Home » Archived » Visual Editor (VE) » How to Convert a java file to "IType" ?
How to Convert a java file to "IType" ? [message #142775] Wed, 07 November 2007 03:12 Go to next message
Originally posted by: lgw198412.gmail.com
Hi:
I'm confusing in the following problems:
There's a java file ,I can use Java I/O Stream to read it into a String
Objecet.But I want to analyze it to know the methods and fields in this java
file ,just like the Java Refelction Mechanism. And I found that in eclipse
there's an type called "IType" could do this thing,but I
don't know how to establish such an IType object and set the data(String
object) to it.Please help me ,or give me some other suggestions to this
subject!
Thank you!
robbin
from China
Re: How to Convert a java file to "IType" ? [message #142786 is a reply to message #142775] Wed, 07 November 2007 19:15 Go to previous messageGo to next message
This question is about JDT. You need know JDT and Eclipse. The main path is
to get IProject and convert it to IJavaProject by
JavaCore.getCore.createProject(IProject). And then you can use the method
findType() of IJavaProject.
Yves YANG
http://www.soyatec.com/eface
"robbin" <lgw198412@gmail.com> wrote in message
news:fgrs0o$86i$1@build.eclipse.org...
> Hi:
> java file ,just like the Java Refelction Mechanism. And I found that in
> eclipse there's an type called "IType" could do this thing,but I
> subject!
> Thank you!
> robbin
> from China
Re: How to Convert a java file to "IType" ? [message #142813 is a reply to message #142786] Wed, 07 November 2007 21:55 Go to previous messageGo to next message
I don't know how to create a IProject ,as I know there's one way to create
it :
IProject project =
ResourcesPlugin.getWorkspace().getRoot().getProject("stupid ");
IJavaProject javaProject = JavaCore.create(project);But there's a new
problem ,my java file is only a java file ,not in any Eclipse Project.So
what should I do?Thank you!"Yves YANG" <yves.yang@soyatec.com> wrote in
message news:fgtkfn$hk0$1@build.eclipse.org...
> is to get IProject and convert it to IJavaProject by
> Regards
> Yves YANG
>> Hi:
>> subject!
>> Thank you!
>> robbin
>> from China
Re: How to Convert a java file to "IType" ? [message #142823 is a reply to message #142813] Thu, 08 November 2007 04:08 Go to previous messageGo to next message
If the file is not in workspace, in general, AFAIK, you cannot use IType.
Best regards
Yves YANG
news:fgttqa$sto$1@build.eclipse.org...
>it :
> IProject project =
>> Regards
>> Yves YANG
>>> Hi:
>>> String Objecet.But I want to analyze it to know the methods and fields
>>> in this java file ,just like the Java Refelction Mechanism. And I found
>>> that in eclipse there's an type called "IType" could do this thing,but I
>>> subject!
>>> Thank you!
>>> robbin
>>> from China
Re: How to Convert a java file to "IType" ? [message #142833 is a reply to message #142823] Thu, 08 November 2007 05:23 Go to previous messageGo to next message
Thank You Very Much!
"Yves YANG" <yves.yang@soyatec.com> wrote in message
news:fgujlh$hhn$1@build.eclipse.org...
> Best regards
> Yves YANG
>>it :
>> IProject project =
>>> method findType() of IJavaProject.
>>> Regards
>>> Yves YANG
>>>> Hi:
>>>> I
>>>> data(String object) to it.Please help me ,or give me some other
>>>> suggestions to this subject!
>>>> Thank you!
>>>> robbin
>>>> from China
Re: How to Convert a java file to "IType" ? [message #142843 is a reply to message #142823] Thu, 08 November 2007 05:53 Go to previous messageGo to next message
Another problem:
Now I've Known your means , and I used the follwoing way to get an IProject
Object
IProject project =
But I don't know how to convert a java file under this Project("stupid") to
an IFile type, Is the following right?
IFile ifile = project.getFile("xxxx .java")
Thank you !
