How to mix GEF's selection display into the PropertySheet with other selections from different Views [message #142464] |
Mon, 12 July 2004 13:26  |
Originally posted by: ra.classys.net
Hello everyone,
After I read again my previous question i realized my chances of getting=
an answer were quite low.
I have the following problem.
In a MultiPageEditor i have a few pages each of them containing an edito=
r. =
One of them is GEF other is a handcrafted JFace (with a ListView and som=
e =
buttons) called ModesetInterface.
When a click happens on an item of this ListView the PropertySheet is =
synchronized with it because the ModesetInterface registers itself to th=
e =
site as the SelectionProvider (this i learned from the article "Take =
control of your properties).
When i switch to the GEF editor, it no longer has the ability to sync th=
e =
selected node with the property sheet. (this part works neatly if I cut =
of =
the other's editor registration as the SelectionProvider).
How can i solve this?
Ra
Re: How to mix GEF's selection display into the PropertySheet with other selections from different V [message #142575 is a reply to message #142557] |
Tue, 13 July 2004 06:52   |
Just wanted to finish this monolog here with the solution to this proble=
m.
MultiPageEditor has its own SelectionProvider that handles the =
distribution/synchronization of selections throughout the member pages. =
Therefore there was no need to make a paralel system for claming the =
SelectionProvider role for all my pages.
The only thing required is that all the pages added should contain =
IEditorPart implementors and they should be added
with the method addPage(IEditorPart , IEditorInput) and certainly NOT th=
e =
simple addPage(Control)
On Tue, 13 Jul 2004 12:16:36 +0300, Rares Pop <ra@classys.net> wrote:
> Still problems....
> I have found out that the SelectionProvider implementor for a GEF edit=
or =
> is by default
> the editor.getGraphicalEditor();
> the problem remains though:
> when I change the page in the MPE (MultiPageEditor) i also change the =
> SelectionProvider accordingly. yet it doesn't work. whoever claims to =
be =
> the SelectionProvider first remains regardless of setSelectionProvider=
> calls that happens after that.
> BUG?
> On Tue, 13 Jul 2004 11:04:44 +0300, Rares Pop <ra@classys.net> wrote:
>> thanks you for answering.
>> how do i do that?
>> is GraphicalEditorWithPallete or one of its members implementing =
>> ISelectionProvider? who?
>> or do i need to make an implementation myself...
>> On Mon, 12 Jul 2004 14:01:33 -0400, Randy Hudson <none@us.ibm.com> =
>> wrote:
>>> change the selection provider every time the page changes.
>>> "Rares Pop" <ra@classys.net> wrote in message
>>> news:opsa1b1r046mykrh@morpheus.classys.net...
>>> Hello everyone,
>>> After I read again my previous question i realized my chances of =
>>> getting
>>> In a MultiPageEditor i have a few pages each of them containing an =
>>> editor.
>>> One of them is GEF other is a handcrafted JFace (with a ListView and=
>>> some
>>> When a click happens on an item of this ListView the PropertySheet i=
s
>>> synchronized with it because the ModesetInterface registers itself t=
o =
>>> the
>>> site as the SelectionProvider (this i learned from the article "Take=
>>> When i switch to the GEF editor, it no longer has the ability to syn=
c =
>>> the
>>> selected node with the property sheet. (this part works neatly if I =
>>> cut of
>>> Regards,
>>> Ra
Using M2, Opera's revolutionary e-mail client: http://www.opera.com/m2/
Re: How to mix GEF's selection display into the PropertySheet with other selections from different V [message #142613 is a reply to message #142575] |
Tue, 13 July 2004 14:37  |
MultiPageEditor is a hack, and you cannot take editors designed to work by
themselves and place them inside a multipage editor. See selectionChanged
in GraphicalEditor for one reason why this approach doesn't work.
news:opsa2ohtcr6mykrh@morpheus.classys.net...
Just wanted to finish this monolog here with the solution to this problem.
with the method addPage(IEditorPart , IEditorInput) and certainly NOT the
> Still problems....
> I have found out that the SelectionProvider implementor for a GEF editor
> is by default
> SelectionProvider accordingly. yet it doesn't work. whoever claims to be
> the SelectionProvider first remains regardless of setSelectionProvider()
> BUG?
>> how do i do that?
>>> Hello everyone,
>>> getting
>>> editor.
>>> some
>>> the
>>> the
>>> cut of
>>> Regards,
>>> Ra
FUDForum. Page generated in 0.04619 seconds
