Home » Modeling » EMF » [CDO] MySQL database is broken after restart of CDO server
icon5.gif  [CDO] MySQL database is broken after restart of CDO server [message #1415199] Tue, 02 September 2014 05:46 Go to next message
We have a problem with the CDO server connecting to a MySQL database. The first startup which creates the tables is ok. But sometimes after a shutdown and a restart the CDO server detects a crash of the repository and reports the exitcode 10000. Here is the log output:
[INFO] CDO server stopping
[INFO] Net4j extension stopping
[INFO] Net4j extension stopped
[INFO] Security extension stopping
[INFO] Security extension stopped
[INFO] CDO server stopped
Start VM: /usr/bin/java
-Xms40m
-Xmx2G
-Dnet4j.config=/opt/cdo-server/config
-Dorg.eclipse.emf.cdo.server.browser.port=7777
-Dorg.osgi.service.http.port=8080
-Dosgi.console.enable.builtin=true
-Ddebug=true
-jar /opt/cdo-server/plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar
-os linux
-ws gtk
-arch x86_64
-showsplash
-launcher /opt/cdo-server/cdo-server
-name Cdo-server
--launcher.library /opt/cdo-server/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.200.v20140116-2212/eclipse_1508.so
-startup /opt/cdo-server/plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar
--launcher.overrideVmargs
-exitdata 10000
-debug
-console 5555
-vm /usr/bin/java
-vmargs
-Xms40m
-Xmx2G
-Ddebug=true
Install location:
    file:/opt/cdo-server/
Configuration file:
    file:/opt/cdo-server/configuration/config.ini loaded
Configuration location:
Framework located:
    file:/opt/cdo-server/plugins/org.eclipse.osgi_3.9.1.v20140110-1610.jar
Framework classpath:
Splash location:
    null
Debug options:
    file:/opt/cdo-server/.options not found
Listening on port 0.0.0.0/0.0.0.0:5555 ...
Time to load bundles: 53
Starting application: 1830
[INFO] CDO server starting
[WARN] Detected crash of repository yt_repo
[ERROR] com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Table 'cdo_repo.cdo_objects' doesn't exist
org.eclipse.net4j.db.DBException: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Table 'cdo_repo.cdo_objects' doesn't exist
        at org.eclipse.emf.cdo.server.internal.db.DBStore.visitAllTables(DBStore.java:288)
        at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontalMappingStrategy.getMinLocalID(AbstractHorizontalMappingStrategy.java:467)
        at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontalMappingStrategy.repairAfterCrash(AbstractHorizontalMappingStrategy.java:105)
        at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalMappingStrategy.repairAfterCrash(HorizontalMappingStrategy.java:204)
        at org.eclipse.emf.cdo.server.internal.db.DBStore.repairAfterCrash(DBStore.java:778)
        at org.eclipse.emf.cdo.server.internal.db.DBStore.reStart(DBStore.java:760)
        at org.eclipse.emf.cdo.server.internal.db.DBStore.doActivate(DBStore.java:653)
        at org.eclipse.net4j.util.lifecycle.Lifecycle.internalActivate(Lifecycle.java:76)
        at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycle.java:162)
        at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:114)
        at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:104)
        at org.eclipse.emf.cdo.internal.server.Repository.doActivate(Repository.java:1980)
        at org.eclipse.net4j.util.lifecycle.ShareableLifecycle.internalActivate(ShareableLifecycle.java:43)
        at org.eclipse.emf.cdo.server.CDOServerUtil.addRepository(CDOServerUtil.java:291)
        at org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.configure(RepositoryConfigurator.java:116)
        at org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplication.doStart(CDOServerApplication.java:61)
        at org.eclipse.net4j.util.om.OSGiApplication.start(OSGiApplication.java:63)
        at org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(AnyThreadAppLauncher.java:26)
        at java.lang.Thread.run(Thread.java:745)
Caused by: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Table 'cdo_repo.cdo_objects' doesn't exist
        at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
        at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
        at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
        at java.lang.reflect.Constructor.newInstance(Constructor.java:526)
        at com.mysql.jdbc.Util.handleNewInstance(Util.java:406)
        at com.mysql.jdbc.Util.getInstance(Util.java:381)
        at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:1051)
        at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3563)
        at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3495)
        at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1959)
        at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2113)
        at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2687)
        at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2616)
        at com.mysql.jdbc.StatementImpl.executeQuery(StatementImpl.java:1464)
        at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontalMappingStrategy$1.visitTable(AbstractHorizontalMappingStrategy.java:477)
        at org.eclipse.emf.cdo.server.internal.db.DBStore.visitAllTables(DBStore.java:272)
        ... 23 more
-Xms40m
-Xmx2G
-Ddebug=true
-os linux
-ws gtk
-arch x86_64
-showsplash
-name Cdo-server
-exitdata 0
-debug
-console 5555
-vm /usr/bin/java
-vmargs
-Xms40m
-Xmx2G
-Ddebug=true
Re: [CDO] MySQL database is broken after restart of CDO server [message #1415204 is a reply to message #1415199] Tue, 02 September 2014 06:01 Go to previous messageGo to next message
Hi Stefan,
How exactly are you shutting your server down?
