Home » Eclipse Projects » e(fx)clipse » Using tags as class selectors
Using tags as class selectors [message #1435355] Wed, 01 October 2014 07:27 Go to next message
According to the RCP book, the CSS engine should be able to recognize user-defined tags in the application model and treat them as class-selectors.
However, when I tag all my Parts with "teststyle" and set up my css-file like this :
.teststyle
	-fx-background-color: red ;
nothing happens. Wat does work, are predefined tags, like the following :
.MPart
Do I have to do something different for referring to this user-defined tags ... ?
Little subsidiary question : on the main page of the Efxclips-project, there's a mention about LESS-support. I've done a search on the wiki, but found no additionnal information about this feature. I tried some LESS-syntax in the CSS-editor but without success. So my question is : what does the LESS-support entail ?
Re: Using tags as class selectors [message #1435381 is a reply to message #1435355] Wed, 01 October 2014 08:17 Go to previous messageGo to next message
On 01.10.14 04:27, Thomas Elskens wrote:
> Hello,
> class-selectors.
yes
> like this :
> teststyle
Well your selector is wrong - a tag is a class selector ".teststyle" and
NOT a element selector "teststyle"
> MPart
> tags ... ?
We don't provide LESS support in the basic toolkit nor does the
CSS-Editor is understanding LESS.
What we have as part of http://efxclipse.bestsolution.at/ is LESS
support at runtime but this was more of an experiment - but this less
stuff does not integrate into e4 on FX.
Tom
Re: Using tags as class selectors [message #1435395 is a reply to message #1435381] Wed, 01 October 2014 08:35 Go to previous messageGo to next message
The quotation marks ">" shopped off my class-selector, but the dot is present in both .MPart and .teststyle (the dots are there in the original message)...
Thanks for the clarification on LESS, I was not really clear to me.
Re: Using tags as class selectors [message #1435420 is a reply to message #1435395] Wed, 01 October 2014 09:09 Go to previous messageGo to next message
Oh - now I remember what we did [1] - to avoid doing too much CSS
applying we are only applying tags who start with "efx_styleclass:"
because without that we'd put too much load on the CSS-Engine because
we'd apply styles whenever a none styling tag changes!
So please use the Tag: efx_styleclass:teststyle and to get a
CSS-Selector of .teststyle
Tom
[1]https://bugs.eclipse.org/bugs/show_bug.cgi?id=440434
On 01.10.14 05:35, Thomas Elskens wrote:
Re: Using tags as class selectors [message #1435431 is a reply to message #1435420] Wed, 01 October 2014 09:28 Go to previous messageGo to next message
.... and of course we should document it at the wiki.
Tom
> Tom
>> Hi,
Re: Using tags as class selectors [message #1436121 is a reply to message #1435431] Thu, 02 October 2014 08:39 Go to previous message
That works, thanks !
Writing (comprehensive) documentation is indeed quite a daunting task.
If my company decides to adopt the couple Eclipse RCP-JavaFX, we will most likely write some training manual about the subject. I could be useful for other beginners. To be continued...
Previous Topic:MAVEN artifacts
Next Topic:Occasionnaly getting error when closing efxclipse application
Current Time: Wed Jul 30 08:34:01 EDT 2025
Powered by FUDForum. Page generated in 0.06256 seconds
