Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP 4.5.2 installation problems
TPTP 4.5.2 installation problems [message #142450] Tue, 02 June 2009 12:16 Go to next message
Hi all, I am new to TPTP and I am running into issues trying to setup TPTP
on Ganymede.
I downloaded and installed the 4.5.2 plugins (platform and testing tools)
from the 4.5.2 download page, and I successfully converted an existing
unit test into a TPTP unit test.
In the preferences window both "test connection" button/links report
success. However when I right-click my TPTP junit test and choose Run As
-> Test I get a dialog saying "preparing and deploying", then after a few
minutes an error saying "IWAT4039E The Test Execution Harness reported the
following problems: IWAT0005E The host localhost was not found."
I have included my serviceconfig.xml below, and there is no firewall in
the way.
I could not figure out how to enable debug logging for the integrated
agent. Changing INFORMATION to DEBUG in serviceconfig.xml had no effect,
does that configuration file affect the IAC or only standalone controllers?
Also, I am a bit confused by the preference pages:
- is the "Agent Controller -> Agent Controller Local Port" setting
defining the port the IAC will listen on?
- if so why is the default host in "Agent Controller -> Hosts" defined as
localhost[10002] when the default agent controller local port is 10006?
Test connection fails with 10002, I had to add a 127.0.0.1[10006] host for
the test to succeed
- What does the defined list of hosts in Agent Controller -> Hosts mean? I
assume the TPTP client is configured on the "Test" main preference page, I
entered localhost[10006] on that page and the test succeeds.
Your help would be greatly appreciated, I can't figure out how to
troubleshoot those issues...
Franck
<AgentControllerConfiguration>
<AgentControllerEnvironment configuration="default">
<Variable name="JAVA_PATH" position="replace"
value="C:\jre6\bin\java.exe"/>
<Variable name="RASERVER_HOME" position="replace"
value=" E:\ganymede\plugins\org.eclipse.tptp.platform.ac.win_ia32_4. 4.100.v200902101418\agent_controller "/>
<Variable name="TPTP_AC_HOME" position="replace"
value="%RASERVER_HOME%"/>
<Variable name="TPTP_AC_CONFIG_HOME" position="replace"
value=" E:\eclipse\.metadata\.plugins\org.eclipse.tptp.platform.iac. administrator\config "/>
<Variable name="PLUGINS_HOME" position="replace"
value="E:\ganymede\plugins"/>
<Variable name="PATH" position="prepend" value="%RASERVER_HOME%\bin"/>
<Variable name="SYS_TEMP_DIR" position="replace" value="%TEMP%"/>
<Variable name="LOCAL_AGENT_TEMP_DIR" position="replace"
value="%SYS_TEMP_DIR%"/>
<Variable name="CLASSPATH_ORG_APACHE_COMMONS_LOGGING" position="append"
value=" E:\ganymede\plugins\org.apache.commons.logging_1.0.4.v200806 05-1930.jar "/>
<Variable name="CLASSPATH_ORG_ECLIPSE_CORE_COMMANDS" position="append"
value=" E:\ganymede\plugins\org.eclipse.core.commands_3.4.0.I2008050 9-2000.jar "/>
<Variable name="CLASSPATH_ORG_ECLIPSE_CORE_RUNTIME" position="append"
value=" E:\ganymede\plugins\org.eclipse.core.runtime_3.4.0.v20080512 .jar "/>
<Variable name="CLASSPATH_ORG_ECLIPSE_EQUINOX_COMMON" position="append"
value=" E:\ganymede\plugins\org.eclipse.equinox.common_3.4.0.v200804 21-2006.jar "/>
<Variable name="CLASSPATH_ORG_ECLIPSE_OSGI" position="append"
value=" e:\ganymede\plugins\org.eclipse.osgi_3.4.3.R34x_v20081215-10 30.jar "/>
<Variable name="CLASSPATH_ORG_ECLIPSE_EMF_COMMON" position="append"
