Home » Archived » Visual Editor (VE) » create a bunch of Button once?
create a bunch of Button once? [message #142355] |
Fri, 26 October 2007 03:18  |
Originally posted by: caye5200.yahoo.com.cn
hello,
Can i create ButtonArrayGroup bean that is a visual JavaBean?
You drop down the ButtonArrayGroup can create a bunch of Button?
Re: create a bunch of Button once? [message #142555 is a reply to message #142355] |
Wed, 31 October 2007 17:17   |
Originally posted by: no.ddress.here
In article <ffs4bc$q1e$1@build.eclipse.org>, caye5200@yahoo.com.cn
says...
> hello,
Creating a bean to encapsulate a bunch of buttons is doable, but the
internals will not be modifiable using VE without significant additional
work. Hardly worth the effort if the goal is just to use a different
code styling.
Just accept that no visual designer writes good, concise code; they
write good machine serviceable code. Attempts to get VE to understand
clever code styles are a form of premature optimization.
Best advice is to use VE to create delegate view classes, Composite,
Group, JPanel, etc., try not to look at or modify the generated code,
and certainly don't put logic or event handlers directly in the view
classes. That way, a VE constructed view class containing, say a bunch
of buttons, is effectively a reusable, modifiable VE visual component.
Re: create a bunch of Button once? [message #142562 is a reply to message #142555] |
Wed, 31 October 2007 21:17   |
Gbr,
Thank you, i want do that when you drop down the JRadioButtonGroup,VE
can generate
the following code,i have way to change code , but VE not support,
what to do i need also?
private JRadioButton[] jRBArray=null;
private void initialize() {
this.add(getJRadioButtonGroup(), null);
public JRadioButton[] getJRadioButtonGroup(){
if(jRBArray==null)
jRBArray=new JRadioButton[2];
jRBArray[0]== new JRadioButton();
jRBArray[0]=.setBounds(new Rectangle(264, 118, 21, 21));
jRBArray[1]== new JRadioButton();
jRBArray[1]=.setBounds(new Rectangle(264, 168, 21, 21));
return jRBArray;
My Container extends Container and add following method ,look :
public void add(Component[] arg ,Object arg1)
for(int i=0;i<arg.length;i++)
this.add(arg[i], arg1);
VE why not support it?
"Gbr" <no@ddress.here> wrote in message
news:MPG.219290b8446899da98968c@news.eclipse.org...
> says...
>> hello,
> code styling.
Re: create a bunch of Button once? [message #142665 is a reply to message #142562] |
Thu, 01 November 2007 20:08   |
If, as a user, you want VE to generate or use code in the style you
show, the answer is: no. Why? The code parser internal to VE has no way
to understand your coding style. The parser does not and cannot read
and write arbitrary/clever coding styles. It has its own machine
serviceable coding style. If your code style is not reasonably similar
to the parser's own (which is entirely determined by VE's parser), the
parser will simply stall out, which is likely what you are already
seeing.
If, as a component developer, you wish to create a new component
(JRadioButtonGroup) that is coded in your particular style, you will
need to create the helper routines that will enable the VE code parser
to read and adjust the source code AST. This is completely supported in
VE, just not well documented. Best to go and read the archived messages
on the VE-DEV list where you can read the questions and answers of
others in the process of creating new components.
A thread that may be helpful is here:
http://dev.eclipse.org/mhonarc/lists/ve-dev/msg00036.html
In article <fgb9gc$i6a$1@build.eclipse.org>, caye5200@yahoo.com.cn
says...
> Gbr,
> can generate
> if(jRBArray==null)
> return jRBArray;
> > says...
> >> hello,
> > code styling.
Re: create a bunch of Button once? [message #142673 is a reply to message #142665] |
Thu, 01 November 2007 20:57  |
Gbr,
thank you, I as a component developer, iwant develope a commponentGroup.
news:MPG.21940a5f19e8455398968d@news.eclipse.org...
seeing.
says...
> Gbr,
> can generate
> if(jRBArray==null)
> return jRBArray;
> > says...
> >> hello,
> > code styling.
Re: create a bunch of Button once? [message #616828 is a reply to message #142355] |
says...
> hello,
code styling.
Re: create a bunch of Button once? [message #616829 is a reply to message #142555] |
Gbr,
can generate
if(jRBArray==null)
return jRBArray;
> says...
>> hello,
> code styling.
Re: create a bunch of Button once? [message #616840 is a reply to message #142562] |
seeing.
says...
> Gbr,
> can generate
> if(jRBArray==null)
> return jRBArray;
> > says...
> >> hello,
> > code styling.
Re: create a bunch of Button once? [message #616841 is a reply to message #142665] |
Gbr,
seeing.
says...
> Gbr,
> can generate
> if(jRBArray==null)
> return jRBArray;
> > says...
> >> hello,
> > code styling.
Current Time: Sun Jul 27 16:14:38 EDT 2025
Powered by FUDForum. Page generated in 0.05042 seconds
