Home » Archived » BIRT » Who knows about data sources?
Who knows about data sources? [message #143538] Mon, 13 March 2006 12:00 Go to next message
Originally posted by: J.Porter.1.warwick.ac.uk
If I have a CSV/XML data source, can I define it the path to that file at
run time?
If so, how?
Jeff
Re: Who knows about data sources? [message #143592 is a reply to message #143538] Mon, 13 March 2006 13:35 Go to previous messageGo to next message
Soultion:
Cheat a little.
Read the xxxx.rptdesign file from the the classpath,
replace the XML code that says...
<property name="HOME">c:\\TEMP</property>
with
<property name="HOME">c:\\MY_NEW_PATH</property>
Then pass it into the engine like this...
IReportRunnable design =
engine.openReportDesign(designFileInputStreamThatIveHackedIn to);
"Jeff Porter" <J.Porter.1@warwick.ac.uk> wrote in message
news:dv48ld$rte$1@utils.eclipse.org...
> run time?
> If so, how?
> Thanks
> Jeff
Re: Who knows about data sources? [message #143605 is a reply to message #143538] Mon, 13 March 2006 14:04 Go to previous message
You can use either Property Binding or Scripting to define a runtime path.
Search this newsgroup for examples; there has been numerous posts on this
topic.
regards,
Gary Xue
Actuate Corporation - Product Development
BIRT Committer
> run time?
> If so, how?
> Thanks
> Jeff
Previous Topic:Carriage return in data?
Next Topic:Regarding the Integration of Birt into Web Application
Current Time: Fri Jul 18 23:52:12 EDT 2025
Powered by FUDForum. Page generated in 0.37336 seconds