value=" E:\ganymede\plugins\org.eclipse.emf.common_2.4.0.v2009021711 15.jar "/>
<Variable name="CLASSPATH_ORG_ECLIPSE_EMF_ECORE" position="append"
value=" E:\ganymede\plugins\org.eclipse.emf.ecore_2.4.2.v20090217111 5.jar "/>
<Variable name="CLASSPATH_ORG_ECLIPSE_EMF_ECORE_XMI" position="append"
value=" E:\ganymede\plugins\org.eclipse.emf.ecore.xmi_2.4.1.v2009021 71115.jar "/>
<Variable name="CLASSPATH_ORG_ECLIPSE_JFACE" position="append"
value=" E:\ganymede\plugins\org.eclipse.jface_3.4.2.M20090107-0800.j ar "/>
<Variable name="CLASSPATH_ORG_ECLIPSE_SWT" position="append"
value=" E:\ganymede\plugins\org.eclipse.swt.win32.win32.x86_3.4.1.v3 452b.jar;E:\ganymede\plugins\org.eclipse.swt_3.4.2.v3452b.ja r "/>
<Variable name="CLASSPATH_ORG_ECLIPSE_TPTP_PLATFORM_MODELS"
position="append"
value=" E:\ganymede\plugins\org.eclipse.tptp.platform.models_4.5.2.v 200901290906\tptp-models.jar "/>
<Variable name="CLASSPATH_ORG_ECLIPSE_TPTP_PLATFORM_MODELS_HIERARCHY"
position="append"
value=" E:\ganymede\plugins\org.eclipse.tptp.platform.models.hierarc hy_4.5.1.v200902180100\tptp-models-hierarchy.jar "/>
<Variable name="CLASSPATH_ORG_JUNIT" position="append"
value=" E:\ganymede\plugins\org.junit_3.8.2.v20080602-1318\junit.jar "/>
<Variable name="CLASSPATH_COM_IBM_ICU" position="append"
value="E:\ganymede\plugins\com.ibm.icu_3.8.1.v20080530.jar"/ >
<Variable name="CLASSPATH_ORG_APACHE_JAKARTA_COMMONS_LOGGING"
position="append" value="%CLASSPATH_ORG_APACHE_COMMONS_LOGGING%"/>
<Variable name="CLASSPATH" position="append"
</AgentControllerEnvironment>
<ApplicationAliases>
<Application configuration="default" executable="java.exe"
location="%SYS_TEMP_DIR%" path="%JAVA_PATH%">
value="%CLASSPATH_ORG_ECLIPSE_EQUINOX_COMMON%"/>
</Application>
</ApplicationAliases>
<Plugin path="E:\eclipse\.metadata\.plugins"/>
<Agent path="%TPTP_AC_HOME%\agents"/>
<Jvm location="C:\jre6\bin\client\jvm.dll"/>
<Logging directory="%TPTP_AC_CONFIG_HOME%" format="CBE" level="DEBUG"/>
<ProcessController>%TPTP_AC_HOME%\bin\tptpProcessController.exe </ProcessController>
<Connection name="Dev">
<TransportLayer loadlib="socketTL" type="TPTP_SOCKET">
<Configuration>
<Port>10006</Port>
<SecurityEnabled>false</SecurityEnabled>
</Configuration>
<CommandExtractor>tptpCmdExtr</CommandExtractor>
</TransportLayer>
<TransportLayer loadlib="namedPipeTL" type="TPTP_LOG">
<Configuration>
<PipeName>acmasterlog</PipeName>
</Configuration>
</TransportLayer>
<TransportLayer loadlib="namedPipeTL" type="TPTP_NAMEDPIPE">
<Configuration>
<PipeName>acmaster</PipeName>
</Configuration>
</TransportLayer>
<TransportLayer loadlib="sharedMemTL" type="TPTP_SHAREDMEM">
<Configuration>
<MemName>acbuffer</MemName>
</Configuration>
</TransportLayer>
<TransportLayer loadlib="tptpCCTL" type="TPTP_CCTL">
<Configuration>
<Port>10002</Port>
<SecuredPort>10003</SecuredPort>
<FilePort>10005</FilePort>
<IsDataMultiplexed>false</IsDataMultiplexed>
<ProcessPolling>true</ProcessPolling>
<Version>4.4.1</Version>
<Hosts configuration="default">
<Allow type="LOCAL"/>
</Hosts>
</Configuration>
</TransportLayer>
<TransportLayer loadlib="tptpACTL" type="TPTP_ACTL">
<Configuration/>
</TransportLayer>
</Connection>
<PeerConnectionTransport>TPTP_CCTL</PeerConnectionTransport >
</AgentControllerConfiguration>
Re: TPTP 4.5.2 installation problems [message #142472 is a reply to message #142450] Tue, 02 June 2009 14:31 Go to previous messageGo to next message
I was able to activate logging, and I still get the same error, the log is
included below.
