Re: Build VE for Eclipse 3.3 [message #144018 is a reply to message #143978] |
Thu, 13 March 2008 07:59  |
It is out of my responsability since I'm not committer. I do what I can to
contribute it.
best regards
Yves YANG
"Michele Puccini" <mik@c-l-a-s-s-x.it> wrote in message
news:fr2uqo$k67$1@build.eclipse.org...
> Hi David,
> this is the simplest working Eclipse 3.3.2 + VE installation around.
> Maybe this should be added to the Wiki.
> It would be nice to hear from Yves YANG..
> Cheers,
> Mik
> "David Perez" <craquerpro@yahoo.es> ha scritto nel messaggio
> news:f4cac21a416ecfe1660f883c44a3381e$1@www.eclipse.org...
>> Thanks for your tips.
>> GEF runtime 3.3.2 is a smaller download and also works.
>> Probably the EMF runtime will be also enough, instead of the full SDK.
>> Why don't make it official?
>>> - download your VE build
>>> - download Eclipse 3.3.2 (eclipse-java-europa-winter-win32.zip)
>>> - download emf-sdo-xsd-SDK-2.3.2.zip
>>> - download GEF-ALL-3.3.2.zip
>>> - unzip them all with respect of the eclipse directory structure.
>>> - READY to use. Just start Eclipse.
Re: Build VE for Eclipse 3.3 [message #616976 is a reply to message #143785] |
Tue, 04 March 2008 09:31  |
Hi Yves,
Everything is working very well with Europa 3.3.2 (Eclipse Europa Winter
Maintenance Packages).
The installation is really easy:
Many thanks.
Mik
> ClassX Development Italy Via Francesca, 368/I I-56030 S.M. a Monte (PI) <
> Tel.(+39)-0587-705153 Fax.(+39)-0587-705153 WEB: http://www.classx.it <
"Yves YANG" <yves.yang@soyatec.com> ha scritto nel messaggio
news:fo5u8t$8tv$1@build.eclipse.org...
> Hi All,
> Here is the build I made for Eclipse 3.3 with the bugfix of
> GridBagConstraint:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=203542
> The build is available here for Windows:
> http://www.soyatec.org/update/org.eclipse.ve_1.3.0.200802040 250.zip
> It depends on emf-sdo-xsd-SDK-2.3.0.zip and GEF-ALL-3.3.1.zip. You need
> to install them first. Please keep in mind, it is not official build. You
> use
> it at your risk. Any report are welcome.
> Best regards
> Yves YANG
> http://www.soyatec.com
Re: Build VE for Eclipse 3.3 [message #616983 is a reply to message #143913] |
Mon, 10 March 2008 04:38  |
Re: Build VE for Eclipse 3.3 [message #616984 is a reply to message #143969] |
Mon, 10 March 2008 05:25  |
Hi David,
Mik
Re: Build VE for Eclipse 3.3 [message #616988 is a reply to message #143978] |
contribute it.
best regards
Yves YANG
> Hi David,
> Cheers,
> Mik
FUDForum. Page generated in 0.06114 seconds