> Best regards
> Yves YANG
>>it :
>> IProject project =
>>> Regards
>>> Yves YANG
>>>> Hi:
>>>> I
>>>> Thank you!
>>>> robbin
>>>> from China
Re: How to Convert a java file to "IType" ? [message #142853 is a reply to message #142843] Thu, 08 November 2007 08:17 Go to previous messageGo to next message
Robbin,
Yes, but beware that this is a file handle object so you might find that
project.getFile("xxx.java").exists() is false. Keep in mind that you
might want to use project.getFile(new Path("src/com/example/xxx.java"))
instead and that you still need to check for exists. The findMember
methods will return null if the member doesn't exist, but in that case
you have to determine wither it's a file or a folder.
robbin wrote:
> Another problem:
> IProject Object
> IProject project =
> Project("stupid") to an IFile type, Is the following right?
> Thank you !
>> IType.
>> Best regards
>> Yves YANG
>>> create it :
>>> IProject project =
>>> new problem ,my java file is only a java file ,not in any Eclipse
>>> Project.So what should I do?Thank you!"Yves YANG"
>>>> path is to get IProject and convert it to IJavaProject by
>>>> Regards
>>>> Yves YANG
>>>>> Hi:
>>>>> fields in this java file ,just like the Java Refelction Mechanism.
>>>>> And I found that in eclipse there's an type called "IType" could
>>>>> do this thing,but I
>>>>> Thank you!
>>>>> robbin
>>>>> from China
Re: How to Convert a java file to "IType" ? [message #142900 is a reply to message #142853] Fri, 09 November 2007 03:30 Go to previous messageGo to next message
Ed Merks:
Thanks for the last answer.
Now I want to get all the files under a project,because I want to use the
method "project.getFile(path)" to get a IFile Type.
So how to get the path?(
Assume that I don't know any files under the current project ,but I want to
use method to get all the files and its full path like
"src/.../.../xxx.java")
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:fgv291$ar$1@build.eclipse.org...
> Robbin,
> robbin wrote:
>> Another problem:
>> IProject Object
>> IProject project =
>> Thank you !
>>> IType.
>>> Best regards
>>> Yves YANG
>>>> create it :
>>>> IProject project =
>>>>> Regards
>>>>> Yves YANG
>>>>>> Hi:
>>>>>> do this thing,but I
>>>>>> Thank you!
>>>>>> robbin
>>>>>> from China
Re: How to Convert a java file to "IType" ? [message #142954 is a reply to message #142900] Fri, 09 November 2007 07:20 Go to previous messageGo to next message
--------------090509050601010401000305
Content-Type: text/plain; charset=ISO-2022-JP
Robbin,
Here's an answer to a different question I posted in the platform newsgroup:
You can use ResourcesPlugin.getWorkspace().getRoot() to get the root
IContainer for the whole workspace. You could use
IWorkspaceRoot.getProjects(), to get all the projects, which are
also IContainers. And generally you can use IContainer.members(), to
recursively walk the tree. Given an IResource, you can use getType
to figure out what kind it is. You can use
IResource.accept(IResourceVisitor,...) to visit resources.
robbin wrote:
> Ed Merks:
> the method "project.getFile(path)" to get a IFile Type.
> want to use method to get all the files and its full path like
>> Robbin,
>> robbin wrote:
>>> Another problem:
>>> IProject Object
>>> IProject project =
>>> Thank you !
>>>> IType.
>>>> Best regards
>>>> Yves YANG
>>>>> create it :
>>>>> IProject project =
>>>>>> Regards
>>>>>> Yves YANG
>>>>>>> Hi:
>>>>>>> do this thing,but I
>>>>>>> Thank you!