I started the test around 18:21, and the interesting message from the
agent controller seems to be "msg="RAC message was received, so
ignore."... any hint as to what the problem might be?
Thanks!
Franck
<CommonBaseEvent creationTime="2009-06-02T18:20:03.197000Z"
globalInstanceId="A8B5A625E79F4F24BBDD4A9B7CED4E2F"
msg="createTransportListener (socket)" severity="5" version="1.0.1">
<sourceComponentId component="AgentController"
componentIdType="TPTPComponent"
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\socketTL\socketListener.c,
line 915" instanceId="1000" location="D5502H3J" locationType="IPV4"
processId="1584" subComponent="Socket TL" threadId="1816"
componentType="Eclipse_TPTP"/>
<situation categoryName="ReportSituation">
<situationType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:type="ReportSituation" reasoningScope="INTERNAL" reportCategory="LOG"/>
</situation>
</CommonBaseEvent>
globalInstanceId="A1DE48CD4F1943E4BB43E703E670BB5E" msg="Successfully
loaded transport layer: socketTL" severity="5" version="1.0.1">
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\agentController\ConnectionManager.c,
line 184" instanceId="2" location="D5502H3J" locationType="IPV4"
processId="1584" subComponent="Connection Manager" threadId="1816"
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2009-06-02T18:20:03.213000Z"
globalInstanceId="AB7BD738DA0D4C8A9B9F401BB6FE33F7" msg="Successfully
loaded command extractor: tptpCmdExtr" severity="5" version="1.0.1">
line 235" instanceId="2" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="A6A63AA4753246228127133BB2CFC30E"
msg="createTransportListener (named pipe)." severity="5" version="1.0.1">
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\namedPipeTL\namedPipeListener.c,
line 946" instanceId="1001" location="D5502H3J" locationType="IPV4"
processId="1584" subComponent="Named Pipe TL" threadId="1816"
</situation>
</CommonBaseEvent>
globalInstanceId="A4C3E18DC94943BF8A473025F807B446" msg="Successfully
loaded transport layer: namedPipeTL" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
globalInstanceId="A65F2C95987D4532BED8E92B1EBD5207" msg="Successfully
</situation>
</CommonBaseEvent>
globalInstanceId="A978FF143B0245DEAF62D67422B797C7"
line 946" instanceId="1002" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="A41F913C43D64C1FBC38E214477A1FE7" msg="Successfully
</situation>
</CommonBaseEvent>
globalInstanceId="AB1E722734D34FC08466C2DA199B0CCB" msg="Successfully
</situation>
</CommonBaseEvent>
globalInstanceId="AF0711F8A5BD4BBC8574AB6F6FA070CF"
msg="createTransportListener (shared memory)." severity="5"
version="1.0.1">
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\SRC\TRANSPORT\sharedMemTL\sharedMemListener.c,
line 112" instanceId="1003" location="D5502H3J" locationType="IPV4"
processId="1584" subComponent="Shared Memory TL" threadId="1816"
</situation>
</CommonBaseEvent>
globalInstanceId="A27EDC60C2F14A90A98E8B4C12701D07" msg="Successfully
loaded transport layer: sharedMemTL" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
globalInstanceId="A19241E94535413F9A589A03ED31BB84" msg="Successfully
</situation>
</CommonBaseEvent>
globalInstanceId="A972F6A8EC3F4AC5B60573538ECBA5E0" msg="Process polling
thread created, tid = 108" severity="5" version="1.0.1">
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\TPTPClientCompTL\ClientCTL.c,
line 1028" instanceId="1004" location="D5502H3J" locationType="IPV4"
processId="1584" subComponent="Client Compatibility TL" threadId="1816"
</situation>
</CommonBaseEvent>
globalInstanceId="AFE67482778249DC80E785EAE292B935" msg="Successfully
loaded transport layer: tptpCCTL" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
globalInstanceId="AA5150CBDF724F65B348CB1460404B7F" msg="Successfully
</situation>
</CommonBaseEvent>
globalInstanceId="AA43663B7A2A415798BB041CFEC7B101" msg="ACTL process
purge thread created, tid = 3932" severity="5" version="1.0.1">
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\TPTPAgentCompTL\Connect2AC.c,
line 1369" instanceId="1005" location="D5502H3J" locationType="IPV4"
processId="1584" subComponent="Agent Compatibility TL" threadId="1816"
</situation>
</CommonBaseEvent>
globalInstanceId="A5A5B332986243C0A744C2BD16267CCF" msg="Successfully
