Choose Bean [message #139387] |
Sun, 29 July 2007 01:27  |
Originally posted by: spac.quick.cz
I downloaded VE for Elipse 3.3 from Erik Hecht and "Choose Bean" button
doesnt work as before. After pressing I can place my visual classes into
object being edited. Is possible to make it working again?
Thank you.
Re: Choose Bean [message #139398 is a reply to message #139387] |
Sun, 29 July 2007 09:18   |
--------------070806080509070107060207
Content-Type: text/plain; charset=ISO-8859-2; format=flowed
Hello Petr,
i found the Bug, but I'm sorry I can't build a new Version within the
next 2 week. I have to do a lot of other things.
So please wait until the next Update.
Greetings
Erik
post scritpum:
I attached the patch to this posting.
Petr Podzimek schrieb:
> Thank you.
name="ChooseBeanSelector.txt"
Content-Disposition: inline;
filename="ChooseBeanSelector.txt"
### Eclipse Workspace Patch 1.0
#P org.eclipse.ve.java.core
Index: core/org/eclipse/ve/internal/java/choosebean/ChooseBeanSelec tor.java
RCS file: /cvsroot/tools/org.eclipse.ve.java.core/core/org/eclipse/ve/ internal/java/choosebean/ChooseBeanSelector.java,v
retrieving revision 1.13
diff -u -r1.13 ChooseBeanSelector.java
--- core/org/eclipse/ve/internal/java/choosebean/ChooseBeanSelec tor.java 2 Dec 2005 16:31:20 -0000 1.13
+++ core/org/eclipse/ve/internal/java/choosebean/ChooseBeanSelec tor.java 29 Jul 2007 13:15:07 -0000
@@ -26,7 +26,7 @@
public Object[] getNewObjectAndType(CreationTool creationTool, org.eclipse.gef.EditDomain domain) {
EditDomain ed = (EditDomain) domain;
- return ChooseBeanDialog.getChooseBeanResults(ed, null, null);
+ return ChooseBeanDialog.getChooseBeanResults(ed, null, "**");
--------------070806080509070107060207--
Re: Choose Bean [message #143035 is a reply to message #139442] |
Wed, 14 November 2007 07:16  |
Originally posted by: please.nospam.org
Is there a solution for this around. I have the same problem. Some
references can't be choosen from the combobox. After the selection the
choosen value disapears. No source code gets generated.
It would be great to have a solution for this.
Greetings,
Richard
Re: Choose Bean [message #616334 is a reply to message #139387] |
Hello Petr,
Greetings
Erik
post scritpum:
> Thank you.
@@ -26,7 +26,7 @@
Re: Choose Bean [message #616343 is a reply to message #139387] |
Tue, 31 July 2007 11:01  |
I noticed a problem with the combobox cell editor in eclipse 3.3 when I
try to select an existing object in the property sheet. Instead of
adding the code to set the selected object as a member, the property
returns to its original value. On the other hand, if I use the "Choose
Bean" selector to create a new member object, everything works fine.
Is anyone else experiencing this problem?
Kristof
Petr Podzimek schreef:
> Thank you.
Re: Choose Bean [message #616877 is a reply to message #139442] |
Greetings,
Richard
FUDForum. Page generated in 0.09748 seconds
