Creating Sirius Diagram - in headless plugin [message #1429506] |
Tue, 23 September 2014 06:20  |
Hi All,
I want to create Sirius diagram using headless eclipse plugin. I am able to create Sirius diagram programmatically from an eclipse plugin.
But when I am trying to create a diagram using headless eclipse plugin, I am facing issues. Could you please help me with this?
Please let me know if it is possible to create sirius diagram from normal java projects (instead of using plugin).
Request your help!
Re: Creating Sirius Diagram - in headless plugin [message #1429575 is a reply to message #1429539] |
Tue, 23 September 2014 08:19   |
Can you provide the plugin which execute this snippet?
It seems that your plugin have not enough sirius dependencies, for
example org.eclipse.sirius.diagram.ui plugin.
Best Regards.
Le 23/09/2014 13:18, VVasanth Kumar a écrit :
> By Headless - I mean 'Eclipse Headless Plugin' (please refer [1]).
> My requirement is - I will be generating my model through java (outside
> of Eclipse). Once generated, I will access the model in Eclipse. Now, I
> am trying to generate Sirius diagram directly (instead of generating
> model first and then creating diagram through Eclipse).
> Please find the snippet of my code below:
> prj.get().getMainRepresentationsFileURI(new
> NullProgressMonitor(), false, false);
> IProject project =
> ResourcesPlugin.getWorkspace().getRoot().getProject("TestSiriusHeadless");
> //My project name
> Session existingSession = null;
> try {
> project.open(new NullProgressMonitor());
> } catch (CoreException e) {
> // TODO Auto-generated catch block
> e.printStackTrace();
> final Option<ModelingProject> prj =
> ModelingProject
> .asModelingProject(project);
> if (prj.some()) {
> existingSession = prj.get().getSession();
> if (existingSession == null) {
> Option<org.eclipse.emf.common.util.URI> optionalMainSessionFileURI =
> prj.get()
> new
> if
> (optionalMainSessionFileURI.some()) {
> // Load the main
> representations file of this modeling
> // project if it's not
> already loaded or during loading.
> ModelingProjectManager.INSTANCE
> .loadAndOpenRepresentationsFile(optionalMainSessionFileURI
> .get());
> In the above snippet, I am getting following sequence of error while
> executing the statement 'final Option<ModelingProject> prj =
> ModelingProject.asModelingProject(project);'.
> Could you please help me in solving this issue?
> org.eclipse.core.runtime.CoreException: Plug-in
> org.eclipse.sirius.diagram.ui was unable to load class
> org.eclipse.sirius.diagram.ui.business.internal.migration.description.OptionalLayersVSMMigrationParticipant.
> at
> org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
> at
> org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:176)
> at
> org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
> at
> org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
> at
> org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
> at
> org.eclipse.sirius.business.internal.migration.AbstractSiriusMigrationService.loadContributions(AbstractSiriusMigrationService.java:72)
> at
> org.eclipse.sirius.business.internal.migration.description.VSMMigrationService.<init>(VSMMigrationService.java:27)
> at
> org.eclipse.sirius.business.internal.migration.description.VSMMigrationService.<clinit>(VSMMigrationService.java:24)
> at
> org.eclipse.sirius.viewpoint.description.util.DescriptionResourceFactoryImpl.createResource(DescriptionResourceFactoryImpl.java:63)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.createResource(ResourceSetImpl.java:434)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandCreateResource(ResourceSetImpl.java:243)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:400)
> at
> org.eclipse.sirius.business.api.componentization.ViewpointRegistryImpl.load(ViewpointRegistryImpl.java:603)
> at
> org.eclipse.sirius.business.api.componentization.ViewpointRegistryImpl.registerFromPlugin(ViewpointRegistryImpl.java:282)
> at defaultpackage.Activator.start(Activator.java:38)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
> at java.security.AccessController.doPrivileged(Native Method)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
> at
> org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:478)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:263)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:109)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:469)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:464)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:340)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1212)
> at
> org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
> at
> at
> at
> at
> org.eclipse.sirius.common.tools.api.util.EclipseUtil.getExtensionPlugins(EclipseUtil.java:137)
> at
> org.eclipse.sirius.common.tools.api.util.EclipseUtil.getExtensionPlugins(EclipseUtil.java:79)
> at
> org.eclipse.sirius.business.api.componentization.ViewpointRegistryImpl.initViewpointsFromPlugins(ViewpointRegistryImpl.java:615)
> at
> org.eclipse.sirius.business.api.componentization.ViewpointRegistryImpl.init(ViewpointRegistryImpl.java:153)
> at
> org.eclipse.sirius.viewpoint.SiriusPlugin.initPreferences(SiriusPlugin.java:173)
> at
> org.eclipse.sirius.viewpoint.SiriusPlugin.start(SiriusPlugin.java:154)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:461)
> at
> at
> at
> at com.cts.Sirius.SiriusTest.createDiagram(SiriusTest.java:233)
> at myheadlessplugin.Application.start(Application.java:18)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
> Caused by:
> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException:
> An error occurred while automatically activating bundle
> org.eclipse.sirius.diagram.ui (748).
