Home » Eclipse Projects » Eclipse Platform » How to Internationalize your Eclipse ?
How to Internationalize your Eclipse ? [message #140681] Tue, 07 October 2003 06:34 Go to next message
Originally posted by: jack98lau.hotmail.com
Hello all,
Does anyone know how to internationalize Eclipse ? Since I am trying to
input chinese in java editor, but don't know how to do it!
Thanks in advance!
Jack
Re: How to Internationalize your Eclipse ? [message #140972 is a reply to message #140681] Tue, 07 October 2003 12:41 Go to previous messageGo to next message
There's an article at www.eclipse.org.
HTH,
Thorsten
Re: How to Internationalize your Eclipse ? [message #142694 is a reply to message #140681] Sun, 12 October 2003 01:56 Go to previous message
Originally posted by: kk.dev.null
Jack wrote:
> Hello all,
Well, at least, tell us what OS you are running, which version of Eclipse,
etc.
Input chinese into the java editor is working fine. On Windows, just
activate
the chinese input method.
On Linux, you need chinput (miniChinput, or another input method), set your
locale to Chinese (you can use a shell script and put your settings in the
script and start Eclipse from there), and set your XMODIFIERS properly.
Everything should be working fine.
Note: Eclipse-Linux-GTK 3.0M3+ has broken keyboard, so if you use it
in Chinese locale, you will run into a nasty problem. Other versions are
working fine.
Previous Topic:Plugin update
Next Topic:In WizardDialog,is there a way to access the error label
Current Time: Tue Jul 22 23:00:59 EDT 2025
Powered by FUDForum. Page generated in 0.03583 seconds
