Home » Newcomers » Newcomers » Eclipse + svn/subclipse + apache dir structure
Eclipse + svn/subclipse + apache dir structure [message #142892] Tue, 14 March 2006 05:22 Go to next message
Originally posted by: chrisg.paper-river.com
We've got a few java projects submitted to svn which have dependancies on
each other. These projects are built in an apache directory structure with
src/build/resources/dist folders and an ant build file at the root.
If I checkout the whole trunk of the svn, which includes all the projects
into Eclipse, then the ant scripts run fine, and projects can compile etc.
However, none of the projects seem to be registered as Java projects, and
therefore none of the editing tools work such as code completion, the '.'
notation to access methods etc, or finding the declarations of objects etc.
After doing some searching, i checked out each project individually into the
workspace, and i checked them out as Java projects. This also allowed me to
set the src and build paths to the correct ones in the file structure.
This now allows me to edit them like normal java projects using standard ide
tools.
However, I now dont have the common ant build file in the root folder, which
is referenced by each of the projects, therefore ant doesnt work.
Has anyone been able to set up eclipse with this kind of file structure, but
still treat each individual project folder as a java project?
I guess what i need is to be able to have "sub-projects" under a main
'trunk' project.
Any help is appreciated!!
Chris
Re: Eclipse + svn/subclipse + apache dir structure [message #142912 is a reply to message #142892] Tue, 14 March 2006 05:49 Go to previous messageGo to next message
Originally posted by: mynewsgroup.web.de
Chris Gates schrieb:
Did you check in the .project and .classpath files to the root folder of
each subproject as well? Subclipse is aware of this file an configures
the nature and the buildpath of a project automatically when checking it
out.
Your projects do not have the Java nature.
Is your repository structure like this:
....myproject/trunk/
subproject1/src/...
subproject2/src/...
and with a build.xml, .project and .classpath in each subprojectX folder?
Do you checkout the single trunk folder (...myproject/trunk) or each
project-folder that is in the trunk-folder? I think you have to do the
latter because Subclipse assumes .project to be in the top-level folder
that is checked out. So you need to select .../subproject1,
..../subproject2 (a multi selection is possible) for checkout instead of
only trunk. Then a Java project is created for each checked out folder
and given the name from .project and the buildpath from .classpath.
Sebastian
Re: Eclipse + svn/subclipse + apache dir structure [message #142930 is a reply to message #142912] Tue, 14 March 2006 07:24 Go to previous messageGo to next message
"Sebastian Scheid" <mynewsgroup@web.de> wrote in message
news:dv677o$nu$1@utils.eclipse.org...
>> Hi,
>> with
> each subproject as well? Subclipse is aware of this file an configures the
> nature and the buildpath of a project automatically when checking it out.
>> etc.
>> etc.
> ...myproject/trunk/
> subproject1/src/...
> subproject2/src/...
Yes.
> only trunk. Then a Java project is created for each checked out folder and
Initially i was trying to checkout the single trunk folder. Doing it this
way allows all the build files to work correctly.
I then tried checking out each project folder. After setting up the
libraries, this lets me edit the code like normal, and eclipse can build the
files and everything, but the ant build files no longer work. I beleive that
this is because they are missing the common build file that is located in
the trunk folder, and so therefore has now not been checked out. I cannot
check this out into the workspace to be at the root of the projects, like it
is when checking out the whole of the trunk Is there anyway of adding this
common build file, or is the only course of action to edit each of the
project build files to incorporate the elements of the common one?
Chris
> Regards
> Sebastian
Re: Eclipse + svn/subclipse + apache dir structure [message #142940 is a reply to message #142930] Tue, 14 March 2006 08:17 Go to previous messageGo to next message
Perhaps it helps to check out the trunk so you have only one eclipse
project containing the subprojects and then define the subprojects src
folders as Source Folders (right-click subproject/src folder->Build
Path->Use as Source Folder). This only works if the checked out project
(from trunk) has the Java nature. If your trunk does not contain a
..project file, you have to checkout with the New Project Wizard and
create a Java project.
After you have configured your build path and included all subprojects
src folders, you can checkin .project and .classpath to the trunk so you
don't need to do that work again and can share your project settings.
Sebastian
Re: Eclipse + svn/subclipse + apache dir structure [message #142950 is a reply to message #142940] Tue, 14 March 2006 09:17 Go to previous message
> .project file, you have to checkout with the New Project Wizard and create
> a Java project.
> After you have configured your build path and included all subprojects src
> folders, you can checkin .project and .classpath to the trunk so you don't
> Regards
> Sebastian
That did the job - setting the individual src folders was exactly what i
needed to know.
Thanks very much for all your help.
Chris
Previous Topic:Key word or preserved word
Next Topic:can't execute an applet that's inside a package
Current Time: Sat Jul 12 22:17:03 EDT 2025
Powered by FUDForum. Page generated in 0.30790 seconds
