Home » Eclipse Projects » Eclipse Platform » Installation location from BaseInstallHandler
Installation location from BaseInstallHandler [message #144161] Tue, 14 October 2003 18:39 Go to next message
I am writing a custom InstallHandler (that extends BaseInstallHandler) for
a feature. In the completeInstall() method, I need to determine the
installation location for the plugins, so I can perform some operations on
the newly installed files. Is there any way to do this using the update
API?
(I used to do this using
Platform.getPlugin("org.eclipse.update.core").find(new Path("."));
and then going up a level to find the plugins directory, but this doesn't
work in general, since Eclipse extension plugins may be installed in a
separate directory)
Re: Installation location from BaseInstallHandler [message #144214 is a reply to message #144161] Tue, 14 October 2003 21:22 Go to previous messageGo to next message
Originally posted by: dorian.birsan.net
"Roberto Scaramuzzi" <birdo@parasoft.com> wrote in message
news:bmhtv0$lvf$1@eclipse.org...
> API?
Update uses some sort of provider/consumer pattern for manipulating feature
contents. In particular, the feature provider has a getURL() method that you
can use to get info about the actual feature location. Plugins are located
in ../plugins relative to the feature.
When InstallHandler.initialize() is called keep track of the feature and
plugin entries objects passed to it, and when needed, just use the
feature.getFeatureContentProvider().getURL()
(I hope I got this right :-)
-Dorian
> separate directory)
Re: Installation location from BaseInstallHandler [message #144639 is a reply to message #144214] Wed, 15 October 2003 17:35 Go to previous messageGo to next message
> > API?
> -Dorian
I'm sorry to say feature.getFeatureContentProvider().getURL() points to
the location of the feature on the update site, not at the newly installed
file.
(and IFeatureContentConsumer does not have a getURL() method.)
Re: Installation location from BaseInstallHandler [message #144736 is a reply to message #144639] Wed, 15 October 2003 23:12 Go to previous message
news:bmkeji$6cf$1@eclipse.org...
for
operations on
update
> > > API?
It looks like I mixed things up a bit :-)
I'd say take a look at DeltaInstallHandler, which is used to install partial
plug-ins by first installing the partial plugin and then copies the
remaining files from the old version of the plugin.
> > -Dorian
> file.
Previous Topic:eclipse 2.1.1 an d win 95
Next Topic:How to properly use CVS/Branching in large development effort w/many projectes and developers
Current Time: Wed Nov 12 21:33:44 EST 2025
Powered by FUDForum. Page generated in 0.06830 seconds
