Home » Newcomers » Newcomers » XMLGregorianCalendar error Eclipse Luna(WebService Interface Not Compiling because of Error described Below- Help )
XMLGregorianCalendar error Eclipse Luna [message #1429421] Tue, 23 September 2014 03:55 Go to next message
I am getting the following error after generating the java code after wsimport.
Error
Abstract class javax.xml.datatype.XMLGregorianCalendar cannot be used as a runtime class because it is not extended by a non abstract class
which is suitable as a runtime class
I am using dateTime as argument to one method,
This is the service interface method.
public List<Weather> getForecast(
@WebParam(name = "arg0", targetNamespace = "xyzdotcom/")
XMLGregorianCalendar arg0,
@WebParam(name = "arg1", targetNamespace = "xyzdotcom/")
int arg1)
throws Exception_Exception
Because of the error the code is not compiling. Is this a bug or some thing i am missing. I am using Websphere Application Server runtime and "IBM Webshere JAX WS" as WebService Runtime. It actually should have been pretty simple.
The following is the commented first line of the generated code
Generated By:JAX-WS RI IBM 2.2.1-11/28/2011
Being a newcomer apologies if i am on a wrong place and will be helpful if anyone can guide to the correct forum
Re: XMLGregorianCalendar error Eclipse Luna [message #1429832 is a reply to message #1429421] Tue, 23 September 2014 16:29 Go to previous message
Khajan Joshi wrote on Tue, 23 September 2014 10:55
Error
int arg1)
This is a Java question. An abstract class is a template for a class and it cannot be used directly. See the discussion at <http://stackoverflow.com/questions/835889/java-util-date-to-xmlgregoriancalendar>.
Previous Topic:Disable line wrapping for all text files?
Next Topic:using eclipse for Pro*C
Current Time: Wed Jul 23 21:40:53 EDT 2025
Powered by FUDForum. Page generated in 0.09587 seconds
