Home » Eclipse Projects » Eclipse Scout » FileChooser in RAP(Kepler Version)
FileChooser in RAP [message #1440364] Wed, 08 October 2014 05:20 Go to next message
Hi all,
I have a problem with FileChooser in RAP client, it doesn't work instead in SWT client works fine.
I follow this tutorial
http://wiki.eclipse.org/Scout/HowTo/3.9/Add_FileChooser_support_for_RAP_UI
And my technology selection are:
index.php/fa/19424/0/
When I try to use FileChooser in RAP this is the result that I obtain
index.php/fa/19422/0/
index.php/fa/19423/0/
Anyone has any idea to help me solve this problem?
Thanks in advance for any help
Re: FileChooser in RAP [message #1440377 is a reply to message #1440364] Wed, 08 October 2014 05:31 Go to previous messageGo to next message
Hi Marco,
please override the following method in the filechooser:
getConfiguredTypeLoad() {
  return true;
[Updated on: Wed, 08 October 2014 05:31] by Moderator
Re: FileChooser in RAP [message #1440393 is a reply to message #1440377] Wed, 08 October 2014 05:59 Go to previous messageGo to next message
Note, with the RAP filechooser you can only upload files. Download is not possible as the javadoc says:
   * Load or Save
   * <ul>
   * <li><code>true</code> loads the file from the file system into the application.</li>
   * <li><code>false</code> saves the file from the application to the file system. Attention: This does not work in
   * RAP/Web-UI</li>
   * </ul>
Re: FileChooser in RAP [message #1440396 is a reply to message #1440377] Wed, 08 October 2014 06:00 Go to previous message
Hi Matthias,
I follow your suggestion and now it works but ask to me to select mandatory a filename.
index.php/fa/19425/0/
Is it possible set in a way that allows you to select only the folder?
You replay at this question with your last topic, don't consider that
[Updated on: Wed, 08 October 2014 06:22] by Moderator
Previous Topic:Lifecycle of a Form
Next Topic:getDataByText() for SmartFields with CodeTypes
Current Time: Sat Nov 08 06:16:20 EST 2025
Powered by FUDForum. Page generated in 0.05043 seconds
