Home » Archived » Visual Editor (VE) » Invisible Text?
Invisible Text? [message #143938] Fri, 07 March 2008 10:05 Go to next message
Originally posted by: frickson.gibbon.com
I just installed eclipse 3.2 (eclipse-platform-3.2-linux-gtk.tar.gz) on
two servers. On one (OpenSUSE 10.2), everything seems to be working fine.
On the other one (SUSE Linux Enterprise Server 10.1), most of the text is
invisible in the editor. After some experimenting, I discovered that any
text following a tab character is invisible. If I use spaces instead of
tabs, it works fine.
I tried changing fonts, sizes, colors, tab size, but nothing helps. The
sample text in "Preferences / C/C++ / Editor / Syntax" is also mostly
invisible.
Any ideas?
Re: Invisible Text? [message #143945 is a reply to message #143938] Fri, 07 March 2008 10:35 Go to previous message
That would have nothing to with the VE. That would be a difference in
the UI Widget implementation provided by the two OS's. The VE doesn't do
anything special with respect to tabs.
It may be some interaction between the two two OS's UI system and
Eclipse, in which case it would be an Eclipse topic instead. Especially
if where the error is occurring (as in your example) is with the
Preferences dialog. So in that case the better place to ask this is
eclipse.platform newsgroup and not the VE forum.
> fine. On the other one (SUSE Linux Enterprise Server 10.1), most of the
> text is invisible in the editor. After some experimenting, I discovered
> that any text following a tab character is invisible. If I use spaces
> instead of tabs, it works fine.
> invisible.
> Any ideas?
Rich Kulp
Re: Invisible Text? [message #616980 is a reply to message #143938] Fri, 07 March 2008 10:35 Go to previous message
> invisible.
> Any ideas?
Rich Kulp
Previous Topic:Invisible Text?
Next Topic:Group Layout Support for VE
Current Time: Wed Nov 05 02:03:12 EST 2025
Powered by FUDForum. Page generated in 0.03696 seconds
