| Profiler Panic [message #143103] | Thu, 09 July 2009 16:08  |  |
| Eclipse User  |  |  |  |  | Hi,
 I am using the below versions to profile a simple application but profiler
 hangs.
 Eclipse version: 3.5
 TPTP Runtime Version: 4.6
 I have also configured the runtime to use an external Agent
 Controller(v4.6.0).
 On launching eclipse with -debug option and profiling an application gives
 the following exception on console:
 java.net.SocketException: Socket is closed
 at java.net.Socket.getOutputStream(Unknown Source)
 at
 org.eclipse.tptp.platform.execution.client.core.internal.Con nectionImpl.sendMessage(ConnectionImpl.java:517)
 at
 org.eclipse.tptp.platform.execution.client.core.internal.Age ntController.sendCommand(AgentController.java:1203)
 at
 org.eclipse.tptp.platform.execution.client.agent.internal.Ag entImpl.sendCommand(AgentImpl.java:353)
 at
 org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.configureDataProcessor(TIDelegateHelper.java:8 42)
 at
 org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.attachToAgent(TIDelegateHelper.java:761)
 at
 org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.attachToAgent(TIDelegateHelper.java:676)
 at
 org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.access$7(TIDelegateHelper.java:674)
 at
 org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper$2.processLaunched(TIDelegateHelper.java:515)
 at
 org.eclipse.tptp.platform.execution.client.core.internal.Pro cessImpl.launchAC(ProcessImpl.java:701)
 at
 org.eclipse.tptp.platform.execution.client.core.internal.Pro cessImpl.launch(ProcessImpl.java:130)
 at
 org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.launchProcess(TIDelegateHelper.java:550)
 at
 org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.launch(TIDelegateHelper.java:348)
 at
 org.eclipse.tptp.platform.jvmti.client.internal.launcher.TIJ avaLauncherDelegate.launch(TIJavaLauncherDelegate.java:37)
 at
 org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.delegateInit(LauncherUtility.java:1164)
 at
 org.eclipse.tptp.trace.ui.provisional.launcher.PrimaryLaunch Delegate.run(PrimaryLaunchDelegate.java:195)
 at
 at
 at
 org.eclipse.tptp.platform.execution.client.core.internal.Pro cessImpl.run(ProcessImpl.java:872)
 While trying to resolve this issue, I had come across
 http://dev.eclipse.org/newslists/news.eclipse.tptp/msg07079. html
 and I see a similar behavior.
 Profiling a simple code from a newly created project in eclipse without a
 heavy library dependency works fine.
 However, when the same code is profiled from a project with a heavy(really
 heavy) dependency .. it fails !!!!. Once this happens the former also stop
 to work.
 Any suggestions ......
 Rahul
| Re: Profiler Panic [message #143340 is a reply to message #143103] | Wed, 22 July 2009 05:44  |  |
| Eclipse User  |  |  |  |  | Hi, Rahul, Can you provide with a simple test case to reproduce the problem you
 described?
 Chengrui Deng
 China Runtime Technologies Lab,
 SSG/SSD/MRTC, Intel
FUDForum. Page generated in 0.15604 seconds