>>>>>>> robbin
>>>>>>> from China
Content-Type: text/html; charset=ISO-2022-JP
<html>
<head>
<meta content="text/html;charset=ISO-2022-JP"
http-equiv="Content-Type">
</head>
Robbin,<br>
<br>
newsgroup:<br>
<blockquote>You can use ResourcesPlugin.getWorkspace().getRoot() to get
the root IContainer for the whole workspace.&nbsp; You could use
IWorkspaceRoot.getProjects(), to get all the projects, which are also
recursively walk the tree.&nbsp; Given an IResource, you can use getType to
figure out what kind it is.&nbsp; You can use
<br>
</blockquote>
<br>
robbin wrote:
<blockquote cite="mid:fh15ql$jrj$1@build.eclipse.org" type="cite">Ed
Merks:
<br>
&nbsp;Thanks for the last answer.
<br>
&nbsp; Now I want to get all the files under a project,because I want to use
<br>
&nbsp; So how to get the path?(
<br>
<br>
<br>
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:fgv291$ar$1@build.eclipse.org">news:fgv291$ar$1@build.eclipse.org</a>...
<br>
<blockquote type="cite">Robbin,
<br>
<br>
that
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
robbin wrote:
<br>
<blockquote type="cite">Another problem:
<br>
<br>
IProject Object
<br>
IProject project =
<br>
<br>
<br>
<br>
<br>
Thank you !
<br>
<br>
"Yves YANG" <a class="moz-txt-link-rfc2396E" href="mailto:yves.yang@soyatec.com">&lt;yves.yang@soyatec.com&gt;</a> wrote in message
<br>
<a class="moz-txt-link-freetext" href="news:fgujlh$hhn$1@build.eclipse.org">news:fgujlh$hhn$1@build.eclipse.org</a>...
<br>
<blockquote type="cite">If the file is not in workspace, in
<br>
IType.
<br>
<br>
Best regards
<br>
Yves YANG
<br>
<br>
<a class="moz-txt-link-freetext" href="http://www.soyatec.com/eface">http://www.soyatec.com/eface</a>
<br>
<br>
"robbin" <a class="moz-txt-link-rfc2396E" href="mailto:lgw198412@gmail.com">&lt;lgw198412@gmail.com&gt;</a> wrote in message
<br>
<a class="moz-txt-link-freetext" href="news:fgttqa$sto$1@build.eclipse.org">news:fgttqa$sto$1@build.eclipse.org</a>...
<br>
<blockquote type="cite">I don't know how to create a IProject
<br>
create it :
<br>
IProject project =
<br>
<br>
<br>
<br>
<br>
<br>
<a class="moz-txt-link-freetext" href="news:fgtkfn$hk0$1@build.eclipse.org">news:fgtkfn$hk0$1@build.eclipse.org</a>...
<br>
<blockquote type="cite">This question is about JDT. You need
<br>
<br>
<br>
<br>
<br>
<br>
Yves YANG
<br>
<br>
<br>
<br>
<br>
<a class="moz-txt-link-freetext" href="news:fgrs0o$86i$1@build.eclipse.org">news:fgrs0o$86i$1@build.eclipse.org</a>...
<br>
<blockquote type="cite">Hi:
<br>
<br>
<br>
<br>
<br>
<br>
do this thing,but I
<br>
<br>
<br>
<br>
Thank you!
<br>
robbin
<br>
from China
<br>
</blockquote>
<br>
<br>
</blockquote>
<br>
</blockquote>
<br>
<br>
</blockquote>
<br>
</blockquote>
<br>
</blockquote>
<br>
</blockquote>
<br>
</body>
</html>
--------------090509050601010401000305--
Re: How to Convert a java file to "IType" ? [message #143004 is a reply to message #142954] Sun, 11 November 2007 08:35 Go to previous messageGo to next message
IResource[] resources = myProject.members();
for(int i =0;i<resources.length;i++){
if(resources[i].getType()==IResource.FOLDER){
IResourceProxyVisitor visitor = new IResourceProxyVisitor(){
public boolean visit( IResourceProxy proxy){
proxy.requestResource();
return true;
resources[i].accept(visitor,IResource.NONE);
My code is Above.
I don't know how to traversing the tree under the resources[i]?
news:fh1jb9$jqa$1@build.eclipse.org...
