Home » Eclipse Projects » NatTable » Make NaTable row non editable based on particular cell value.(NatTable row needs to be made non editable,)
Make NaTable row non editable based on particular cell value. [message #1428653] Mon, 22 September 2014 02:14 Go to next message
Based on particular value input from the user ,need to make the entire NatTable row
non editable.
Captured the user input and applied the NON EDITABLE label to the column as follows:
public void setDataValue(int columnIndex, int rowIndex,Object newValue) {
// TODO Auto-generated method stub
if(columnIndex==1 && newValue.toString().equalsIgnoreCase("no"))
configLabel = getConfigLabelsByPosition(columnIndex, rowIndex);
crossValidationAcc.accumulateConfigLabels(configLabel, columnIndex, rowIndex);[/i][/font]
super.setDataValue(columnIndex, rowIndex, newValue);
After applying the lable to the columnindex and rowindex need to configure the registry,Need to understand which class I need to overide to be able to apply the configuration to the NatTable ,to make the row non editable.
Re: Make NaTable row non editable based on particular cell value. [message #1428819 is a reply to message #1428653] Mon, 22 September 2014 07:53 Go to previous message
Hi Amruta,
Try adding the following configuration to your table:
		natTable.addConfiguration(new AbstractRegistryConfiguration() {
			public void configureRegistry(IConfigRegistry configRegistry) {
				configRegistry.registerConfigAttribute(
						EditConfigAttributes.CELL_EDITABLE_RULE,
						IEditableRule.NEVER_EDITABLE,
						DisplayMode.EDIT,
						<your label for non-editable cells>);
Hope it helps.
Previous Topic:getCellByPosition() returning a null datavalue
Next Topic:Sample NAT table project
Current Time: Mon Jul 28 17:41:26 EDT 2025
Powered by FUDForum. Page generated in 0.03929 seconds
