Home » Eclipse Projects » Sirius » Can't use IFML editor wizard(Failing to create the core model)
icon9.gif  Can't use IFML editor wizard [message #1431967] Fri, 26 September 2014 08:01 Go to next message
Thanks for all the good work, I can't wait to use IFML editor. I wanted to use Uwe but it looks quite more accurate.
I use Eclipse and jdk7 and the latest jre, virtual machine 1.8.0_11.
Eclipse Kepler service release 2 ; 2.0.2.20140224.
IFML editor 1.0.0.201408250121 looks installed.
To use IFML editor, I followed this (ifml.github.io/) until "Right click on models and select New -> Other -> Example EMF Model Creation Wizards -> Core Model"
When I start Core model, all goes wrong.
"Problem opening wizard :
The selected wizard could not be started."
Details :
Plug-in "IFMLEditor.editor" was unable to instantiate class "IFML.Core.presentation.CoreModelWizard".
Could not initialize class IFML.Core.CorePackage
Where can I find the core package and check it s here ?
Am I doing things the wrong way ? Is IFTML has-been ?
Bat
Re: Can't use IFML editor wizard [message #1433644 is a reply to message #1431967] Mon, 29 September 2014 00:19 Go to previous messageGo to next message
Got same problem here..
Solved using Eclipse Modeling Tools Luna Very Happy
https://www.eclipse.org/downloads/packages/eclipse-modeling-tools/lunar
your welcome
Re: Can't use IFML editor wizard [message #1433721 is a reply to message #1431967] Mon, 29 September 2014 03:09 Go to previous messageGo to next message
Hi Bat
Le 26/09/2014 14:01, Bat Galt a écrit :
> -> Core Model"
> Details :
It seems your issue comes from the IFML plugins and not directly for Sirius.
> Bat
You should try to contact the IFML-editor team [1] [2].
Maxime - Obeo
Need professional services for Sirius?
http://www.obeodesigner.com/sirius*
[1] https://github.com/ifml/ifml-editor
[2] https://github.com/jcabot
Re: Can't use IFML editor wizard [message #1530156 is a reply to message #1433721] Fri, 26 December 2014 13:43 Go to previous message
Hi Bat
Is this the same issue? https://github.com/ifml/ifml-editor/issues/16
If yes, please also comment on this ticket.
thanks
Previous Topic:Problem Initializing reference
Next Topic:How to disable drag/drop elements in a diagram
Current Time: Sat Jul 26 19:13:46 EDT 2025
Powered by FUDForum. Page generated in 0.04992 seconds