loaded transport layer: tptpACTL" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
globalInstanceId="A7D3886E75FD4C9E82FC302698A96269" msg="Successfully
</situation>
</CommonBaseEvent>
globalInstanceId="A1B64F0A86824DF5B68DE26AF9FD962B" msg="Ready to start
servers" severity="5" version="1.0.1">
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\agentController\AgentController.c,
line 213" instanceId="0" location="D5502H3J" locationType="IPV4"
processId="1584" subComponent="Core" threadId="1816"
</situation>
</CommonBaseEvent>
globalInstanceId="A380F2443BBC4E73A6A768FA942A56A7"
msg="startTransportListener (socket)" severity="5" version="1.0.1">
line 995" instanceId="1000" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="A6F6CC0E24EB4C318A85CAE27752ABF8" msg="Named pipe server
is running and listening at &quot;\\.\pipe\IBMAC\acmasterlog&quot; pipe."
line 920" instanceId="1001" location="D5502H3J" locationType="IPV4"
processId="1584" subComponent="Named Pipe TL" threadId="516"
</situation>
</CommonBaseEvent>
globalInstanceId="A5A72E4FE4AA47E6808E261424FD1DE0" msg="Ready to accept
next named pipe request." severity="5" version="1.0.1">
line 1105" instanceId="1001" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="AC64DB6D735841B3B9D6B68EFE827959" msg="Named pipe server
is running and listening at &quot;\\.\pipe\IBMAC\acmaster&quot; pipe."
line 920" instanceId="1002" location="D5502H3J" locationType="IPV4"
processId="1584" subComponent="Named Pipe TL" threadId="3008"
</situation>
</CommonBaseEvent>
globalInstanceId="A919F9332E4F407F989E3F44A781B6B1" msg="Ready to accept
line 1105" instanceId="1002" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="AAC9EE34C4EA428D853D1AC428CE12B5" msg="ConnectionManger
- successfully added connectionID 100 for transportID 1004" severity="5"
version="1.0.1">
line 328" instanceId="2" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="A974AA15CC454A6A8C9DA169FBF9FD77" msg="Shared memory
server is running and listening at &quot;acbuffer&quot; name."
line 326" instanceId="1003" location="D5502H3J" locationType="IPV4"
processId="1584" subComponent="Shared Memory TL" threadId="496"
</situation>
</CommonBaseEvent>
globalInstanceId="AFB8F0CF0B6F42D18C8D0C9EE905A04C" msg="Client
compatibility transport layer received a command that that is recognized
(but unsupported). (iid: org.eclipse.tptp.eventProvider cmd:
listenerAccepted)" severity="5" version="1.0.1">
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\TPTPClientCompTL\Connect2AC.c,
line 2280" instanceId="1004" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2009-06-02T18:20:03.228000Z"
globalInstanceId="A38C0DFBD26B4478AB123D7A3F8EEE6D" msg="Native file
server started listening on port 10005" severity="10" version="1.0.1">
line 586" instanceId="1004" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="A71CCF91A3654E2B8A53858E49B63336" msg="Socket server is
running at port number of 10006." severity="5" version="1.0.1">
line 827" instanceId="1000" location="D5502H3J" locationType="IPV4"
processId="1584" subComponent="Socket TL" threadId="1884"
</situation>
</CommonBaseEvent>
globalInstanceId="A819D0D062D944CB89B87B66EC82CCA2" msg="Ready to accept
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\TPTPAgentCompTL\ACTLServer.c,
line 449" instanceId="1005" location="D5502H3J" locationType="IPV4"
processId="1584" subComponent="Agent Compatibility TL" threadId="980"
</situation>
</CommonBaseEvent>
globalInstanceId="A52830B84CA64EF5881713AC00ED4044" msg="Starting Process
Controller:E:\ganymede\plugins\org.eclipse.tptp.platform.ac. win_ia32_4.4.100.v200902101418\agent_controller\bin\tptpProc essController.exe "
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\agentController\AgentManager.c,
line 3095" instanceId="1" location="D5502H3J" locationType="IPV4"
processId="1584" subComponent="Agent Manager" threadId="1816"
</situation>
</CommonBaseEvent>
globalInstanceId="A26D3FB3CBA44403936BBFAF227DBE9E" msg="SUCCESSFULLY
started Process Controller (pid=1240)" severity="5" version="1.0.1">
line 3120" instanceId="1" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="AD3C18C96E1047C2B4182426DAC2AE99" msg="Everything is
running" severity="5" version="1.0.1">
