VE not being showed suddenly [message #143852] |
Tue, 12 February 2008 10:06  |
Originally posted by: antoneti.gmail.com
I managed to install VE in my eclipse Europa (3.3.1.1) through some of
the mails sent to here time ago, and actually I didn't use it then but
now I want to use it and suddenly the Visual Editor option doesn't
appear, I suppose some automatic upgrade of some libraries make that
fail (or something similar since I haven't done anything).
The thing is that I started eclipse with -debug option, in the screen
nothing strange appears but in the .log file there is this error:
!ENTRY org.eclipse.osgi 2 0 2008-02-12 14:07:24.328
!MESSAGE While loading class
" org.eclipse.gmf.runtime.common.ui.util.UIModificationValidat or$WindowListener ",
thread "Thread[main,6,main]" timed out waiting (5000ms) for thread
"Thread[Worker-1,5,main]" to finish starting bundle
"update@plugins /org.eclipse.gmf.runtime.common.ui_1.0.101.v20070921-0000.ja r
[510]". To avoid deadlock, thread "Thread[main,6,main]" is proceeding
but
may not be fully initialized.
!STACK 0
org.osgi.framework.BundleException: State change in progress for bundle
"update@plugins /org.eclipse.gmf.runtime.common.ui_1.0.101.v20070921-0000.ja r "
by thread "Worker-1".
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.begi nStateChange(AbstractBundle.java:1141)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:258)
at
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:408)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at
org.eclipse.gmf.runtime.common.ui.util.UIModificationValidat or$1.run(UIModificationValidator.java:115)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3659)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3296)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
Caused by:
org.eclipse.osgi.framework.internal.core.AbstractBundle$Bund leStatusException
... 38 more
Root exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
to be honest I don't know what that means, could any of you help me?
Antonio
Re: VE not being showed suddenly [message #143857 is a reply to message #143852] |
Tue, 12 February 2008 10:41  |
I managed to show that up again by using the patch Yves YANG creates.
Antonio
Antonio escribió:
> of the mails sent to here time ago, and actually I didn't use it then
> but now I want to use it and suddenly the Visual Editor option doesn't
> screen nothing strange appears but in the .log file there is this error:
> but
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by:
> ... 38 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Antonio
Re: VE not being showed suddenly [message #616969 is a reply to message #143852] |
Antonio
Antonio escribió:
> but
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by:
> ... 38 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Antonio
FUDForum. Page generated in 0.05133 seconds
