Task element, Simulation Property Tab, "blinking" problem [message #1421559] |
Thu, 11 September 2014 10:28  |
I am working in BPMN2Modeler, with Jbpm Runtime Extension, latest nighlty build for Kepler (2014-03-06).
I create a new Task, and open the "Simulation" property tab.
The "Task{0} Simulation Parameters" blinks, and input fields into the property tab lose focus when clicked, as if the section is continuously refreshed.
I click on "Task{0} Simulation Parameters", in order to close the section, and click again on it, in order to reopen the section.
Everything seems ok.
Now, if I try populating the "Cost per Time Unit" field, everything seems ok.
If I try modifying one of the other three fields, the misbehaving starts all over again:
label blinking, cannot keep focus on fields.
If I double click on the Task element, a pop-up appears. The pop-up seems to work correctly, provided the Simulation Property Tab is not opened also; otherwise, the two windows interfere.
I am able to open source code for JBPM plugin, recompile, and republish plugin, but I cannot figure out what to do to correct the bug.
Please help.
[Updated on: Thu, 11 September 2014 10:33] by Moderator
FUDForum. Page generated in 0.04731 seconds
