Home » Modeling » EMF » [EMF/CDO] - Exact meaning of 'Resolve Proxies'
[EMF/CDO] - Exact meaning of 'Resolve Proxies' [message #1426452] Thu, 18 September 2014 15:37 Go to next message
We have a EMF model, shared between various computers using CDO.
Up to now, the parameter 'Resolve Proxies" of all relations was set to 'True' (default value, when using Ecore Tool to design the model).
Now (model getting more complex, more users connected simultaneously), we observe from time to time error messages referring to an issue with a proxy ("List contains proxy elements").
I admit that I don't understand the meaning of this field 'Resolve Proxies'; I googled, and obviously, for a lot of people, the meaning seems to be so obvious, that I find nowhere a basic explanation of what this option does, and when (which kind of relation 1=>many, 0=>1, ...) it should be set to True or False ...
Could somebody please provide me with a hint or redirect me to a basic document 'Resolve Proxies for newbies" ?
Bernard.
Re: [EMF/CDO] - Exact meaning of 'Resolve Proxies' [message #1426784 is a reply to message #1426452] Fri, 19 September 2014 03:58 Go to previous messageGo to next message
Bernard,
Comments below.
On 18/09/2014 9:37 PM, Bernard SARTER wrote:
> Hello,
I'm not sure the nature of these error messages. Certainly the basic
EMF validator will produce error diagnostics for unresolved proxies, but
I'm not sure how this relates to CDO...
In general, true is a good default. It specifies that the referenced
object in an instance of a class with that reference may be contained in
a different resource, i.e., it specifies that cross resource references
are supported, which is generally the case, except for a few rare
exceptions.
There's the EMF book...
Again, I'm not sure how CDO deals with proxies, but in basic EMF, when a
resource is serialized, any reference to an EObject that's in a
different resource from the referencing object will be serialized as a
"proxy reference", i.e.,
<resource-uri>#<fragment-of-object-in-that-resource>. When that resource
is deserialized, an instance object is created and it carries that URI
as its proxy URI. When that object is accessed, and the reference
specifies resolveProxies true, the object is inspect to see if it's a
proxy and if so to retrieve its proxy URI. Ultimately
resourceSet.getEObject is called with that URI, and if that successfully
returns an EObject, it replaces the proxy and is returned instead of the
proxy. So generally you'll never see a proxy when using the generated
API, except when a proxy fails to resolve, in which case the proxy
itself will be return.
The most common reason proxies fail to resolve, is poor choice of
Resource URIs. I.e., a Resource's URI should generally be an absolute
URI, in which case the URIs in the serialization will generally be
relative URIs. Another reason proxy resolution might fail is because
the referenced object is no longer present in the resource...
I know CDO handles all this somewhat differently, so it's hard to
comment on the CDO aspect of your question...
> Bernard.
Re: [EMF/CDO] - Exact meaning of 'Resolve Proxies' [message #1428863 is a reply to message #1426452] Mon, 22 September 2014 09:21 Go to previous message
On 18-09-14 21:37, Bernard SARTER wrote:
> Hello,
Yes, but I think these could be Proxy Objects, (As in Java proxy
objects, see
http://docs.oracle.com/javase/7/docs/api/java/lang/reflect/Proxy.html
So, CDO uses these Proxy objects, as an CDOObject could be in memory but
not fully resolved from the server. I think this is a different thing,
than the EMF setting, 'Resolve Proxies'....(Please put me straight!)
I experienced proxy errors before, simply non-resolved objects.
See this bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=394076
It went away with a newer build. What is your exact Exception?
> Bernard.
Previous Topic:[CDO] MySQL database is broken after restart of CDO server
Next Topic:[CDO] IllegalMonitorStateException at commit when removing an element
Current Time: Sat Jul 26 20:48:49 EDT 2025
Powered by FUDForum. Page generated in 0.04835 seconds
