Home » Archived » BIRT » Anyone see why this should fail?
Anyone see why this should fail? [message #144451] Thu, 16 March 2006 07:40 Go to next message
Originally posted by: andy.nospam.com
I have a MySQL query where I want a difference in times between two dattime
fields. In testing, if I run this query in a MySQL client application (not
Birt)...
SELECT TIMEDIFF('2006-02-24 09:59:31','2006-02-01 00:00:00') as tdiff
then I get a result - 561:59:31.
If I run the exact same query in Birt, and try and preview the result, I get
the following error:
A BIRT exception occurred.
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Data Engine
Plug-in ID:org.eclipse.birt.data
Version:2.0.1
Error Code:odaconsumer.CannotGetTimeFromColumn
Error Message:Cannot get the time value from column: 1
Cannot get time value in the result set.
java.sql.SQLException
Anyone know why?
Andy
Re: Anyone see why this should fail? [message #144479 is a reply to message #144451] Thu, 16 March 2006 08:25 Go to previous messageGo to next message
Originally posted by: rebprotizer_2k3.hotmail.com
Why don't you use the expression system of birt.
first recover your minutes and after do a difference.
row["YourDate"].getTime()
Re: Anyone see why this should fail? [message #144497 is a reply to message #144479] Thu, 16 March 2006 09:46 Go to previous message
Yeeesss....I suppose I could...
But it still doesn't explain why it doesn't work.
This gives the same error:
select sec_to_time(unix_timestamp('2006-02-24 10:59:31') -
unix_timestamp('2006-02-24 09:59:30'))
as elapsed
And it shouldn't. I think there may be a bug?
Andy
"Lucho" <rebprotizer_2k3@hotmail.com> wrote in message
news:d4d8a4c62b46671a8901e17ed85d882c$1@www.eclipse.org...
Previous Topic:How to display the grid lines in the "Table"?
Next Topic:accessing dataset
Current Time: Sun Oct 26 19:34:23 EDT 2025
Powered by FUDForum. Page generated in 0.28888 seconds