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:124)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 76 more
> Caused by: org.osgi.framework.BundleException: The activator
> org.eclipse.sirius.diagram.ui.provider.DiagramUIPlugin$Implementation
> for bundle org.eclipse.sirius.diagram.ui is invalid
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:172)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:679)
> at
> at
> at
> at
> at
> ... 88 more
> Caused by: java.lang.NoClassDefFoundError:
> org/eclipse/sirius/viewpoint/provider/SiriusEditPlugin
> at
> org.eclipse.sirius.diagram.ui.provider.DiagramUIPlugin.<init>(DiagramUIPlugin.java:105)
> at
> org.eclipse.sirius.diagram.ui.provider.DiagramUIPlugin.<clinit>(DiagramUIPlugin.java:89)
> at
> org.eclipse.sirius.diagram.ui.provider.DiagramUIPlugin$Implementation.<init>(DiagramUIPlugin.java:163)
> at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native
> Method)
> at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown
> Source)
> at
> sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
> at java.lang.reflect.Constructor.newInstance(Unknown Source)
> at java.lang.Class.newInstance(Unknown Source)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:167)
> ... 94 more
> Caused by:
> org.eclipse.sirius.ui (774).
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 103 more
> Caused by: org.osgi.framework.BundleException: Exception in
> org.eclipse.sirius.viewpoint.provider.SiriusEditPlugin$Implementation.start()
> of bundle org.eclipse.sirius.ui.
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
> at
> at
> at
> at
> at
> at
> ... 112 more
> Caused by: java.lang.IllegalStateException: Workbench has not been
> created yet.
> at org.eclipse.ui.PlatformUI.getWorkbench(PlatformUI.java:93)
> at
> org.eclipse.sirius.viewpoint.provider.SiriusEditPlugin$Implementation.start(SiriusEditPlugin.java:214)
> at
> at
> ... 118 more
> !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2014-09-23 08:17:08.707
> !MESSAGE Plug-in org.eclipse.sirius.diagram.ui was unable to load class
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 88 more
> at
> at
> at
> Method)
> Source)
> at
> at
> ... 94 more
> Caused by:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 103 more
> at
> at
> at
> at
> at
> at
> at
> ... 112 more
> created yet.
> at
> at
> at
> ... 118 more
> !ENTRY org.eclipse.sirius 2 0 2014-09-23 08:17:08.823
> !MESSAGE Cannot instanciate migration contribution
> !STACK 1
> org.eclipse.sirius.diagram.ui.business.internal.migration.DiagramSplitMigrationParticipant.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 76 more
> at
> at
> at
> at
> at
> at
> at
> ... 88 more
> at
> at
> at
> Method)
> Source)
> at
> at
> ... 94 more
> Caused by:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 103 more
> at
> at
> at
> at
> at
> at
> at
> ... 112 more
> created yet.
> at
> at
> at
> ... 118 more
> !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2014-09-23 08:17:08.915
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.se
Re: Creating Sirius Diagram - in headless plugin [message #1430440 is a reply to message #1430362] |
Wed, 24 September 2014 07:28  |
Thanks Cedric...
Could you pls let me know when this feature will be available?
I am assuming even in standalone mode we cannot create and export a sirius diagram. Request you to correct me if I am wrong. If it is possible via standalone mode, kindly point me to the right resource.
Thanks!
FUDForum. Page generated in 0.11434 seconds