> Robbin,
> newsgroup:
> robbin wrote:
>> Ed Merks:
>>> Robbin,
>>> robbin wrote:
>>>> Another problem:
>>>> IProject Object
>>>> IProject project =
>>>> Thank you !
>>>>> IType.
>>>>> Best regards
>>>>> Yves YANG
>>>>>> create it :
>>>>>> IProject project =
>>>>>>> Regards
>>>>>>> Yves YANG
>>>>>>>> Hi:
>>>>>>>> do this thing,but I
>>>>>>>> Thank you!
>>>>>>>> robbin
>>>>>>>> from China
Re: How to Convert a java file to "IType" ? [message #143016 is a reply to message #143004] Sun, 11 November 2007 08:44 Go to previous message
Robbin,
Doesn't it strike you that IResource.NONE might well not be a good flag
to use? Don't you want to specify a flag for the type of resource you
want to visit?
I would suggest you ask general question on the platform or newcomers
newsgroup. I won't answer your non-VE questions on this newsgroup anymore.
> return true;
> My code is Above.
>> Robbin,
>> newsgroup:
>> robbin wrote:
>>> Ed Merks:
>>>> Robbin,
>>>> that
>>>> robbin wrote:
>>>>> Another problem:
>>>>> IProject Object
>>>>> IProject project =
>>>>> Thank you !
>>>>>> IType.
>>>>>> Best regards
>>>>>> Yves YANG
>>>>>>> create it :
>>>>>>> IProject project =
>>>>>>>> main
>>>>>>>> Regards
>>>>>>>> Yves YANG
>>>>>>>>> Hi:
>>>>>>>>> Mechanism.
>>>>>>>>> do this thing,but I
>>>>>>>>> Thank you!
>>>>>>>>> robbin
>>>>>>>>> from China
Re: How to Convert a java file to "IType" ? [message #616852 is a reply to message #142775] Wed, 07 November 2007 19:15 Go to previous message
Yves YANG
> Hi:
> subject!
> Thank you!
> robbin
> from China
Re: How to Convert a java file to "IType" ? [message #616855 is a reply to message #142786] Wed, 07 November 2007 21:55 Go to previous message
it :
IProject project =
> Regards
> Yves YANG
>> Hi:
>> subject!
>> Thank you!
>> robbin
>> from China
Re: How to Convert a java file to "IType" ? [message #616856 is a reply to message #142813] Thu, 08 November 2007 04:08 Go to previous message
Best regards
Yves YANG
>it :
> IProject project =
>> Regards
>> Yves YANG
>>> Hi:
>>> subject!
>>> Thank you!
>>> robbin
>>> from China
Re: How to Convert a java file to "IType" ? [message #616857 is a reply to message #142823] Thu, 08 November 2007 05:23 Go to previous message
> Best regards
> Yves YANG
>>it :
>> IProject project =
>>> Regards
>>> Yves YANG
>>>> Hi:
>>>> I
>>>> Thank you!
>>>> robbin
>>>> from China
Re: How to Convert a java file to "IType" ? [message #616858 is a reply to message #142823] Thu, 08 November 2007 05:53 Go to previous message
Another problem:
Object
IProject project =
Thank you !
> Best regards
> Yves YANG
>>it :
>> IProject project =
>>> Regards
>>> Yves YANG
>>>> Hi:
>>>> I
>>>> Thank you!
>>>> robbin
>>>> from China
Re: How to Convert a java file to "IType" ? [message #616859 is a reply to message #142843] Thu, 08 November 2007 08:17 Go to previous message
Robbin,
robbin wrote:
> Another problem:
> IProject Object
> IProject project =
> Thank you !
>> IType.
>> Best regards
>> Yves YANG
>>> create it :
>>> IProject project =
>>>> Regards
>>>> Yves YANG
>>>>> Hi:
>>>>> do this thing,but I
>>>>> Thank you!
