How to inherit a project from another in a different setup file [message #1428982] |
Mon, 22 September 2014 12:32  |
My use case:
I want to provide a public .setup file and a private one. The private one will inherits everything from the public one and also add references to some internal resources (such as Sonar, CI builds).
I tried to specify the "Logical Project Container" but not action from the container has been executed.
is it something supported? If yes, how can I handle it?
Re: How to inherit a project from another in a different setup file [message #1428998 is a reply to message #1428982] |
Mon, 22 September 2014 12:58   |
Aurelien,
Comments below.
On 22/09/2014 6:32 PM, Aurelien Pupier wrote:
> My use case:
What specifically will it inherit?
> builds).
What do you mean specifically by "adding references"?
That's only used in the outline preview. At runtime, the project must
be contained somewhere.
I'm wondering if it's actually necessary to contain the private project
in the public project. I.e., what does that buy you verses having two
separate projects and simply specifying a stream from each? (That's
what we've been doing.)
No, it's not...
I'm wondering why you actually need it. (I imagine this is primarily
an issue of sharing variables, but I could be missing the point.)
> Regards,
Re: How to inherit a project from another in a different setup file [message #1429012 is a reply to message #1428998] |
Mon, 22 September 2014 13:29   |
Hi Ed,
thanks for your very fast answers!
> My use case:
It will inherits everything which is not related to our internal Sonar instance and Jira. So same working sets, same projects, same Preferences, all P2 directors from the public one.
Ok I understand, you simply ask to install two projects.
My idea was to provide a single one for the company developers too.
Effectively if we need to share variables it might an issue. Currently, I don't have this use case.
So currently, the only thing is that it would be easier for my company developers if they a single project instead of two to import. Anyway, I think that we can live without it.
Regards and thanks again for your answers
Re: How to inherit a project from another in a different setup file [message #1429023 is a reply to message #1429012] |
Mon, 22 September 2014 13:44  |
Aurelien,
Comments below.
On 22/09/2014 7:29 PM, Aurelien Pupier wrote:
> Hi Ed,
>> My use case:
Well, if you choose the stream for your public project, you will get all
those. None of these are a reason why another project would needs to be
contained...
> project in the public project. I.e., what does that buy you verses
> having two separate projects and simply specifying a stream from each?
Exactly. Ease of selection I supposed, but the project page remembers
your last selection so that's not a big win...
> (That's what we've been doing.)
Yep.
That would be the strongest concern...
One thing I've considered is creating dependencies between streams so
you can basically specify "if this stream is selected, this other stream
should also be selected automatically", but it's all complicated enough
already that we'd need stronger use cases...
You're welcome.
FUDForum. Page generated in 0.03966 seconds