Cheers
/Eike
http://www.esc-net.de
Am 02.09.2014 um 11:46 schrieb Stefan Weise:
> -Xms40m
> -Xmx2G
> -Ddebug=true
> -os linux
> -ws gtk
> -arch x86_64
> -showsplash
> -name Cdo-server
> --launcher.library
> -exitdata 10000
> -debug
> -console 5555
> -vm /usr/bin/java
> -vmargs
> -Xms40m
> -Xmx2G
> -Ddebug=true
> -jar /opt/cdo-server/plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar Install location:
> Configuration file:
> Framework located:
> Splash location:
> null
> Debug options:
> Listening on port 0.0.0.0/0.0.0.0:5555 ... Time to load bundles: 53
> at
> at
> at
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> ... 23 more
> -Xms40m
> -Xmx2G
> -Ddebug=true
> -os linux
> -ws gtk
> -arch x86_64
> -showsplash
> -name Cdo-server
> --launcher.library
> -exitdata 0
> -debug
> -console 5555
> -vm /usr/bin/java
> -vmargs
> -Xms40m
> -Xmx2G
> -Ddebug=true
Re: [CDO] MySQL database is broken after restart of CDO server [message #1415207 is a reply to message #1415204] Tue, 02 September 2014 06:10 Go to previous messageGo to next message
Hi Eike,
since we are on Linux we are using a script to start and stop the server. To shut the server down we are using telnet with the following command
stop() {
   echo -n "Shutting down $DAEMON"
   { echo "shutdown"; echo "close"; } | telnet localhost 5555
   echo $!
This works when we call it manually. But when we restart the server this will fail with the described message.
Stefan
Re: [CDO] MySQL database is broken after restart of CDO server [message #1415210 is a reply to message #1415207] Tue, 02 September 2014 06:18 Go to previous messageGo to next message
Am 02.09.2014 um 12:10 schrieb Stefan Weise:
> Hi Eike,
> stop() {
I think only "close" would be good.
Cheers
/Eike
Re: [CDO] MySQL database is broken after restart of CDO server [message #1415215 is a reply to message #1415210] Tue, 02 September 2014 06:29 Go to previous messageGo to next message
Same result. Seems to be a timing problem when the system goes down. Perhaps the database server is already down before CDO can close the connection.
But why is CDO unable to repair the database tables? When I use an embedded derby instead this works.
Stefan
Re: [CDO] MySQL database is broken after restart of CDO server [message #1415235 is a reply to message #1415215] Tue, 02 September 2014 07:32 Go to previous messageGo to next message
Am 02.09.2014 um 12:29 schrieb Stefan Weise:
I guess that's generally possible.
A missing table is a severe problem that shouldn't happen in the first place. Are you sure your connection is transactional?
Cheers
/Eike
Re: [CDO] MySQL database is broken after restart of CDO server [message #1415254 is a reply to message #1415235] Tue, 02 September 2014 08:20 Go to previous messageGo to next message
Eike Stepper wrote on Tue, 02 September 2014 11:32
Yes, that was the reason. The database was already down but the CDO server wasn't.
We just have an empty database at the moment. So I don't know if this could be the reason. But here is our current cdo-server configuration:
<cdoServer>
  <!-- See http://wiki.eclipse.org/CDO/Server_Configuration_Reference -->
  <acceptor type="tcp" listenAddr="0.0.0.0" port="2036"/>
  <repository name="yt_repo">
    <property name="overrideUUID" value=""/>
    <property name="supportingAudits" value="true"/>
    <property name="supportingBranches" value="true"/>
    <property name="ensureReferentialIntegrity" value="false"/>
    <property name="allowInterruptRunningQueries" value="true"/>
    <property name="idGenerationLocation" value="STORE"/> <!-- Possible values: STORE | CLIENT -->
    <property name="serializeCommits" value="false"/>
    <property name="optimisticLockingTimeout" value="10000"/>
    <store type="db">
      <!-- Period at which to execute an SQL statement to keep DB connection alive, in minutes -->
      <property name="connectionKeepAlivePeriod" value="60"/>
      <!-- Maximum number of store accessors (JDBC connections) to keep in the reader pool. The default value is 15.  -->
      <property name="readerPoolCapacity" value="20"/>
      <!-- Maximum number of store accessors (JDBC connections) to keep in the writer pool. The default value is 15.  -->
      <property name="writerPoolCapacity" value="20"/>
      <mappingStrategy type="horizontal"> <!-- callout -->
        <property name="qualifiedNames" value="true"/>
      </mappingStrategy>
      <dbAdapter name="mysql"/>
      <dataSource class="com.mysql.jdbc.jdbc2.optional.MysqlDataSource"
        url="jdbc:mysql://localhost/yt_repo?createDatabaseIfNotExist=true"
        user="cdo-user"
        password="cdo-password"
    </store>
  </repository>
</cdoServer>
~Stefan
Re: [CDO] MySQL database is broken after restart of CDO server [message #1424717 is a reply to message #1415254] Tue, 16 September 2014 06:14 Go to previous messageGo to next message
Update:
The problem occurs when the MYSQL database is running on Linux because here the file system is case sensitive. Each table within a database corresponds to at least one file within the database directory. See http://dev.mysql.com/doc/refman/5.7/en/identifier-case-sensitivity.html for more information about that.
