Home » Eclipse Projects » Sirius » Creation of element based edge
Creation of element based edge [message #1429449] Tue, 23 September 2014 04:42 Go to next message
This is my second topic in this forum and I hope that the answers to my problem will be as much helpful as the first time Razz
I'm trying to create a Diagram representation, containing Containers and Edges.
All the containers and the contained bordered nodes are well displayed, but not the edges which are too numerous Mad
As my metamodel use an ecore association class, I assumed to use an Element based edge.
Sirius creates too much edges between the nodes!!
AssociationClass---------->Source
|_______________> Target
The problem is that several instances of the AssociationClass are referencing the same source AND target, but only one instance of AssociationClass is referenced.
That's why I've got multiple edges!
What should I do to limit the number of edges?
I'm sorry about the confused explanion, and I'll try to extract an example from my project to make it clearer Rolling Eyes
Miguel
Re: Creation of element based edge [message #1429498 is a reply to message #1429449] Tue, 23 September 2014 06:01 Go to previous messageGo to next message
Hi Miguel,
I don't know your metamodel, but if you want edges for AssocationClass
only if this last is referenced, you can have a "Semantic Candidates
Expression" which filter unwanted AssociationClass or yet the
"Precondition" available in the Advanced tab.
Best Regards.
Le 23/09/2014 10:42, Miguel Dalcampo a écrit :
> Hello,
> problem will be as much helpful as the first time :p
> Edges.
> but not the edges which are too numerous :x
> Element based edge.
> example from my project to make it clearer :roll:
> Regards,
> Miguel
Esteban Dugueperoux - Obeo
Need professional services for Sirius?
Re: Creation of element based edge [message #1429559 is a reply to message #1429498] Tue, 23 September 2014 07:57 Go to previous message
Hi Esteban,
That's probably the key of the problem.
I've got a class 'A' that reference the AssociationClass 'B'.
The associationClass 'AssoClass' reference two class 'B' and 'C'.
A
v
AssoClass-------->B
v
C
There are two types of containers:
- the first one 'C1' is issued from 'C'.
- the second one 'C2' is issued from 'A' and contains nodes with information from 'C'. I add also nodes which displays the address of the referenced AssociationClass elements.
In the label the edge I display the adress of the AssociationClass element.
The edge are created even if the AssociationClass element is not in 'C2'!
The addresses does not match, but the edges are created.
Miguel
Previous Topic:Optimize performances on big models
Next Topic:Creating Sirius Diagram - in headless plugin
Current Time: Sun Jul 27 14:03:55 EDT 2025
Powered by FUDForum. Page generated in 0.03063 seconds
