Home » Modeling » EMF » [EMF Transaction] EObject removed from ResourceSet has always TransactionChangeRecorder as Adapter
[EMF Transaction] EObject removed from ResourceSet has always TransactionChangeRecorder as Adapter [message #1430266] Wed, 24 September 2014 03:36 Go to next message
Hi EMF Community,
I expected to find a CDO bug [1], but after a little analysis this
doesn't seems a CDO bug. Indeed If I add a EObject to a ResourceSet and
this addition is rollback, i.e. removed from the ResourceSet, this
EObject has always the TransactionChangeRecorder as Adapter.
Consequently if I modify this EObject without EMF Command I get the
following exception :
Caused by: java.lang.IllegalStateException: Cannot modify resource set
without a write transaction
at
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.assertWriting(TransactionChangeRecorder.java:348)
at
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.appendNotification(TransactionChangeRecorder.java:302)
at
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.processObjectNotification(TransactionChangeRecorder.java:284)
at
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.notifyChanged(TransactionChangeRecorder.java:240)
at
org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at
org.eclipse.emf.ecore.impl.EStructuralFeatureImpl$InternalSettingDelegateSingleData.dynamicSet(EStructuralFeatureImpl.java:2237)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicSet(BasicEObjectImpl.java:1127)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjectImpl.java:1101)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjectImpl.java:1071)
at
org.eclipse.emf.cdo.tests.model1.impl.CategoryImpl.setName(CategoryImpl.java:81)
at
org.eclipse.emf.cdo.tests.bugzilla.Bugzilla_444824_Test.testRollBackInCDO(Bugzilla_444824_Test.java:109)
According to this exception, EMF Transaction considers that the EObject
is yet contained in the ResourceSet while it is not the case.
Is the TransactionChangeRecorder should remove itself of a EObject
removed from ResourceSet?
Best Regards.
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=444824
Esteban Dugueperoux - Obeo
Need professional services for Sirius?
Re: [EMF Transaction] EObject removed from ResourceSet has always TransactionChangeRecorder as Adapt [message #1430333 is a reply to message #1430266] Wed, 24 September 2014 05:03 Go to previous messageGo to next message
Hi Esteban,
I think you're hit by something that's documented in EMF Transaction doc
under "Working with Transactional Editing Domains". Once an object
belongs to a TED, it will be in that TED until you detach it manually
with TransactionUtil.disconnectFromEditingDomain(). Now your case is
interesting, because the add() gets rolled back instantly, so maybe the
object should have never been part of the domain, or at least EMFT
should remove its adapters during the rollback?
Felix
Re: [EMF Transaction] EObject removed from ResourceSet has always TransactionChangeRecorder as Adapt [message #1430546 is a reply to message #1430333] Wed, 24 September 2014 09:49 Go to previous messageGo to next message
Hi, Felix, Esteban,
It's an interesting case, the rollback of the first attachment of a new
EObject. However, I'm not sure that it's really so different from any
other case of detaching an element from the content forest of a
resource set.
It's clear that the intention of the transaction that was rolled back
was to add this new EObject into the context of the particular editing
domain. It would be strange, then, for the application in question to
try to use that EObject in any other domain. Why would it? Other
domains would work with their own copies of all the resources and
objects involved.
I wouldn't recommend trying to make the editing domain treat this case
of detachment from the resource set differently from other cases. An
object that is intended for manipulation in a TED should only be
manipulated in transactions on the TED, whether it is attached or not,
and even before it is attached and therefore before it has the change
recorder in the first place.
Hope that makes sense.
Christian
On 2014-09-24 09:03:56 +0000, Felix Dorner said:
> Hi Esteban,
> doc under "Working with Transactional Editing Domains". Once an object
> Felix
Re: [EMF Transaction] EObject removed from ResourceSet has always TransactionChangeRecorder as Adapt [message #1430637 is a reply to message #1430546] Wed, 24 September 2014 11:40 Go to previous message
Hi Felix, Christian,
Thanks for your answer.
Le 24/09/2014 15:49, Christian W. Damus a écrit :
> Hi, Felix, Esteban,
> other case of detaching an element from the content forest of a resource
> set.
> objects involved.
> Christian
>> Hi Esteban,
>> the object should have never been part of the domain, or at least EMFT
>> Felix
Previous Topic:Synchronize a diagram with a mode
Next Topic:Geting the CDO Resource using CDOResource URI
Current Time: Mon Jun 09 03:30:10 EDT 2025
Powered by FUDForum. Page generated in 0.03105 seconds