line 227" instanceId="0" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2009-06-02T18:20:03.275000Z"
globalInstanceId="AE558652294B445D8F78054DB7A92621" msg="Received(49
bytes)." severity="5" version="1.0.1">
line 854" instanceId="1002" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="A86A3546F642473FA19463E6B9ECE9D3" msg="Validated message
of 49 bytes" severity="5" version="1.0.1">
line 770" instanceId="1002" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="AC866C08507C4692A9780D362EA340D1" msg="ConnectionManger
- successfully added connectionID 101 for transportID 1002" severity="5"
version="1.0.1">
processId="1584" subComponent="Connection Manager" threadId="3008"
</situation>
</CommonBaseEvent>
globalInstanceId="A0DE14FE181A419A90E4E801BB1533AE" msg="NamedPipe
getInitRequestDataBlock: returning Connection ID: 101." severity="5"
version="1.0.1">
line 163" instanceId="1002" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="AF8838E97F7E48B4BFED136E3033A355" msg="UUID:
e7a1a976-c6ea-4a66-abcc-074d3df9137c." severity="5" version="1.0.1">
line 441" instanceId="1002" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="A2BCCFDBE0A7433C91E3C7314AA0457D" msg="NamedPipe: Sent
16 bytes on connection ID 101" severity="5" version="1.0.1">
line 222" instanceId="1002" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="AD6CF23B769C40E0A846B6D661B2C2EF" msg="Ready to accept
</situation>
</CommonBaseEvent>
globalInstanceId="A61906C72A644720AA29A6C92B5E841F" msg="Received(935
line 854" instanceId="1001" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="A5333189D3BF4FC1B526B69D60AEE2BB" msg="Validated message
of 935 bytes" severity="5" version="1.0.1">
line 770" instanceId="1001" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="ABD56D1BFD1C4838A3F64BC3E1D30C3E" msg="Agent's
(ProcessController) connection id is - 101" severity="5" version="1.0.1">
<sourceComponentId component="ProcessController"
componentIdType="TPTPComponent" componentType="Eclipse_TPTP"
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\agents\agentBase\BaseAgentImpl.cpp,
line 1002" instanceId="101" location="D5502H3J" locationType="IPV4"
processId="1240" subComponent="ProcessController" threadId="2108"/>
<situationType reasoningScope="INTERNAL" reportCategory="LOG"
xsi:type="ReportSituation"/>
</situation>
</CommonBaseEvent>
globalInstanceId="A1E2DA39C5894F50922B5A11D943FE72" msg="Ready to accept
</situation>
</CommonBaseEvent>
globalInstanceId="A5536EB1235943F5B7E7581A67EC13EA" msg="Received(934
</situation>
</CommonBaseEvent>
globalInstanceId="AB22C7A0E3FF461E81EBA217E06C4517" msg="Validated message
of 934 bytes" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
globalInstanceId="A9769A4D7CB34BD1935B025FB2ADD2C6" msg="Agent(101): Bytes
in msg left to be processed: 0 bytes." severity="5" version="1.0.1">
line 887" instanceId="101" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="A1F3BD4F804B46309B9A7F4BD13B16D7" msg="Ready to accept
</situation>
</CommonBaseEvent>
globalInstanceId="A2C523E3C546448580E8398E7CDAC33C" msg="Received(945
</situation>
</CommonBaseEvent>
globalInstanceId="A349D887092445F18163F95C9C65764A" msg="Validated message
of 945 bytes" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
globalInstanceId="A65DB44401D6469A8E5A65CEFC9F387C" msg="BaseAgent
registerFunc: Agent (ProcessController) connected to AC " severity="5"
version="1.0.1">
line 428" instanceId="101" location="D5502H3J" locationType="IPV4"
processId="1240" subComponent="ProcessController" threadId="3092"/>
</situation>
</CommonBaseEvent>
globalInstanceId="AB2E9D62E7B04046BAAB15D5E4A2BE11" msg="Ready to accept
</situation>
</CommonBaseEvent>
globalInstanceId="ABF0FCC6175A4F13941CE1B6A6DED63B" msg="Received(916
</situation>
</CommonBaseEvent>
globalInstanceId="A0EE52113AED48E6A9A9CBA46B7AB1FF" msg="Received(137
&l
Re: TPTP 4.5.2 installation problems [message #142482 is a reply to message #142472] Tue, 02 June 2009 15:26 Go to previous messageGo to next message
One last think, I am beginning to suspect that this is a name lookup
problem. Hopefully the client is not doing an explicit DNS lookup for
localhost, but is using the system calls that will go through the local
hosts file?