>>>>> robbin
>>>>> from China
Re: How to Convert a java file to "IType" ? [message #616864 is a reply to message #142853] Fri, 09 November 2007 03:30 Go to previous message
Ed Merks:
> Robbin,
> robbin wrote:
>> Another problem:
>> IProject Object
>> IProject project =
>> Thank you !
>>> IType.
>>> Best regards
>>> Yves YANG
>>>> create it :
>>>> IProject project =
>>>>> Regards
>>>>> Yves YANG
>>>>>> Hi:
>>>>>> do this thing,but I
>>>>>> Thank you!
>>>>>> robbin
>>>>>> from China
Re: How to Convert a java file to "IType" ? [message #616869 is a reply to message #142900] Fri, 09 November 2007 07:20 Go to previous message
Robbin,
robbin wrote:
> Ed Merks:
>> Robbin,
>> robbin wrote:
>>> Another problem:
>>> IProject Object
>>> IProject project =
>>> Thank you !
>>>> IType.
>>>> Best regards
>>>> Yves YANG
>>>>> create it :
>>>>> IProject project =
>>>>>> Regards
>>>>>> Yves YANG
>>>>>>> Hi:
>>>>>>> do this thing,but I
>>>>>>> Thank you!
>>>>>>> robbin
>>>>>>> from China
<html>
<head>
</head>
Robbin,<br>
<br>
newsgroup:<br>
<br>
</blockquote>
<br>
Merks:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
that
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
robbin wrote:
<br>
<br>
<br>
IProject Object
<br>
IProject project =
<br>
<br>
<br>
<br>
<br>
Thank you !
<br>
<br>
<br>
<br>
<br>
IType.
<br>
<br>
Best regards
<br>
Yves YANG
<br>
<br>
<br>
<br>
<br>
<br>
<br>
create it :
<br>
IProject project =
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Yves YANG
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
do this thing,but I
<br>
<br>
<br>
<br>
Thank you!
<br>
robbin
<br>
from China
<br>
</blockquote>
<br>
<br>
</blockquote>
<br>
</blockquote>
<br>
<br>
</blockquote>
<br>
</blockquote>
<br>
</blockquote>
<br>
</blockquote>
<br>
</body>
</html>
Re: How to Convert a java file to "IType" ? [message #616874 is a reply to message #142954] Sun, 11 November 2007 08:35 Go to previous message
return true;
My code is Above.
> Robbin,
> newsgroup:
> robbin wrote:
>> Ed Merks:
>>> Robbin,
>>> robbin wrote:
>>>> Another problem:
>>>> IProject Object
>>>> IProject project =
>>>> Thank you !
>>>>> IType.
>>>>> Best regards
>>>>> Yves YANG
>>>>>> create it :
>>>>>> IProject project =
>>>>>>> Regards
>>>>>>> Yves YANG
>>>>>>>> Hi:
>>>>>>>> do this thing,but I
>>>>>>>> Thank you!
>>>>>>>> robbin
>>>>>>>> from China
Re: How to Convert a java file to "IType" ? [message #616875 is a reply to message #143004] Sun, 11 November 2007 08:44 Go to previous message
Robbin,
want to visit?
> return true;
> My code is Above.
>> Robbin,
>> newsgroup:
>> robbin wrote:
>>> Ed Merks:
>>>> Robbin,
>>>> that
>>>> robbin wrote:
>>>>> Another problem:
>>>>> IProject Object
>>>>> IProject project =
>>>>> Thank you !
>>>>>> IType.
>>>>>> Best regards
>>>>>> Yves YANG
>>>>>>> create it :
>>>>>>> IProject project =
>>>>>>>> main
>>>>>>>> Regards
>>>>>>>> Yves YANG
>>>>>>>>> Hi:
>>>>>>>>> Mechanism.
>>>>>>>>> do this thing,but I
>>>>>>>>> Thank you!
>>>>>>>>> robbin
>>>>>>>>> from China
Previous Topic:Open Source Software Research
Next Topic:Adding feature of control-lock
Current Time: Sat Jul 26 02:33:35 EDT 2025
Powered by FUDForum. Page generated in 0.07661 seconds
