Home » Eclipse Projects » Sirius » get the name of the file storing a model(get the name of the file storing a model)
get the name of the file storing a model [message #1424807] Tue, 16 September 2014 08:52 Go to next message
Hi !
I would like to get the name of the file given by the user when he creates a model and use it to automatically name the first created instance. Where and how doing this ?
Thanks for your support.
Anne-Lise
Re: get the name of the file storing a model [message #1425503 is a reply to message #1424807] Wed, 17 September 2014 08:12 Go to previous messageGo to next message
you are talking about EcoreTools?
In EcoreTools this name is also given to representation file. You can get the name of representation file by this code:
IWorkbenchWindow win = PlatformUI.getWorkbench().getActiveWorkbenchWindow();
IFile file = (IFile) win.getActivePage().getActiveEditor().getEditorInput().getAdapter(IFile.class);
String name = file.getName();
Re: get the name of the file storing a model [message #1426137 is a reply to message #1425503] Thu, 18 September 2014 05:47 Go to previous messageGo to next message
I am talking about the code in my .odesign file, associated with the creation of an instance in a diagram.
I guess I could associate the code you send to me as an "External Java code". However, I do not understand to which window corresponds the getActiveWorkbenchWindow in instruction:
Thanks again for your help.
Anne-Lise
Re: get the name of the file storing a model [message #1426232 is a reply to message #1426137] Thu, 18 September 2014 08:41 Go to previous messageGo to next message
Hi Anne-Lise
If I well understand your need, I think you could create a Java service,
called on the semantic/domain object which will contain the newly
created instance. The service would take an EObject as parameter and it
could make something like eObject.eResource().getUri(). From this uri,
you will remove the file extension and extract the last segment to get
the file name.
> getActiveWorkbenchWindow in instruction: IWorkbenchWindow win =
This corresponds to the active Eclipse window. By default, when you
launch Eclipse, you see one window (one application in your system), but
if you click on Window > new Window, it opens a new window. Then you
will have two windows (WorkbenchWindow) for the same Eclipse instance
(the Workbench). Only one is active at the same time: the one which has
the focus in your system.
> Anne-Lise
Maxime - Obeo
Need professional services for Sirius?
Re: get the name of the file storing a model [message #1426273 is a reply to message #1426232] Thu, 18 September 2014 09:53 Go to previous messageGo to next message
Thanks Maxime for the answer. It is exactly what I want to do BUT
I have a problem if I test the formula under Acceleo Interpreter. I can get the resource with : Object.eResource() and I see the uri label, but there is an error (of syntax ?...) with Object.eResource().getUri(). Do you know why ?
Maybe I need a good course about emf. Could you advise to me a good support on internet or a book (I am from the old school), waiting next year to see you again to have a lesson to become an expert on emf Smile ?
I will try to include this code into a java service. I still fail to call a java service. It will be next subject, if my colleague cannot help me.
Anne-Lise
Re: get the name of the file storing a model [message #1426752 is a reply to message #1426273] Fri, 19 September 2014 03:03 Go to previous message
Hi Anne-Lise,
> you know why ?
It seems you try to interprete some Java code in the Accelo Interpreter
which is able to interprete Acceleo code (+ Sirius supported interpreter
if the Sirius interpreted is selected).
Acceleo will be able to interprete [someEObject.eResource()/] as
eResource is a method on EObject. But then by default you hav no need to
get the uri with an Acceleo expression without using a Java service.
> year to see you again to have a lesson to become an expert on emf :) ?
You will find some tuto, docs and book references on EMF docs page (see
[1]).
> help me.
You will find information about Java services in the Sirius
documentation (see [2]).
> Regards,
> Anne-Lise
Maxime - Obeo
[1] https://www.eclipse.org/modeling/emf/docs/
[2]
https://www.eclipse.org/sirius/doc/specifier/general/Writing_Queries.html#service_methods
Previous Topic:Sirius - Capture screenshot programmatically
Next Topic:Documentation / Tutorial
Current Time: Sun Jul 27 16:32:50 EDT 2025
Powered by FUDForum. Page generated in 0.04447 seconds