Also, I tried to replace localhost with 127.0.0.1 in all the preference
pages and I still get the localhost not found error.
Any help appreciated, I will have to give on TPTP if I can't solve this :(
Franck
E:\>nslookup localhost
*** xxx can't find localhost: Server failed
E:\>ping localhost
Pinging yyy [127.0.0.1] with 32 bytes of data:
Reply from 127.0.0.1: bytes=32 time<1ms TTL=128
Re: TPTP 4.5.2 installation problems [message #142492 is a reply to message #142482] Tue, 02 June 2009 16:34 Go to previous messageGo to next message
I gave it a last shot, and created a custom deployment with a location
that has 127.0.0.1 as the host; I get the same behavior when using Run as
on my TPTP JUnit test with this message:
IWAT0005E The host 127.0.0.1 was not found
Both the "test connection" link in the location editor and the
SampleClient work fine...
Franck
Re: TPTP 4.5.2 installation problems [message #142500 is a reply to message #142492] Wed, 03 June 2009 06:25 Go to previous messageGo to next message
Hi Franck,
What JVM vendor/version are you using for the workbench and Agent
Controller? I believe you are running into
https://bugs.eclipse.org/bugs/show_bug.cgi?id=278655 or something similar.
Can you confirm if there are any stray java.exe processes running. If so,
kill them, restart TPTP/Agent Controller, and run your test again. There is
no need to create a custom deployment/artifact/location (<right-click your
test> >> Run As >> Test).
Paul
"Franck " <franck102@yahoo.com> wrote in message
news:9249e1f6cab34d56e23d4da91bb3b505$1@www.eclipse.org...
>I gave it a last shot, and created a custom deployment with a location that
>has 127.0.0.1 as the host; I get the same behavior when using Run as on my
> Franck
Re: TPTP 4.5.2 installation problems [message #142511 is a reply to message #142500] Fri, 05 June 2009 09:53 Go to previous messageGo to next message
Paul Slauenwhite wrote:
> Hi Franck,
Hi Paul,
Thanks for the help, there was indeed a stray java process left behind,
and even a stray eclipse process as well. Once I kill them the connection
happens and the test completes.
The only remaining issue is that the test takes 5mn to complete when the
method itself should take a few seconds to run, but that is secondary.
Franck
Re: TPTP 4.5.2 installation problems [message #142521 is a reply to message #142511] Fri, 05 June 2009 12:56 Go to previous messageGo to next message
Hi Franck,
Great news. Please add your Bugzilla ID to the CC list for
https://bugs.eclipse.org/bugs/show_bug.cgi?id=278655 if you are interested
in tracking the fix.
As for the slow test execution, what percentage of the test execution
(see the Progress view) takes the longest time? Is security enabled on the
Agent Controller? What JVM vendor/version are you using for the workbench
and Agent Controller?
Paul
news:2cf8cf2e04c6f61ef6f2de46da908d46$1@www.eclipse.org...
>> Hi Franck,
>> similar. Can you confirm if there are any stray java.exe processes
>> running. If so, kill them, restart TPTP/Agent Controller, and run your
>> test again.
> Hi Paul,
> Franck
Re: TPTP 4.5.2 installation problems [message #142539 is a reply to message #142521] Sat, 06 June 2009 01:46 Go to previous messageGo to next message
The execution remains stuck at 33% most of the time, with little CPU usage
but a very high disk activity. I checked the temporary directories
(LOCAL_AGENT_TEMP_DIR) and I see that TPTP is creating copies of many
plugin libraries and even jre libs - that is over 500M of data and over
30,000 files in my case, so that probably explains the performance.
