Home » Language IDEs » C / C++ IDE (CDT) » Linking Error, possible makefile problem
Linking Error, possible makefile problem [message #142571] Mon, 04 April 2005 17:50 Go to next message
Originally posted by: janst_nwgs.freenet.de
Hello all,
in short, i am trying to compile an (Makefile) Managed C++ GTKmm hello
world app.
But i always get an strange linking error with the following message:
crt1.o(.text+0x18): In function `_start':
: undefined reference to `main'
OK, i know what that means, he cannot find my main function, which has
actually the correct signature and return val plus a nice definition :D
=> int main (int argc, char** argv)
I guess there must be some problem with the make file because an simple
g++ Main.cpp RndStat.cpp `pkg-config --cflags --libs gtk+-2.0`
`pkg-config gtkmm-2.4 --libs --cflags`
works without problems.
The directory structure is:
- Main.h
- Main.cpp
- RndStat.h
- RndStat.cpp
Anybody got an idea what the problem might be or how to solve it...
Thank you in advcance
jan
Re: Linking Error, possible makefile problem [message #142580 is a reply to message #142571] Mon, 04 April 2005 18:03 Go to previous messageGo to next message
Make sure that the file that contains the definition for the main
function is being linked in the executable. I'm not sure whether it
matters, but check that you're using g++ to link if you use it to
compile.
Greetings,
Javier Kohen <jkohen@users.sourceforge.net>
ICQ: blashyrkh #2361802
Jabber: jkohen@jabber.org
Re: Linking Error, possible makefile problem [message #142689 is a reply to message #142580] Tue, 05 April 2005 17:00 Go to previous messageGo to next message
Yes, and now the 1.000.000$ question:
Any ideas how to do that (in a Managed C++ Project:D )?
Greetings jan
Re: Linking Error, possible makefile problem [message #142699 is a reply to message #142689] Tue, 05 April 2005 17:23 Go to previous messageGo to next message
Hm... I guess that you have to be lucky, I only tried C Managed projects
(libraries and binaries) and they work here ;-)
Can you post the commands that are being run during linking and
compilation, to see whether there is an attempt to link this particular
object or not?
Re: Linking Error, possible makefile problem [message #142756 is a reply to message #142699] Wed, 06 April 2005 13:25 Go to previous messageGo to next message
> object or not?
Ok, i just wanted to wait until somone really wants to see it :D..
Here we go:
Main.h
Main.cpp
RndStat.cpp
RndStat.h
and as I said, a simple
"g++ Main.cpp RndStat.cpp `pkg-config --cflags --libs gtk+-2.0`
`pkg-config gtkmm-2.4 --libs --cflags` " is successful..
The makefile is at the bottom..
make -k all
Building file: ../Main.cpp
g++ -I/usr/include/gtk -I/usr/include/gtkmm-2.4 -O0 -g3 -Wall -DXTHREADS
-D_REENTRANT -DXUSE_MTSAFE_API -I/usr/include/gtk-2.0
-I/usr/lib/gtk-2.0/include -I/usr/X11R6/include -I/usr/include/atk-1.0
-I/usr/include/pango-1.0 -I/usr/include/freetype2
-I/usr/include/freetype2/config -I/usr/include/glib-2.0
-I/usr/lib/glib-2.0/include -Wl,--export-dynamic -lgtk-x11-2.0
-lgdk-x11-2.0 -latk-1.0 -lgdk_pixbuf-2.0 -lm -lpangoxft-1.0 -lpangox-1.0
-lpango-1.0 -lgobject-2.0 -lgmodule-2.0 -ldl -lglib-2.0 -DXTHREADS
