Home » Eclipse Projects » GEF » Graph Layout?
Graph Layout? [message #144230] |
Fri, 23 July 2004 20:28  |
Originally posted by: grant.hodgins.maketechnologies.com
Maybe I wasn't clear (see below).
I want to force a default layout the first time my figures are displayed
(with some kind of graph layout algorithm).
After the first display, I would like the diagram to not enforce the layout
(and thus be free form -which I have working well).
Can I accomplish a default graph layout on my rectangular figures with
connections?
Many Thanks,
Grant
"Grant Hodgins" <grant.hodgins@maketechnologies.com> wrote in message
news:cdoph3$hm3$1@eclipse.org...
> I'm a GEF Newbie.
> I have an existing model for which I need to provide a default graphical
> layout of figures. That is to say, I'd like to neatly organize and
> distribute figures on the canvas. I have no requirement to maintain this
> layout once the user manipulates the diagram.
> Assume the figures are simple rectangles.
> Is there a best practice approach or implementation to accomplish this?
> Thanks in advance,
> Grant Hodgins
Re: Graph Layout? [message #144441 is a reply to message #144423] |
Mon, 26 July 2004 14:17   |
So, displaying inheritance is pretty easy because it is directed. But how
would you handle relationships between classes? They are undirected and
sometimes may even be on classes which are on the same row in the class
hierarchy. DirectedGraphLayout doesn't handle undirected edges.
Of course, you can remove those edges and then add them back in.
Have you seen the org.eclpise.draw2d.examples project in CVS?
news:ce3ak4$c8g$1@eclipse.org...
> I'm writing a simple GEF application to display class diagrams and assist
in
> the manipulation.
> As such, my rectangles and connections, form the Draw2d perspective, are
> quite similar to the famous "Displaying a UML Diagram with Draw2D"
tutorial.
> I was looking for somewhere to start as the only detailed article I could
> find pertaining to GEF graph layout is written in Japanese
> (http://www13.plala.or.jp/observe/draw2d/draw2d_graph.html). The diagrams
> and snippets seem relevant but I can't read Japanese so I'm somewhat out
of
> luck to use this as a case study.
> Thank you,
> Grant
> "Randy Hudson" <none@us.ibm.com> wrote in message
> news:cdvamu$n19$1@eclipse.org...
> > > connections?
> > Yes, but this depends a lot on what your ractangles are and whether the
> > connections are directed or not. Are you doing class diagrams, ER,
flow?
Re: Graph Layout? [message #144481 is a reply to message #144441] |
Mon, 26 July 2004 20:34   |
For the purposes of my diagram, the directed edges will suffice. We're not
handling undirected edges - at least for now.
After learning from the examples I am close (thank you).
Now my problem is pertaining to the preferred size of my classes.
Before attempting a DefaultLayout with the DirectedGraphLayout, I used the
Dimension(-1,-1) to set the preferred size of the model for the class.
Now, of course, if I do that, the nodes do not take on the preferred size. I
believe the layout manager is responsible for determining this on first
paint which happens after I create the contents for the viewer.
When I'm creating the contents for my viewer on first load, I would like to
somehow retain the preferred size while still utilizing the node layout.
I was wondering what you might suggest to accomplish this? I don't
understand where or how I can have access to the preferred size of the
complete figure before I perform my default layout.
I've attempted to do this within: initializeGraphicalViewer() after
constructing the diagram model. (To no avail)
Any help is appreciated,
Grant
news:ce3ho4$mc2$1@eclipse.org...
assist
> in
> > the manipulation.
> tutorial.
could
diagrams
> of
> > Thank you,
> > Grant
with
> > > > connections?
the
> flow?
Re: Graph Layout? [message #144490 is a reply to message #144481] |
Mon, 26 July 2004 22:23   |
Check out https://bugs.eclipse.org/bugs/show_bug.cgi?id=54927
news:ce47rh$n7d$1@eclipse.org...
not
I
to
> Regards,
> Grant
how
> assist
> > in
> > > the manipulation.
are
> > tutorial.
> could
> diagrams
out
> > of
> > > Thank you,
> > > Grant
> with
> > > > > connections?
> the
> > flow?
Re: Graph Layout? [message #144638 is a reply to message #144481] |
Tue, 27 July 2004 14:16  |
You shouldn't be calling setPreferredSize(-1, -1)
you should be calling getPreferredSize(-1, -1)
Setting the size overrides anything the layout would normally do. You can
query the preferred size of a figure even before it has painted. We do this
in the Flow example in GEF.
not
I
to
> Regards,
> Grant
how
> assist
> > in
> > > the manipulation.
are
> > tutorial.
> could
> diagrams
out
> > of
> > > Thank you,
> > > Grant
> with
> > > > > connections?
> the
> > flow?
Current Time: Thu Sep 04 04:43:59 EDT 2025
Powered by FUDForum. Page generated in 0.26965 seconds