Not sure if there is any way to avoid that step? I am using Sun's Java SE
(build 1.6.0_12-b04) and security is disabled.
Franck
Re: TPTP 4.5.2 installation problems [message #142567 is a reply to message #142539] Mon, 08 June 2009 06:33 Go to previous messageGo to next message
Hi Franck,
At the this (33%) stage of the test execution, the project/plug-in
dependencies are gathered and deployed to the target host (<temp
directory>/<account user name>/). Unfortunately, there is no optimization
for a local deployment. Your deployment may be taking longer due the number
of dependencies on your project/plug-in's classapth or you may be seeing an
exaggerated case of https://bugs.eclipse.org/bugs/show_bug.cgi?id=253288.
Paul
news:186971833477291386bbf8c7e81978a5$1@www.eclipse.org...
>> the Agent Controller? What JVM vendor/version are you using for the
>> workbench and Agent Controller?
> Franck
Re: TPTP 4.5.2 installation problems [message #142597 is a reply to message #142567] Mon, 08 June 2009 13:35 Go to previous messageGo to next message
Thanks Paul,
That is what I feared, we have fairly large plug-in dependencies because
we are integrating a legacy product into Eclipse, I guess we'll have to
live with the [erformance for now.
I ran into an unrelated issue today while trying to execute a unit test
from a shell script as described in the documentation. Using this command
line:
java -Xms40m -Xmx512m -cp
E:/ganymede/plugins/org.eclipse.hyades.execution_4.4.202.v20 0901200947/tptp-automation-client.jar
org.eclipse.hyades.automation.client.adapters.shell.Automati onClientAdapter
-eclipse "E:/ganymede" -workspace e:/workspace -project project1 -suite
project1/qa/src/test1.testsuite
I get the OutOfMemoryError exception with the stack trace included below
(the NoClassDefFound exceptions I think are all due to the
OutOfMemoryException at the bottom of the stack trace).
The interesting thing is that if I then try to open the workspace using
the ganymede IDE, I get the same exception in the error log. The exception
goes away if I shutdown the IDE and restart it, but any attempt to run a
test from the command line makes it reappear.
Short of putting the client under debugger I have no idea where to start
looking, has anyone seen this before? This is with TPTP 4.5.2 from the
Ganymede update site and Sun's JVM 6 on Windows, and that particular unit
test runs fine using Run As in the IDE.
Franck
org.eclipse.core.runtime.CoreException: Plug-in
org.eclipse.hyades.test.tools.core was unable to load class org.eclipse.
hyades.test.tools.core.services.TestExecutionService.
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:180)
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.j
ava:162)
at
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:867)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:2
43)
at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementH
andle.java:51)
at
org.eclipse.hyades.automation.server.ServiceProxy.<init>(ServiceProxy.java:87)
at
org.eclipse.hyades.automation.server.AutomationServer.run(Au tomationServer.java:254)
at
org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hodWithException(EclipseAppContainer.java:574)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:195)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
Caused by:
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException:
An error occu
rred while automatically activating bundle org.eclipse.hyades.test.core
(136).
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:427)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:370)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:446)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:399)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:387)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:315)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1274)
at
ava:160)
... 22 more
Caused by: org.osgi.framework.BundleException: Exception in
org.eclipse.hyades.test.core.TestCorePlugin.start() of bundl
e org.eclipse.hyades.test.core.
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1028)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:984)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
at
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
... 34 more
Caused by: java.lang.NoClassDefFoundError:
org/eclipse/emf/ecore/resource/Resource$Factory$Registry
at
org.eclipse.hyades.test.core.TestCorePlugin.start(TestCorePl ugin.java:247)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:1009)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1003)
... 39 more
Caused by:
An error occu
rred while automatically activating bundle org.eclipse.emf.ecore (71).
at
at
at
at
at
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:33)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:443)
at
at
at
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
... 43 more
org.eclipse.emf.ecore.plugin.EcorePlugin$Implementation.star
t() of bundle org.eclipse.emf.ecore.
