Home » Eclipse Projects » Eclipse Platform » Embedded web application
Embedded web application [message #143634] Tue, 14 October 2003 10:14 Go to next message
Originally posted by: Eric.Jain.isb-sib.ch
I'm trying to embed a web application within an existing plug-in. Currently,
I simply have a bunch of static HTML files in a "web" subdirectory within
the plug-in. In MyPlugin.startup() I do the following:
String id = getDescriptor().getUniqueIdentifier():
Path path = new Path("web");
WebappManager.start("test", id, path);
log.debug("Port: " + WebappManager.getPort());
When I then point a browser to http://localhost:xyz/test/, I get: "The
document that you have requested is not available."
If I change the path to http://localhost:xyz/help/, the same message
appears, initially. Only after opening the help from within Eclipse at least
once does the help application load correctly. I therefore assume I am
missing one step in order to activate my own web application, but what?
Eric Jain
Re: Embedded web application [message #143669 is a reply to message #143634] Tue, 14 October 2003 10:55 Go to previous messageGo to next message
What you did is enough, and works for me. Check the .log. There might be
something else that has a side effect as you describe.
Konrad Kolosowski
"Eric Jain" <Eric.Jain@isb-sib.ch> wrote in message
news:bmh0ap$ifk$1@eclipse.org...
Currently,
least
> Eric Jain
Re: Embedded web application [message #143678 is a reply to message #143634] Tue, 14 October 2003 11:00 Go to previous messageGo to next message
Currently,
least
Was your plugin active when you browsed the page? Your plugin's startup()
method should run in order to register the webapp.
-Dorian
> Eric Jain
Re: Embedded web application [message #143922 is a reply to message #143678] Tue, 14 October 2003 12:28 Go to previous messageGo to next message
> startup() method should run in order to register the webapp.
Definitely, I print out the port number in the startup method. Without that
I wouldn't even know where to point the browser to.
Eric Jain
Re: Embedded web application [message #143974 is a reply to message #143669] Tue, 14 October 2003 13:15 Go to previous message
> might be something else that has a side effect as you describe.
The problem turned out to be that I was trying to put the web application
root into a sub directory within the plug-in. The following works:
String id = getDescriptor().getUniqueIdentifier();
WebappManager.start("test", id, new Path(""));
Eric Jain
Previous Topic:How to pipe into the status line?
Next Topic:how to split edit view
Current Time: Sat Nov 08 02:05:47 EST 2025
Powered by FUDForum. Page generated in 0.32764 seconds
