Home » Newcomers » Newcomers » Need help loading example app code
icon5.gif  Need help loading example app code [message #1427278] Fri, 19 September 2014 20:45 Go to next message
I found a small example of code for a GPS location app to use in Eclipse. Below is the URL of where the code is. I created a class and then pasted the code in there. I immediately got errors which you can see marked. I opened the error box for one which you can see in the screen shot attached.
Can someone tell me why I get these errors? How do I run the code from the web page? Thanks!!
Warren
GpsBasicsAndroidExample.java file
/***********  Create class and implements with LocationListener **************/
    public class GpsBasicsAndroidExample extends Activity implements LocationListener {
            private LocationManager locationManager;
            protected void onCreate(Bundle savedInstanceState) {
                super.onCreate(savedInstanceState);
                setContentView(R.layout.activity_gps_basics_android_example);
                /********** get Gps location service LocationManager object ***********/
                locationManager = (LocationManager) getSystemService(Context.LOCATION_SERVICE);
                /* CAL METHOD requestLocationUpdates */
                  // Parameters :
                  //   First(provider)    :  the name of the provider with which to register
                  //   Second(minTime)    :  the minimum time interval for notifications,
                  //                         in milliseconds. This field is only used as a hint
                  //                         to conserve power, and actual time between location
                  //                         updates may be greater or lesser than this value.
                  //   Third(minDistance) :  the minimum distance interval for notifications, in meters
                  //   Fourth(listener)   :  a {#link LocationListener} whose onLocationChanged(Location)
                  //                         method will be called for each location update
                locationManager.requestLocationUpdates( LocationManager.GPS_PROVIDER,
                        3000,   // 3 sec
                        10, this);
                /********* After registration onLocationChanged method  ********/
                /********* called periodically after each 3 sec ***********/
            /************* Called after each 3 sec **********/
            public void onLocationChanged(Location location) {
                String str = "Latitude: "+location.getLatitude()+"
Longitude: "+location.getLongitude();
                Toast.makeText(getBaseContext(), str, Toast.LENGTH_LONG).show();
            public void onProviderDisabled(String provider) {
                /******** Called when User off Gps *********/
                Toast.makeText(getBaseContext(), "Gps turned off ", Toast.LENGTH_LONG).show();
            public void onProviderEnabled(String provider) {
                /******** Called when User on Gps  *********/
                Toast.makeText(getBaseContext(), "Gps turned on ", Toast.LENGTH_LONG).show();
            public void onStatusChanged(String provider, int status, Bundle extras) {
                // TODO Auto-generated method stub
Explanation :
                requestLocationUpdates Method :
                    Registers the current activity to be notified periodically by the named provider. Periodically, the supplied LocationListener will be called with the current Location or with status updates.
                           Parameters :
                                  Second(minTime)    :  the minimum time interval for notifications, in milliseconds. This field is only used as a hint to conserve power, and actual time between location updates may be greater or lesser than this value.
                                    Fourth(listener)        :  a {#link LocationListener} whose onLocationChanged(Location) method will be called for each location update
                        onLocationChanged Method :
                                    Called after each 3 sec ( we have defined in requestLocationUpdates ).
                        onProviderDisabled Method :
                                   Called when User off Gps in phone setting.
                         onProviderEnabled Method :
                                    Called when User on Gps in phone setting
  • Attachment: Help1.png
    (Size: 180.78KB, Downloaded 154 times)
Re: Need help loading example app code [message #1427307 is a reply to message #1427278] Fri, 19 September 2014 21:51 Go to previous messageGo to next message
On 09/19/2014 06:45 PM, Warren Williams wrote:
> Hello,
Please ready sticky posts at top of forum.
Re: Need help loading example app code [message #1427353 is a reply to message #1427307] Fri, 19 September 2014 23:37 Go to previous messageGo to next message
The only sticky note about this is maybe posting in the ADT forum. But I wasn't sure if this is specific to that or what because this is my first time using Eclipse and did not know if this meant maybe a library is not set or something like that.
Warren
Re: Need help loading example app code [message #1427640 is a reply to message #1427353] Sat, 20 September 2014 10:36 Go to previous message
> Warren
Yeah, your illustration tells me that you're having trouble piecing
together this Android application.
First, if Activity is missing, it's something with how you have or
haven't integrated ADT libraries. I've done a bit of Android programming
(albeit long ago) and I know that this is a class you can't get around
dealing with no matter how simple or tiny your application is.
Second, the question of how to run the code from the web page is hard
for me to understand. You should be asking how to run the code from
Eclipse? Did you mean the code you took from the webpage and pasted into
Eclipse? Etc. However, the answer likely lies somewhere between whoever
is supporting the webpage example and folk in an ADT forum.
Lars Vogella probably has some great Android aids on his website
(http://www.vogella.com/tutorials/android.html) although they've changed
hugely since I used them over 4 years ago.
The point of the forum sticky posts isn't to be rude, but as you read,
we can't extend the breadth of Eclipse fora to cover frameworks that
consume Eclipse, that may change all the time, etc., but aren't from the
narrower Eclipse IDE community.
There are many examples of frameworks that are supported by Eclipse
fora; and many, like ADT, that aren't properly Eclipse. It's
understandably confusing.
Best of luck.
Previous Topic:Need help with my eclipse Juno IDE
Next Topic:Cannot "find" or run project downloaded from Github
Current Time: Sat Jul 19 01:43:57 EDT 2025
Powered by FUDForum. Page generated in 0.11768 seconds
