Home » Newcomers » Newcomers » Search/browse Java documentation in Eclipse?
Search/browse Java documentation in Eclipse? [message #144008] Mon, 20 March 2006 11:22 Go to next message
Originally posted by: johann.petrak.gmail.com
Is there a way to search/browse the Sun Java documentation from within
Eclipse similar as in Netbeans?
Re: Search/browse Java documentation in Eclipse? [message #144061 is a reply to message #144008] Mon, 20 March 2006 22:03 Go to previous messageGo to next message
Yes,
you need to go to Window->Preferences->Java->Installed JREs and add your
installed copy of a JDK to the list and set it to be the default JRE.
By default, eclipse detects a copy of the JRE, which does not have the
source code attached to it.
"jope" <johann.petrak@gmail.com> wrote in message
news:1790b3af4ab2edcbd0329b8b0e386a48$1@www.eclipse.org...
Re: Search/browse Java documentation in Eclipse? [message #144383 is a reply to message #144061] Wed, 22 March 2006 05:27 Go to previous messageGo to next message
Originally posted by: marmite.fastmail.fm
So, if I wanted to add the Javadoc for Jena, would I put this here too?
e.g. F:\Jena-2.3\doc\javadoc
Ivor
Re: Search/browse Java documentation in Eclipse? [message #144414 is a reply to message #144061] Wed, 22 March 2006 07:30 Go to previous message
Thank you for the answer. I still do not understand this though: how cam I
then search and view the Javadoc in Eclipse? Do I need a seperate plugin?
Also, what I wanted to do is to simply make the seperate Javadoc zipfile I
downloaded from Sun (jdk-1_5_0-doc.zip which contains all the html files)
available and usable from within Eclipse. The idea is that I can than
bring up the documentation of any element in the buffer (e.g. Character)
within Eclipse and maybe also use it for code completion.
What am I missing here?
Marcin Dobosz wrote:
> Yes,
Previous Topic:Moving class tabs down
Next Topic:How does build work?
Current Time: Wed Jul 23 19:36:15 EDT 2025
Powered by FUDForum. Page generated in 0.08210 seconds
