018 16:21] by Moderator
Previous Topic:Problem with images export to pdf
Next Topic:in-out reports
Current Time: Sat Jul 19 04:03:28 EDT 2025
Powered by FUDForum. Page generated in 0.04960 seconds
