Error logging [message #1430358] |
Wed, 24 September 2014 05:40  |
(I use the old Acceleo2 engine, maybe this has some impact, but I guess
evaluation errors could be logged independently of the underlying engine)
I always thought that Sirius was too silent about invalid expressions at
runtime.
I now found out that if I import the .odesign plugin into the runtime
workspace, Sirius would create a marker on the relevant odesign object.
For now I never had done that import, because it gave me weird results
sometimes (Can't exactly remember), and also - this option will not be
feasible once the product is deployed.
So once I deploy my sirius application, theres no expression error
logging whatsoever by default. Is that really desirable? I am aware of
the logging extension point. The question is: Why does sirius itself not
provide a default extension that logs to the error log?
Felix
Re: Error logging [message #1430641 is a reply to message #1430358] |
Wed, 24 September 2014 11:46   |
Hi Felix,
In which case you would like Sirius log? It is possible that in some
cases the odesign interpretation is incorrect and nothing is logged. If
you have found some of these case, you can raise a bugzilla with
reproduction data and scenario.
Which logging extension point are you talking about?
Best Regards.
Le 24/09/2014 11:40, Felix Dorner a écrit :
> runtime.
> Felix
Esteban Dugueperoux - Obeo
Need professional services for Sirius?
Re: Error logging [message #1430667 is a reply to message #1430641] |
Wed, 24 September 2014 12:27  |
On 24/09/2014 17:46, Esteban Dugueperoux wrote:
> Hi Felix,
It is org.eclipse.sirius.runtimeLogger. It's being consumed in
RuntimeLoggerManager.
FUDForum. Page generated in 0.07111 seconds
