Home » Modeling » GMF (Graphical Modeling Framework) » Updating the Model File reference in Diagram FIle
Updating the Model File reference in Diagram FIle [message #143696] Tue, 24 July 2007 04:52 Go to next message
Originally posted by: vlalan.csc.com
Hi All,
I want to implement the Save As functionality for a Diagram File.
The procedure I am following is:
1. Create a new Diagram File having the same contents as the old one.
2. Create a new Model File having the same contents as the old one.
3. Traverse the newly created Diagram File and update the references of
old model file with new model file.
The problem I am facing is that when I save the Diagram in the same
folder, everything is running fine but when I save the Diagram in another
folder it gives me error in step 3.
The code that handles this is:
final Resource diagramResource =
editingDomain.getResourceSet().getResource(newDiagramFileUri , true);
GMFResource gmfResource = (GMFResource) diagramResource;
final DiagramImpl diagram = (DiagramImpl) gmfResource.getContents().get(0);
try {
editingDomain.getCommandStack().execute(
new RecordingCommand(editingDomain) {
protected void doExecute() {
diagram.setName(dupDiagramFile.getName());
diagram.getElement().eResource().setURI(newModelFileUri);
<<<<......recursily traverse the diagram and setURI at each node>>>
Further debugging let to the conclusion that when we save the new Diagram
File in same folder the last line diagram.getElement().eResource() works
fine as it finds the old model file present in this folder.
However when we save the Diagram in a new Folder the same line
diagram.getElement().eResource() gives a NullPointerException as there is
no old model file here.
Please help if anyone has come across the same issue.
Also please suggest any other way to update the model reference if any.
Thanks in Advance,
Vipul
Re: Updating the Model File reference in Diagram FIle [message #143697 is a reply to message #143696] Tue, 24 July 2007 04:57 Go to previous message
Originally posted by: philippeweber57.yahoo.fr
Hi Vipul,
here is the code that I used to duplicate a model and its diagram within
UML2Tools, as it is a GMF-based tool, you could reuse the same
principle. The trick is to load the 2 files in the same ResourceSet and
use a CrossReferenceAdapter to handle the changes for you.
The xxxHelper classes are only an help to load and save the file
UMLResourceHelper umlResourceHelper = new UMLResourceHelper();
DiagramResourceHelper diagramResourceHelper = new DiagramResourceHelper();
Diagram diagram =
diagramResourceHelper.loadUMLClassDiagram(inputDiagramURI);
ResourceSet resourceSet = diagram.eResource().getResourceSet();
Model inputModel =
umlResourceHelper.loadUMLModel(inputModelURI,resourceSet);
//Initialize CrossReference Adapter to resolve references in diagram
CrossReferenceAdapter.getCrossReferenceAdapter(resourceSet);
umlResourceHelper.saveUMLModel(inputModel, outputModelURI);
//Save Diagram
try {
Resource resource = diagram.eResource();
resource.setURI(outputDiagramURI);
resource.save(Collections.EMPTY_MAP);
} catch (IOException e) {
e.printStackTrace();
Hope it helps
Philippe
Vipul wrote:
> Hi All,
> another folder it gives me error in step 3.
> try {
> Diagram File in same folder the last line
> diagram.getElement().eResource() works fine as it finds the old model
> is no old model file here.
> Thanks in Advance,
> Vipul
Previous Topic:Request for a complete Taipan zip file
Next Topic:Registration of Editparts as listeners for handleNotificationEvent
Current Time: Fri Oct 10 14:55:10 EDT 2025
Powered by FUDForum. Page generated in 0.22397 seconds