at
at
at
at
at
at
... 53 more
org/eclipse/core/resources/ResourcesPlugin
at
org.eclipse.emf.ecore.plugin.EcorePlugin$Implementation.star t(EcorePlugin.java:520)
at
at
... 58 more
Caused by:
An error occu
rred while automatically activating bundle org.eclipse.core.resources (51).
at
at
at
at
at
at
at
at
at
... 62 more
org.eclipse.core.resources.ResourcesPlugin.start() of bundle
at
at
at
at
at
at
... 72 more
Caused by: java.lang.OutOfMemoryError: Java heap space
at
org.eclipse.core.internal.resources.Workspace.newElement(Wor kspace.java:1598)
at
org.eclipse.core.internal.resources.SaveManager.readElement( SaveManager.java:493)
at
org.eclipse.core.internal.watson.ElementTreeReader$1.readDat a(ElementTreeReader.java:62)
at
org.eclipse.core.internal.dtree.DataTreeReader.readNode(Data TreeReader.java:80)
at
org.eclipse.core.internal.dtree.DataTreeReader.readNode(Data TreeReader.java:94)
at
at
at
at
at
at
at
at
at
at
org.eclipse.core.internal.dtree.DataTreeReader.readTree(Data TreeReader.java:135)
at
org.eclipse.core.internal.watson.ElementTreeReaderImpl_1.rea dTree(ElementTreeReaderImpl_1.java:102)
at
org.eclipse.core.internal.watson.ElementTreeReader.readTree( ElementTreeReader.java:123)
at
org.eclipse.core.internal.watson.ElementTreeReaderImpl_1.rea dDeltaChain(ElementTreeReaderImpl_1.java:84)
at
org.eclipse.core.internal.watson.ElementTreeReader.readDelta Chain(ElementTreeReader.java:96)
at
org.eclipse.core.internal.resources.WorkspaceTreeReader_1.re adTrees(WorkspaceTreeReader_1.java:226)
at
org.eclipse.core.internal.resources.WorkspaceTreeReader_1.re adTree(WorkspaceTreeReader_1.java:165)
at
org.eclipse.core.internal.resources.SaveManager.restoreTree( SaveManager.java:921)
at
org.eclipse.core.internal.resources.SaveManager.restore(Save Manager.java:647)
at
org.eclipse.core.internal.resources.SaveManager.startup(Save Manager.java:1326)
at
org.eclipse.core.internal.resources.Workspace.startup(Worksp ace.java:1953)
at
org.eclipse.core.internal.resources.Workspace.open(Workspace .java:1716)
at
org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPl ugin.java:376)
at
at
at
at
Re: TPTP 4.5.2 installation problems [message #142632 is a reply to message #142597] Wed, 10 June 2009 06:55 Go to previous message
Hi Franck,
No, we have not seen this behavior. What vendor/version of JVM? We
test the script adapter every iteration using the following test (calls the
same class as automation-client-adapter.bat/cmd/sh):
http://dev.eclipse.org/viewcvs/index.cgi/test-results/test/o rg.eclipse.hyades.test.core.services.tests/src/org/eclipse/h yades/test/core/services/tests/shell/?root=TPTP_Project
I noticed that you are not passing in the service (see
org.eclipse.hyades.test.core.services.tests.shell.ShellAutom ationClientAdapterTest.testExecuteSampleJUnitTestOutOfProces s()):
org.eclipse.hyades.test.tools.core.execute
If the problem persists, please open a defect.
Paul
news:88dde31c28841df7f86d89304ebe5492$1@www.eclipse.org...
> Thanks Paul,
> line:
> Franck
> at
> at
> ava:162)
> at
> at
> 43)
> at
> andle.java:51)
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by:
> An error occu
> (136).
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> ava:160)
> ... 22 more
> at
> at
> at
> at
> at
> at
> ... 34 more
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> ... 39 more
> Caused by:
> An error occu
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 43 more
> at
> at
> at
> at
> at
> at
> ... 53 more
> at
> at
> at
> ... 58 more
> Caused by:
> An error occu
> (51).
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 62 more
> at
> at
> at
> at
> at
> at
> ... 72 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:COmo puedo ayudar al proyecto
Next Topic:4.5.2 - Where is the 'add' button for test cases?
Current Time: Wed Jul 23 05:27:45 EDT 2025
Powered by FUDForum. Page generated in 0.06902 seconds