-D_REENTRANT -DXUSE_MTSAFE_API -I/usr/include/gtkmm-2.4
-I/usr/lib/gtkmm-2.4/include -I/usr/include/glibmm-2.4
-I/usr/lib/glibmm-2.4/include -I/usr/include/gdkmm-2.4
-I/usr/lib/gdkmm-2.4/include -I/usr/include/pangomm-1.4
-I/usr/include/atkmm-1.6 -I/usr/include/gtk-2.0
-I/usr/include/sigc++-2.0 -I/usr/lib/sigc++-2.0/include
-I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include
-I/usr/lib/gtk-2.0/include -I/usr/X11R6/include -I/usr/include/pango-1.0
-I/usr/include/freetype2 -I/usr/include/freetype2/config
-I/usr/include/atk-1.0 -Wl,--export-dynamic -lgtkmm-2.4 -lgdkmm-2.4
-latkmm-1.6 -lgtk-x11-2.0 -lpangomm-1.4 -lglibmm-2.4 -lsigc-2.0
-lpango-1.0 -lgobject-2.0 -lgmodule-2.0 -ldl -lglib-2.0 -oMain.o ../Main.cpp
/tmp/ccisnknl.o(.text+0x1eb): In function `main':
.../Main.cpp:20: undefined reference to `RndStat::RndStat()'
/tmp/ccisnknl.o(.text+0x22b):../Main.cpp:25: undefined reference to
`RndStat::~RndStat()'
/tmp/ccisnknl.o(.text+0x267):../Main.cpp:25: undefined reference to
Building file: ../RndData.cpp
collect2: ld gab 1 als Ende-Status zurück
make: *** [Main.o] Fehler 1
-lpango-1.0 -lgobject-2.0 -lgmodule-2.0 -ldl -lglib-2.0 -oRndData.o
.../RndData.cpp
/usr/lib/gcc/i386-redhat-linux/3.4.2/../../../crt1.o(.text+0 x18): In
function `_start':
make: *** [RndData.o] Fehler 1
Building file: ../RndStat.cpp
-lpango-1.0 -lgobject-2.0 -lgmodule-2.0 -ldl -lglib-2.0 -oRndStat.o
.../RndStat.cpp
function `_start':
make: *** [RndStat.o] Fehler 1
make: Das Target »all« wurde wegen Fehlern nicht aktualisiert.
Build complete for project RndStat
# Automatically-generated file. Do not edit!
ROOT := ..
-include $(ROOT)/makefile.init
RM := rm -rf
# All of the sources participating in the build are defined here
-include sources.mk
-include $(SUBDIRS:%=%/subdir.mk)
-include objects.mk
-include $(DEPS)
-include $(ROOT)/makefile.defs
all: RndStat
RndStat: $(OBJS)
@echo 'Building target: $@'
g++ -L/home/jan/eclipse/workspace/RndStat -o $@ $(OBJS) $(USER_OBJS)
$(LIBS)
@echo 'Finished building: $@'
clean:
-$(RM) $(OBJS) $(DEPS) RndStat
..PHONY: all clean dependents
-include $(ROOT)/makefile.targets
Re: Linking Error, possible makefile problem [message #142764 is a reply to message #142756] Wed, 06 April 2005 13:44 Go to previous messageGo to next message
Hallo Jan,
> > object or not?
> make -k all
Your compiler settings are wrong. It's trying to generate a executable
called Main.o and not an intermediate object. You can tell because the
-c gcc switch is missing and because it's trying to link a lot of
libraries into a .o file.
I don't know how to fix it in your case with CDT, but I guess you have
to convince it to compile from .cpp to .o instead of doing a full link.
Greetings,
Re: Linking Error, possible makefile problem [message #142774 is a reply to message #142764] Wed, 06 April 2005 14:36 Go to previous message
Hello Javier,
thank you for this information. Due to I am new to gcc, make and gtkmm
at one time :D this really makes it easier..!
Jan
Previous Topic:PC environment variables
Next Topic:Java Developer Journal and Linux World Awards
Current Time: Tue Sep 16 21:35:40 EDT 2025
Powered by FUDForum. Page generated in 0.10486 seconds
