Home » Eclipse Projects » NatTable » getCellByPosition() returning a null datavalue
getCellByPosition() returning a null datavalue [message #1426267] Thu, 18 September 2014 09:45 Go to next message
Hi !
I am currently trying to get the cells from the getCellByPosition(int, int) method. If it does indeed return a TranslatedLayerCell, most of its fields are null (such as bounds, configLabels, datavalue...) and what really has me puzzled is that i can get them using the other accessors such as getDataValueByPosition() and getConfigLabelsByPosition().
I feel like I am missing something concerning the different layers but I reallly cant find out what...
these are the two snippets I have tested so far :
BodyLayerStack bs = (BodyLayerStack) cell.getLayer().getUnderlyingLayerByPosition(cell.getColumnIndex(), cell.getRowIndex());
List<Object> rowSpan = ArrayUtil.asList(bs.getSelectionLayer().getSelectedRowPositions().toArray());
List<Integer> columnSpan = ArrayUtil.asIntegerList(bs.getSelectionLayer().getSelectedColumnPositions());
List<Integer> rowSpanRange = ArrayUtil.asList(((Range) rowSpan.get(0)).getMembers().toArray(new Integer[0]));
List<ILayerCell> mergedCells = new ArrayList<ILayerCell>();
	for (Integer indexY : rowSpanRange) {
		for (Integer indexX : columnSpan) {
			mergedCells.add(bs.getCellByPosition(indexX, indexY)); // yielding a list of cells with mostly null values
and,
((NatTable) parent).getLayer().getCellByPosition(2, 2); // yielding cells but with mostly null values
((NatTable) parent).getLayer().getDataValueByPosition(2, 2); // yielding the correct value
((NatTable) parent).getLayer().getConfigLabelsByPosition(2, 2); // yielding the correct value
Thank you for any enlightenment that you could bestow upon me Wink
Re: getCellByPosition() returning a null datavalue [message #1426285 is a reply to message #1426267] Thu, 18 September 2014 10:11 Go to previous messageGo to next message
Maybe because the cells wrap the original cells and the methods that return the correct values are aware of that. Not sure, would need to look into the code myself.
What are you trying to achieve?
Re: getCellByPosition() returning a null datavalue [message #1426290 is a reply to message #1426285] Thu, 18 September 2014 10:20 Go to previous messageGo to next message
I am trying to edit merged cells using a method extracted from EditController: editCells and giving the layer.doCommand(new UpdateDataCommand(layer, selectedCell.getColumnPosition(), selectedCell.getRowPosition(), editorValue)) all the selected merged cells.
oh and also an edition through: cellEditor.activateCell(parent, initialCanonicalValue, EditModeEnum.INLINE, editHandler, cell, configRegistry);
for the first one, I may already have all I need, but for the second I think I need the cells for it to work; which I can't seem to get...
ps: the "cell" and "selectedCell" used are both obtained through mouse selection in the table
[Updated on: Thu, 18 September 2014 10:53] by Moderator
Re: getCellByPosition() returning a null datavalue [message #1426347 is a reply to message #1426290] Thu, 18 September 2014 12:02 Go to previous messageGo to next message
what do you mean with "merged cells"? spanned cells? than just execute the EditCellCommand. If you mean multi editing you need to execute the EditSelectionCommand. There should be no need to operate on the cells itself.
Re: getCellByPosition() returning a null datavalue [message #1426879 is a reply to message #1426267] Fri, 19 September 2014 07:05 Go to previous message
I think I see what I was doing wrong... Thanks for the help !
Previous Topic:Use multi cell painters on a single cell
Next Topic:Make NaTable row non editable based on particular cell value.
Current Time: Thu Jul 24 22:20:57 EDT 2025
Powered by FUDForum. Page generated in 0.04853 seconds