The CDO server seems to use different spellings for the creation and the access of the tables even after a unclean restart of the database server. These are the table names in the database after setting up the database:
| Tables_in_cdo_repo                     |
| CDO_BRANCHES                           |
| CDO_COMMIT_INFOS                       |
| CDO_EXTERNAL_REFS                      |
| CDO_LOBS                               |
| CDO_LOCKS                              |
| CDO_LOCK_AREAS                         |
| CDO_OBJECTS                            |
| CDO_PACKAGE_INFOS                      |
| CDO_PACKAGE_UNITS                      |
| CDO_PROPERTIES                         |
| ERESOURCE_CDOBINARYRESOURCE            |
| ERESOURCE_CDORESOURCE                  |
| ERESOURCE_CDORESOURCEFOLDER            |
| ERESOURCE_CDORESOURCEFOLDER_NODES_LIST |
| ERESOURCE_CDORESOURCE_CONTENTS_LIST    |
| ERESOURCE_CDOTEXTRESOURCE              |
But after an unclean restart of the CDO server I get the following exception:
Now the server wants to access the table 'cdo_repo.cdo_objects' which does not exist in the database. But 'cdo_repo.CDO_OBJECTS' does exist.
mysql> select * from cdo_objects;
ERROR 1146 (42S02): Table 'cdo_repo.cdo_objects' doesn't exist
mysql> select * from CDO_OBJECTS;
| CDO_ID | CDO_CLASS | CDO_CREATED   |
|      1 |        -5 | 1410862129468 |
1 row in set (0.00 sec)
Do you have an idea where this different spelling comes from and how we can avoid it?
Stefan
Re: [CDO] MySQL database is broken after restart of CDO server [message #1424789 is a reply to message #1424717] Tue, 16 September 2014 08:23 Go to previous messageGo to next message
On 16-09-14 12:14, Stefan Weise wrote:
> Update:
> database:
> | CDO_BRANCHES |
> | CDO_COMMIT_INFOS |
> | CDO_EXTERNAL_REFS |
> | CDO_LOBS |
> | CDO_LOCKS |
> | CDO_LOCK_AREAS |
> | CDO_OBJECTS |
> | CDO_PACKAGE_INFOS |
> | CDO_PACKAGE_UNITS |
> | CDO_PROPERTIES |
> exception:
> at
> can avoid it?
Hi, This sounds very much like a problem we have as well.
We also have Linux and MySQL. We have done extensive troubleshooting and
found the issue. (But still need a patch).
The bug is in the class DBNamedElement, this method.
public static String name(String name)
return name.toUpperCase().intern();
The CDO Bug report is this one:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=412520
The bug was introduced somewhere in March 2013. (Judging from the GIT
logs). where this bug is very active:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=401763
> Regards,
> Stefan
Re: [CDO] MySQL database is broken after restart of CDO server [message #1424816 is a reply to message #1424789] Tue, 16 September 2014 09:03 Go to previous messageGo to next message
Hi.
Thank you for sharing this information. I've already voted for this bug Cool
The problem only seems to occur in maintenance mode when the database is getting upgraded or repaired. During normal operation this error does not appear.
~Stefan
Christophe Bouhier wrote on Tue, 16 September 2014 12:23
[Updated on: Tue, 16 September 2014 09:03] by Moderator
Re: [CDO] MySQL database is broken after restart of CDO server [message #1424842 is a reply to message #1424816] Tue, 16 September 2014 09:47 Go to previous messageGo to next message
On 16-09-14 15:03, Stefan Weise wrote:
> Hi.
> Thank you for sharing this information. I've already voted for this bug 8)
> not appear.
Yes, we noticed a relation with a CDO schema migration. (Which can not
be skipped).
> ~Stefan
>> and found the issue. (But still need a patch).
Re: [CDO] MySQL database is broken after restart of CDO server [message #1428856 is a reply to message #1424816] Mon, 22 September 2014 09:06 Go to previous message
> Hi.
@Eike, I can provide a patch, which simply removes, toUpperCase(), which
will likely fix the problem. Is this OK?
> not appear.
> ~Stefan
Previous Topic:EMF Databinding for CheckboxTableViewer.checkedElements
Next Topic:[EMF/CDO] - Exact meaning of 'Resolve Proxies'
Current Time: Thu Jul 24 23:03:27 EDT 2025
Powered by FUDForum. Page generated in 0.53811 seconds
