Home » Eclipse Projects » Eclipse Platform » 3.0 M4 CVS broken commit?
3.0 M4 CVS broken commit? [message #143366] |
Mon, 13 October 2003 23:43  |
Hey all,
I was very excited to get M4. Lots of great new stuff, and hopefully fixes
for the M3 issues. But for some reason, when I set up my CVS now, I can't
commit. I see the new synchronize view, and it shows a bunch of issues.
Hell, I lost all my code on my local when I syncronized, luckilly the old
Eclipse locall history was still intact!! Anyway, I grab all the source,
make a few modifications, do a commit, and it keeps telling me error
Up-to-date check failed. How is this possible? I also do UPDATE, then
COMMIT, still no go! I can't make my changes stick. Help?!
Re: 3.0 M4 CVS broken commit? [message #143375 is a reply to message #143366] |
Mon, 13 October 2003 23:47   |
Found the problem. I think its a bug?? Problem is, I configured the new m4
feature to read using pserver, but write usin ext. When I do that, the
update/commit doesn't work. When I turned it back to using extssh for both
read and write, it worked. Is that a bug? I would think using pserver for
read only should be fine?
"Kevin" <supreme_java_guru_1@yahoo.com> wrote in message
news:bmfr34$e66$1@eclipse.org...
> Hey all,
Re: 3.0 M4 CVS broken commit? [message #143404 is a reply to message #143375] |
Tue, 14 October 2003 03:15   |
I think it's more than that. I got the same problem, but my read and write
proto is the same, and it's been working in M3 and previous.
In M4, when I checked in a new package, it left out some files not
checked in. And when I do a compare on the whole package with
the latest in CVS, it shows no difference! And there are 4 java files
left out, and no difference?
And the next day, I did a compare again (after I "accidentally" figured out
how to check in the left out, still don't know why!), it shows me every
file is different from the latest in CVS. I compare every file, and there's
not a single difference!
WTH!
The thing I like is that now, the long CVS commands (and most other
long commands) are handled in a background thread, and I can continue
working while Eclipse is working on those.
kk
Re: 3.0 M4 CVS broken commit? [message #143659 is a reply to message #143404] |
Tue, 14 October 2003 10:50   |
Ok, so I suppose we have to wat for M5...damn! Unless a nightly build fixes
this issue soon. Did you log a bug report? If not, can you log one
describing what you found. Sounds like you are more on top of it than I.
"kk" <kk@dev.null> wrote in message news:bmg7r8$nr4$1@eclipse.org...
m4
both
for
out
there's
> WTH!
> kk
Re: 3.0 M4 CVS broken commit? [message #144152 is a reply to message #143659] |
Tue, 14 October 2003 15:54  |
Originally posted by: Michael_Valenta.oti.com
This could be related to bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=44614. Was there anything
in the log file?
Michael
> m4
> both
> for
> out
> there's
>>WTH!
>>kk
Current Time: Sun Jul 27 03:31:00 EDT 2025
Powered by FUDForum. Page generated in 0.04238 seconds
